Yakima Outpost HD install problems
Discussion in '2nd Gen Tundras (2007-2013)' started by JBoes, Oct 7, 2020.
  1. Oct 7, 2020 at 3:45 PM
    JBoes
    JBoes [OP] New Member
    Josh
    2012 Tundra Crewmax
    Hey guys, first post here. Trying to install the base plates for a Yakima Outpost HD rack on my wife’s Tundra. It’s a 2012 Crewmax, short bed. No factory bed rail track. It seems that the base plates won’t push in flush with the bed rail because the clamps hit the bed inside. I peeled back the bed liner and the areas that are recessed enough to allow the baseplate to sit flush are pretty short and the clamps don’t get close enough together. Wondering if anyone has run into this. I don’t want to install it with a 1/4” gap like in the photo. The bed liner is pretty thin, so cutting it out in that section will help but not solve it.
    Thanks
    YardBird likes this.
  2. Oct 7, 2020 at 3:52 PM
    YardBird
    YardBird Native San Diegan
    Jonesy
    2005 RCLB
    Welcome aboard.
  3. Oct 7, 2020 at 3:59 PM
    18" TRD Off Road Wheels
    Here is one professionally installed on a Tundra. That gap is intended. Video starts at a point where you can see the gap pretty easily.
    Welcome from Wyoming.
    https://youtu.be/v2-nWk7BoqE?t=89
    Skew12 and Black Wolf like this.
  4. Oct 8, 2020 at 10:32 AM
    JBoes
    Josh
    2012 Tundra Crewmax
    Ok thanks for the info, just wasn’t sure if that gap would take away from the weight capacity. I did cut out a notch of the bed liner, didn’t help much but went ahead and installed it anyways. Feels pretty solid. Thanks for the help.
    GODZILLA likes this.
  5. Oct 8, 2020 at 12:19 PM
    Looks good! If I ever get around to getting a kayak, that is the setup I want for it!
  6. Oct 23, 2020 at 11:36 PM
    PaulROahu
    PaulROahu New Member
    Paul
    Kaneohe, Hawaii
    2017 5.7 Tundra Platinum 4x4 MGM
    Looks great. I installed mines just after my tool box and included the cross bar support
  7. May 13, 2021 at 3:56 PM
    Loswhit
    Loswhit New Member
    Carlos
    hey! New here. I’m having the SAME issues with my ‘18 tundra. I can’t get the overhaul to fit flush...
    How’s it working for you a few months later???
