  1. Oct 7, 2020 at 3:40 PM
    OnespeedTRD
    OnespeedTRD New Member
    Don
    San Diego
    275/70r18 Cooper AT3 XLT on SCS Ray 10s, Eibach Coilovers, DD 12" Exhaust, AJT Blackout Kit, Truxedo Pro X15, paint match/chrome delete.
    No, just go 90 degrees towards the rear so the bar would be basically in line with, or behind the axle.
  2. Oct 7, 2020 at 3:42 PM
    Hartsy8
    Hartsy8 Resident Hockey Guy
    Max
    2020 MGM 1794
    Any cutting or anything crazy for the install?
  3. Oct 7, 2020 at 3:48 PM
    No. The bumper is a direct fit. It is the Rough Country for the 14 and up. I had it Line-X'ed to match the rest of the truck. I did use the 1/2 inch bumper shims and it lined up perfectly.
  4. Oct 7, 2020 at 3:52 PM
    AggiePhil
    College Station, TX
    I removed the center console box, sat it on the edge of my tailgate, placed the safe in it where I wanted it (front passenger side corner), and used a white grease pencil to reach up from underneath and mark where the hole needed to be drilled in the safe. Then removed the safe and drilled the hole. Then put the console back in place and verified that the holes lined up. Then reinstalled everything and tightened down the bolt. For the bolt, I just used a longer version of the factory bolt.
    kittyhawk[QUOTED] likes this.
  5. Oct 7, 2020 at 4:16 PM
    GiantWinston
    GiantWinston New Member
    Justin
    2016 MGM SR5 5.7l 4x4 Crewmax
    Toytec Boss Lift (3.5" front / 2.5" rear) 295/65/R20 Nitro Ridge Grapplers 2018 LED Headlight Conversion Pioneer AVH-W4400NEX Headunit
    I just looked up what you were talking about and found a pic. In my case the diff is still the lowest point so I'll likely leave it alone, but it does look neat running in line with the axle.
    AggiePhil likes this.
  6. Oct 7, 2020 at 4:27 PM
    RefinedHillbilly
    RefinedHillbilly New Member
    2015 Tundra Crewmax Platinum
    Just watched it while working out actually. Love the content @2020Platinum
    Did you ever end up installing the resonator? I don’t tow very often but my driving is generally 35-40 mph city driving at low RPM or 75-80 freeway driving. Just trying to decide if I want to do the resonator right away or test for a while without.
    2020Platinum likes this.
  7. Oct 7, 2020 at 4:42 PM
    GODZILLA Ask me about my hot doc
    Definitely run it a few hundred miles without. Unless it's totally unbearable, and you'll know that rapidly. Just my opinion.
  8. Oct 7, 2020 at 5:23 PM
    dkahs05
    dkahs05 New Member
    2020 Tundra TRD PRO
    Washed her up. Hard to see a good reflection on a white truck...1007201903.jpg 1007201904.jpg 1007201904_HDR.jpg 1007201904b.jpg 1007201904e.jpg 1007201905.jpg
    RBB, Sean492, 2018Tundra and 17 others like this.
  9. Oct 7, 2020 at 5:56 PM
    FISHN43
    FISHN43 New Member
    Ohio
    2020 Super White TRD Pro
    What brand “TRD Pro” inserts are those?
  10. Oct 7, 2020 at 5:59 PM
    Blue Thunder
    Washington
    Took my 15 year old out for more driving. Introduced him to the 4wd system tonight. Did some driving in a gravel parking lot. He's going to be the only kid he knows that can drive a full-size rig, knows how to use 4wd and can change the oil.
  11. Oct 7, 2020 at 6:01 PM
    sillydadztrksR4momz
    sillydadztrksR4momz New Member
    Yes!
    mrburns05[QUOTED] likes this.
  12. Oct 7, 2020 at 6:02 PM
    dkahs05
    dkahs05 New Member
    2020 Tundra TRD PRO
    I have no idea. The dealership did them.
  13. Oct 7, 2020 at 6:11 PM
    FISHN43
    FISHN43 New Member
    Ohio
    Ok, thanks
  14. Oct 7, 2020 at 6:51 PM
    willx
    willx New Member
    will
    2020 tundra sr5 crewmax
    I installed headlight revolution led interior lights. Girlfriend got in the car and said “my god it feels like last call”. Yea they are bright
  15. Oct 7, 2020 at 7:04 PM
    Pillslinger
    Pillslinger New Member
    Rollin
    SWMO
    2018 Cement TRD CrewMax
    Bed light kit Jerry can mount Badge overlays (removed 2021) Pin stripe / TRD decal / pillar vinyl removal Raised tailgate lettering Center console badge/tray/divider Interior/exterior LED upgrade VLED footwells TVD Vinyl TRD Offroad wheels Icon 17x8 rebound titanium Bubbas Garage grab handles WeatherTech floor mats (Eagle Klaw added) Rough country front shackles (removed 2021) DD SS3 yellow fogs MESO map light replacement Softopper MESO Chrome delete
    You are correct. When I did mine I started the boring out process then decided against it and just very carefully masked it off. 20200830_163641.jpg
  16. Oct 7, 2020 at 7:07 PM
    Bravohook
    Bravohook New Member
    Addame
    NY
    2007 RCSB
    Cool Things
    Ordered new tires, get them on tomorrow. Goodyear Ultraterrain A/T, pics to follow!!
