6112 alignment
Discussion in 'Suspension' started by 2Manytoyz, Oct 8, 2020.
  1. Oct 8, 2020 at 8:11 PM
    2Manytoyz
    2Manytoyz [OP] New Member
    I installed a blistein 6112 level on the top settings, a cb .5 shim on ds, and cb +2 shackles on the rear and have a couple questions. They said the cams are maxed out , which I expected but the truck still wonders to the right a bit more than I wanted. I gave them some alignment specs I found on the forum. They said I could bring it back but I wanted some input you guys. guys. I really wished I would have went with the 1.9 setting honestly. I feel like the 2.5 is too much for the stock suspension
  2. Oct 8, 2020 at 8:15 PM
    Hartsy8
    Hartsy8 Resident Hockey Guy
    Max
    2020 MGM 1794
    I am installing my 6112s tomorrow and this may help me with my decision.. sorry to jack the thread, but do you have a picture? I am debating if an inch and half in the rear is too much at 1.9. I was also contemplating 2.5 but this has turned me off from that, so thank you!
  3. Oct 8, 2020 at 8:47 PM
    2Manytoyz
    I posted a pic of the truck. I still am running stock tires and will probably do so until after winter is over. A +2 shackle only yields 1.25 lift in the rear. If yours is an actual 1.5 lift then I would keep it on the top setting. If the +1.5 is actually only .75 lift then do the 1.9. I think a little rake looks good with these anyhow
  4. Oct 8, 2020 at 8:51 PM
    Hartsy8
    Max
    2020 MGM 1794
    Ah just saw that, didn’t load up on my phone when I initially saw the post. The shackles are good for true 1.5” of lift. On the fence about using them for now. The more I look the CB +2 shackle might be the ticket.
    I’ll be keeping an eye on this thread, I go in for an alignment on Saturday assuming I can get everything on tomorrow
  5. Oct 10, 2020 at 7:45 AM
    THP865
    THP865 New Member
    2019 Tundra TRD Sport
    Coming soon.
    I installed Blistein 6112s at 1.9, a .5 shim on ds, and 5160s with +1 shackles. My truck pulls right and I have had it aligned and checked twice. I did the install myself and can't help but wonder if I did something wrong but have gone over it in my head many times and come up blank. My truck is a Sport and has sway bars front and rear. I put 1" spacers on the front sway bar to drop it back down and relocated the rear sway bar up on the back of the axle. I am seriously disappointed with the drift/pull to the right. My feeling is the .5" ds spacer is the culprit.
  6. Oct 10, 2020 at 7:54 AM
    cmiller219
    cmiller219 New Member
    Nashville, TN
    2018 Cement CM Tundra
    First at that setting most would go after market UCA. But either way it should still be within specs. Take it somewhere that specializes in lifted trucks.
  7. Oct 11, 2020 at 2:27 PM
    THP865
    THP865 New Member
    Coming soon.
    Were you referring to me or the OP? I specifically kept my lift on the mild side so I wouldn't have any issues or need new UCAs. My wheel/tire combo is basically stock with only a change to a 60 sidewall from a 55. As far as I know, here in Knoxville, there isn't a shop that specializes in lifted trucks. Where would you go in Nashville?
  8. Oct 12, 2020 at 8:17 AM
    cmiller219
    Nashville, TN
    Was talking to the OP. I would reccomend $ wheel parts. My alignment was spot on and I am about to get another one done by them soon. its been a while
  9. Oct 12, 2020 at 8:26 AM
    grichg
    grichg New Member
    rich
    I have 6112 with 3" in the front. AAL and Fox 2.0 in the rear installed by Westcott. Dont know anything about the alignment as they took care of that. I can say that it rides great, no pulling etc.
  10. Oct 12, 2020 at 8:35 AM
    14burrito
    14burrito IG @14burrito
    2014 SR5 CM 4x4 5.7
    Goes right for 2 reasons IMO,
    1. Road crown
    2. Pulls to the side with least positive caster
    So not only is the right lower caster number, but add that with road crown and it's going to go right.
    Ask them to see about driver caster closer to 2
  11. Oct 12, 2020 at 9:34 AM
    14burrito
    2014 SR5 CM 4x4 5.7
    Also, IMO, try getting your cross toe closer to .14.
    Just talking out loud here.
  12. Oct 12, 2020 at 9:47 AM
    Tortuga83
    Tortuga83 New Member
    Tortuga
    7005041C-0293-4842-BA97-776D0F1602A9.jpg 34D7181F-2D3F-488E-B2B3-8C7B098E9890.jpg
    Here is my set up. 6112 at top setting with JBA UCAs. Stock rims and tires. Alignment came out perfect. The place where I got them installed said they would not install them at the top setting without aftermarket UCAs because you would not get the right amount of caster from stock UCAs.
    Oldmtnsoul, toyofan87 and Krewcial like this.
  13. Oct 12, 2020 at 10:55 AM
    BassBlaster
    BassBlaster New Member
    Jay
    2016 silver 1794
    Bilsteins front and rear
    I am at the 1.3 setting. My alignment shows fine on the latest, greatest machine but the truck pulls left at 60+ mph -- any crown and it's a pretty decent pull. I need to take it to a for-real alignment shop (4x4 or racing maybe) but haven't yet.
  14. Nov 20, 2020 at 1:03 PM
    toyofan87
    toyofan87 Beer thirty
    Seth
    Gettysburg, Penna
    That looks killer Tman... Congrats!
  15. Nov 20, 2020 at 2:11 PM
    Tortuga83
    Tortuga
    Appreciate It!!
