  1. Oct 7, 2020 at 1:23 PM
    blueshound
    blueshound New Member
    2015 Red Tundra Platinum
    Did you take apart the gear shifter piece to paint it or just mask around it? I was going to wrap mine but then realized you can't just unclip that piece you have to drill it out to get it apart.
  2. Oct 7, 2020 at 1:26 PM
    18" TRD Off Road Wheels
    IIRC the part around the shifter that has to be drilled/broken out is the actual chrome around the shift gate. The part he has painted red (used to be silver, not chrome) is separate and pops off. At least that is what I thought from posts way back?
  3. Oct 7, 2020 at 1:42 PM
    Congratulations! I can't wait for that day.
  4. Oct 7, 2020 at 1:51 PM
    Hartsy8
    Hartsy8 Resident Hockey Guy
    Max
    2020 MGM 1794
    I believe there are plastic welds that need to be bore out with a drill to release the silver finish piece around the shifter
    Pillslinger likes this.
  5. Oct 7, 2020 at 1:56 PM
    BamaMan44
    BamaMan44 Roll Tide Roll! Bama Fan till I die! & Go 'Hawks!
    Andre
    Tucson
    Trailbreaker - 2017 Black CrewMax SR5 4x4
    Just finished an oil change and swapped the plastic housing to aluminum and installed a fumoto valve.
  6. Oct 7, 2020 at 2:02 PM
    BamaMan44
    Andre
    Tucson
    Daytime pics of my new stereo.
    F7F3E0AB-06FD-4927-8FFB-DC778DFC6DAF.jpg C2A90D20-EA12-496C-904D-7CE869979423.jpg
  7. Oct 7, 2020 at 2:05 PM
    You are correct @Hartsy8 ! :thumbsup: I had confused it with the cup holder trim that was only held in with clips. The silver around the shifter area has 5 plastic welds that must be drilled out, per the AJT install video.
  8. Oct 7, 2020 at 2:14 PM
  9. Oct 7, 2020 at 2:18 PM
    French Avocado
    Utah / Wyo
    @Tundra234 Painted or wrapped?
  10. Oct 7, 2020 at 2:19 PM
    SEM trim paint.
    Rely01 and ElNopal like this.
  11. Oct 7, 2020 at 2:24 PM
    Hartsy8
    Max
    2020 MGM 1794
    Thanks for digging up the specifics!! I think the AJT video is where I got the info as well:cheers:
    GODZILLA[QUOTED] likes this.
  12. Oct 7, 2020 at 2:25 PM
    French Avocado
    Utah / Wyo
    Very nicely done!
  13. Oct 7, 2020 at 2:27 PM
    RefinedHillbilly
    RefinedHillbilly New Member
    2015 Tundra Crewmax Platinum
    Got my @dirtydeeds 10” exhaust today! Contemplating if I want to dive into it tonight or take tomorrow off to do it hahahahaha. Any pro tips from all of you to make this go swimmingly as possible since I’m not nearly as mechanically inclined as I’d like to think I am
  14. Oct 7, 2020 at 2:35 PM
    Hit the bolts with WD40 or PB Blaster and let them soak for a while before you try to remove the bolts. Depending on rust, you might want to have a spare bolt or two on hand. You can hit the exhaust bushings with WD40 as well, but DO NOT put PB blaster on them. It is not rubber safe. I used a set of ramps on the front and rear passenger wheels to get a bit more room, and it was a very quick install, but I also didn't do the resonator. Keith has an install video on youtube and it is very easy to follow.
  15. Oct 7, 2020 at 2:36 PM
    Danimal86
    Daniel
    Sacramento, CA
    2017 White Tundra SR5
    Either have an impact or a lot of muscle.....or a BFH to break the front bolts off.