    285/70r17's for my Rock Warriors and the new hub caps should be here next week for them
    Blue Thunder and Fotnot like this.
  17. Oct 7, 2020 at 7:08 PM
    Fotnot
    Fotnot SSEM #69; LRCS#1
    Andy
    SW Louisiana
    Swimmers gonna swim
    Looks good! And it's possible to get white to show reflections. All about lighting and angles. I do it with my wife's van lol
  18. Oct 7, 2020 at 7:11 PM
    BamaMan44
    BamaMan44 Roll Tide Roll! Bama Fan till I die! & Go 'Hawks!
    Andre
    Tucson
    Trailbreaker - 2017 Black CrewMax SR5 4x4
    Installed inner black door handles and the OEM tailgate lock.
  19. Oct 7, 2020 at 7:16 PM
    ElNopal
    Willis TX
    19 Cavalry Blue CM
    Did you get a chance to snap a couple of pics with door handles installed?
    You sure have been busy!
    BamaMan44[QUOTED] and Beesta like this.
  20. Oct 7, 2020 at 7:35 PM
    BamaMan44
    Andre
    Tucson
    No, I didn’t. I can take some for you tomorrow. Yeppers! The wife spoils me. Lol
    Beesta and ElNopal[QUOTED] like this.
  21. Oct 7, 2020 at 8:13 PM
    2020Platinum
    2020Platinum www.youtube.com/NitroZ18Fishing
    Patrick
    Northeast PA
    2022 TRD Pro (Lunar Rock)
    A lot. See my channel for all installs/mods!
    Thank you sir!
    No sir, left resonator off and have no plans on installing it, the sound is perfect for me without it...even with towing the boat it’s awesome, I would def recommend leaving it off to see how ya like it first...you can always go back and install if needed...Thanks for watching!
  22. Oct 7, 2020 at 8:17 PM
    2020Platinum
    Patrick
    Northeast PA
    AJT has a video as others have mentioned, I also have one that goes into a little more detail with how to get those pieces out, and drill out those plastic welds...let me know if I can help ya with any of it...I actually have videos of all AJT product installs, and how to completely disassemble dash for customizing, if you decide to go that route!
    https://youtu.be/A9PX88czq_Y
    Doccountry69, GODZILLA and sotex like this.
  23. Oct 7, 2020 at 8:59 PM
    sbxx312
    sbxx312 New Member
    2018 Tundra, 2012 s/c Tacoma
    Nice. I've gone back and forth about the next mod and this is what I'm going to do. It totally changes the interior and provides some contrast with the cabin chrome making it more tolerable. I put Katzkin leather in my Tacoma in 2012 and it's still going strong even with a terrible dog puking incident a few years ago.
    Two years of camping and dog and Skittles and I'm done with the factory Tundra fabric. Later this month my seats should look like yours but with black stitching.
  24. Oct 7, 2020 at 11:31 PM
    GCanuck
    GCanuck Member since 2020
    Gary
    BC,Canada
    2020 Tundra DC MGM TRD Sport
    TRD Swaybars. Line-X bed liner. Toyota Tri-fold Tonneau. N-fab side bars. TRD cold air. AMP bed extender. Rough Country Level kit. BFG A/T K02. RCI Skids. OEM Tow mirrors. TRD exhaust
    Looks great! Which side bars are those÷ They tuck in nicely
  25. Oct 8, 2020 at 4:32 AM
    Hurricane
    Hurricane Default: Aggressive
    NC
    2017 White 1794
    None
    What does it look like behind the screen? Like what does it look like from the side?
    BamaMan44[QUOTED] likes this.
  26. Oct 8, 2020 at 5:20 AM
    Saab95v6
    Saab95v6 New Member
    I think it looks superb SEM painted , I think this is what I will do to to few remaining chrome parts on the interior.
  27. Oct 8, 2020 at 6:15 AM
    Firefed22
    Firefed22 New Member
    2019 Tundra Crewmax TRD Sport
    Nothing yet, but headed that way!!!!
    What did you go with and are you changing head unit and amp? I spoke to an audio shop who pointed out the difference between the ohms of the head unit vs the new speakers being different and that sound would be effected. I am super interested how it goes for you because the stock is trash!!!
  28. Oct 8, 2020 at 7:04 AM
    shapinoweno
    shapinoweno New Member
    2014 Tundra Platinum crewmax 4x4
    LED lifeeee, so much better. Thanks @Roman
  29. Oct 8, 2020 at 7:07 AM
    Bakershack
    Kelly
    Spanish Fort, AL
    2020 SSM 1794 4x4
    You mind posting a link, or at least a picture of the can of the SEM Trim paint? I think this is a great way to cover the blinding chrome parts without major surgery or changing the look by too much.
  30. Oct 8, 2020 at 7:12 AM
    shapinoweno
    This is the trim paint, it works great but im not sure how well it bonds to the chrome plating. maybe someone can chime in.
