iforce 4.7 vs non
Discussion in '1st Gen Tundras (2000-2006)' started by ajmorenoaz, Oct 5, 2020.
  1. Oct 5, 2020 at 2:31 PM
    ajmorenoaz
    ajmorenoaz [OP] New Member
    2000 Tundra Sr5
    Hey guys I have a 2000 Tundra and my buddy bought a 2006 crew cab (I have a access cab) and his trucks wayyy faster yea his trucks newer and I have a lift and bigger tires but holy shit he blows me out of the water his is the “iforce” 4.7 tundra but here’s my question was it even a opinion in 2000??? My grandpa bought this truck new and I’m only the second owner so just wondering because I’ve been looking for HP so how do I get this iForce opinion? SWAP THE DAMN THING??
  2. Oct 5, 2020 at 2:41 PM
    ajmorenoaz
    2000 Tundra Sr5
    I probably sound dumb but :duh:
  3. Oct 5, 2020 at 2:42 PM
    Kongap
    Kongap New Member
    2004 SR5 DC
    05 and 06 got beefier engines with that VVTi tech.
  4. Oct 5, 2020 at 2:42 PM
    Darkness
    Darkness Allergic to white
    Luis
    All over SoCal
    The darkest
    It's really dark
    They're all "iForce" but the 05 and 06 have variable valve timing.
    As far as I can tell "iForce" doesn't mean anything.
    snivilous and FrenchToasty like this.
  5. Oct 5, 2020 at 2:42 PM
    ajmorenoaz
    2000 Tundra Sr5
    So the iforce has nothing to do with it?
  6. Oct 5, 2020 at 2:43 PM
    ajmorenoaz
    2000 Tundra Sr5
    So if I don’t have “iforce” on my engine I still have it?
  7. Oct 5, 2020 at 2:47 PM
    Darkness
    Luis
    All over SoCal
    The darkest
    It's really dark
    Toyota made the name "iForce" when they made the first Tundras. It isn't the same as variable valve timing which is what your friend has, the 05-06 get an extra 30 horsepower from the Toyota version of Vtec.
    I think they just made up "iForce" to sound cool.
  8. Oct 5, 2020 at 4:08 PM
    Pucks18
    Pucks18 Fleabit peanut monkey
    2001 Tundra 4x4 Limited trd
    They are not "beefier", they just have the vvti new age crap!
  9. Oct 5, 2020 at 4:08 PM
    ajmorenoaz
    2000 Tundra Sr5
    Always saving the day appreciate it man last question since I have you here bilstein 5100s or icon shocks for the rear?
  10. Oct 5, 2020 at 4:09 PM
    Pucks18
    Your truck should say I force on the rear tailgate next to where it ways toyota tundra
  11. Oct 5, 2020 at 4:15 PM
    ajmorenoaz
    2000 Tundra Sr5
  12. Oct 5, 2020 at 4:16 PM
    Pucks18
    Weird. Must not have been put on them all. As long as u have the v8 it's fine. "Iforce" is just a dummy term
  13. Oct 5, 2020 at 4:21 PM
    Professional Hand Model
    Fred
    Hand Protectors
  14. Oct 5, 2020 at 4:33 PM
    Sunnier
    Sunny
    San Diego, CA
    Of those 2, Icon is the spendier, upper tier option. But do some research on progressive vs. digressive so you get what you need for how you use your truck.
    Also, why only the rear?
  15. Oct 5, 2020 at 4:52 PM
    Darkness
    Luis
    All over SoCal
    The darkest
    It's really dark
    He has Icon up front already :cool:
    I might say neither but depends what you want from your truck.
    5100s are okay, I have run a pair for about ten years. They limit my rear suspension travel by about 3" though. If you will stick with atock springs they are fine.
    Icon, depends which ones. Some are not meant for extra travel (don't confuse travel with lift). They have one set that can work with aftermarket springs but for that price I would sooner get the Archive garage relocation kit and a pair of 12" King or Fox for the rear.
  16. Oct 5, 2020 at 4:53 PM
    BigBone001
    BigBone001 BigBone!
    Charles
    fayetteville NC
    2001 Tundra sr5 extended
    Big brakes front, hid modded headlamp, led modded foglamps, bar lamp inside front bumper, bass box under seat, 2k liftsprings, dimming mirror, dual battery, steering filter
    hey its been a while since i been here....
    the "iForce" stands for "Intelligent Throttle" AKA Electronic throttle control; i think its started at 2001. (thats about 240HP).
    Then the VVT was added at 2005 (thats adds to about 270HP).
    So yes your friend does have little more HP and and a 5 speed transmission, yours is a 4 speed.
    Now there is a supercharger made for the 2000-2003 but is like impossible to find....
    Now about the engine swap... it maybe possible but you will need the ecm too to control the VVT but also you will the the 5 speed transmission....
    i got 2001 and am very happy with it
    Filthyphil and ajmorenoaz[OP] like this.
  17. Oct 5, 2020 at 5:41 PM
    empty_lord
    Indiana, Chicagoland
    05 rollover special
    Engine can be swapped if you find a donor, you’d need the engine, transmission, ecu, engine harness. Then some wiring unless you also swapped the interior harness out.
    The difference is VVTI and a 5 speed auto vs your 2000
  18. Oct 5, 2020 at 9:13 PM
    Darkness
    Luis
    All over SoCal
    The darkest
    It's really dark
    Wait is your friends truck black? If not then paint yours black and you'll smoke his ass.
    :cool:
    Filthyphil, mtntop and bmf4069 like this.
  19. Oct 5, 2020 at 9:40 PM
    artsr2002
    artsr2002 2005 Tundra DC SR5
    'Yonder
    Don't forget the stickers. Each adds 5hp.
  20. Oct 6, 2020 at 1:54 AM
    tvpierce
    tvpierce Formerly New Member
    Maine
    Also, your taller tires make your truck slower off the line. They effectively lower your gearing -- it's like going from a 4:11 to a 3:73 rear end. Plus they add unsprung weight.
    ajmorenoaz[OP] likes this.
  21. Oct 6, 2020 at 2:08 AM
    mnm
    mnm Old Guy...
    Mark
    Smithfield, VA
    2008 Tundra Limited 4x4 DC
    iForce stands for "I force" you to buy a lot of gasoline.....
  22. Oct 6, 2020 at 10:17 AM
    Baller
    Baller New Member
    '05 Tundra SR5 DC
    Also, throw some TRD stickers on your rig for even more HP.
  23. Oct 6, 2020 at 2:05 PM
    Fred
    Hand Protectors
    I’ve been rubbing Crystals on mine for extra speed.
    wandering_boy, bmf4069 and Kongap like this.