  16. Oct 7, 2020 at 2:36 PM
    :hattip: Sure thing! It's good to get the correct info refreshed in here periodically so forgetful people like me don't go breaking things! :rofl:
  17. Oct 7, 2020 at 2:50 PM
    GiantWinston
    GiantWinston New Member
    Justin
    2016 MGM SR5 5.7l 4x4 Crewmax
    Toytec Boss Lift (3.5" front / 2.5" rear) 295/65/R20 Nitro Ridge Grapplers 2018 LED Headlight Conversion Pioneer AVH-W4400NEX Headunit
    TRD rear sway bar installed.
    Plus, I sent DirtyDeeds my final payment for the group buy. 10" system should ship out tomorrow!
  18. Oct 7, 2020 at 2:54 PM
    mrburns05
    mrburns05 New Member
    Jacob
    Menifee CA.
    2018 4.6L White DC SR5
    Maxtrac 3.5” Spindles Bilstein 6112 Icon AAL Icon 2.5” PB shocks Coachbuilder +1 Shackles AFE dry filter TRD AIA Magnaflow muffler TB Coolant Bypass
    Yea I separated it. Not to difficult really. I did break a tab or two but it still clips in just fine
  19. Oct 7, 2020 at 2:57 PM
    OnespeedTRD
    OnespeedTRD New Member
    Don
    San Diego
    275/70r18 Cooper AT3 XLT on SCS Ray 10s, Eibach Coilovers, DD 12" Exhaust, AJT Blackout Kit, Truxedo Pro X15, paint match/chrome delete.
    Gotta love shiny new parts parts!
    Looks like you have enough rear lift to rotate that swaybar 90 degrees to the rear.
    Would level it out and give you more ground clearance.
    Pretty sure some here have done it with no ill effects.
    Hightide likes this.
  20. Oct 7, 2020 at 3:05 PM
    GiantWinston
    Justin
    I didn't even consider that. The whole install took just 30 min so I wouldn't mind giving it a shot. Thanks for the recommendation.
    Edit: So that would place the sway bar essentially above the axle?
  21. Oct 7, 2020 at 3:06 PM
    @2020Platinum has an excellent video on his channel.
  22. Oct 7, 2020 at 3:13 PM
    CorsoTundra
    CorsoTundra This is the way
    North GA
    2021 Cement Trail Edition
    Toytec Aluma 3/1.5, Pro headlights, OEM LED fog lights, AJT chrome delete, interior/exterior LEDs, front TRD sway, 18x9 Method Roosts, 285/75/18 Toyo A/T 3, RCI engine skid,
    speaker upgrade got here before the truck did.
  23. Oct 7, 2020 at 3:22 PM
    You are correct. I just masked mine off with painters tape.
  24. Oct 7, 2020 at 3:25 PM
    fbingha
    fbingha New Member
    Bakersfield, CA
    Oh I like this and want to do it but fear that someone at the dealer or the truck st
    Paint straight on chrome or did you use a primer?
  25. Oct 7, 2020 at 3:28 PM
    Solid skills. I'm enjoying the journey your new truck is taking. :D
  26. Oct 7, 2020 at 3:33 PM
    Painted straight on the silver. Haven't done the chrome around the cup holder yet.
  27. Oct 7, 2020 at 3:35 PM
    Thanks. Its getting there. Did the lift in the front today, rear will be tomm. Bushwacker flares and the anytime camera kit are on their way. I don't know if I will Line-X these flares like the 2013 or color match this time.
    Wallygator, 3xYOTA, dpast88 and 12 others like this.
  28. Oct 7, 2020 at 3:38 PM
    Maybe just put them on in the regular black to get an idea of how the lines look in black on the new body style? It wouldn't be exactly like the liner, but it would give a close enough idea that you can see if it's the direction you want to go.
  29. Oct 7, 2020 at 3:38 PM
    Hartsy8
    Max
    2020 MGM 1794
    The more I see of it the more I love that bumper!
    GarTX526 and GODZILLA like this.
  30. Oct 7, 2020 at 3:40 PM
    You and me both!
