Anyone know where to get Total Chaos UCA tapered spindle adapter, nut, and bolt?
Discussion in 'Suspension' started by longcat, Oct 3, 2020.
  1. Oct 3, 2020 at 6:24 PM
    longcat
    longcat [OP] New Member
    Jon
    DFW / Texas
    2024 Tundra 4x4 Hybrid CrewMax (Silver)
    I was installing my UCA's today and torqued down the bolt going through the uniball connecting the spindle to 100lbs per instruction. I had the truck up on jack stands so I didn't notice that I completely had the sleeve on backwards when I torqued it down as I was outside the fender standing to get leverage. In turn, and yes one of those "DOH!" moments, I realized I bent the sleeve. I removed the bolt and sleeve and used the second sleeve and bolt from my kit to finish attaching the UCA I was working on.
    So now I need to find another sleeve at least. I'd like to get the bolt and nut to go with it. I've sent an email to the info@chaosfab.com to see if I can buy that direct but I thought I'd throw this up here and see if anyone knew somewhere I could source the parts other than the manufacturer, meaning does some online store you might know of stock spare parts? Drop a response if you have any suggestions. (pic attached has an arrow pointing to what I need)
    Thanks!
  2. Oct 3, 2020 at 6:45 PM
    Do you have your instruction sheet?
  3. Oct 3, 2020 at 6:48 PM
    longcat
    Jon
    DFW / Texas
    Yes... not sure what your getting at here but I do have the instructions
  4. Oct 3, 2020 at 6:51 PM
    Okay. Page 4 has a part number listing. Its looking like you will have to get the parts directly from them. I haven't found them anywhere else.
  5. Oct 3, 2020 at 7:10 PM
    14burrito
    14burrito IG @14burrito
    2014 SR5 CM 4x4 5.7
  6. Oct 3, 2020 at 8:03 PM
    longcat
    Jon
    DFW / Texas
    Thanks to you both. I didn't have any luck locating the parts individually online either. I've dropped a few of their authorized dealers (@sdhq_offroad included) to see if they might stock those parts. I'll probably end up calling Total Chaos Fab directly Monday and seeing if they will sell me just those parts. Hopefully it wont be too terribly long to get them.
    831Tun likes this.
  7. Oct 3, 2020 at 9:28 PM
    831Tun
    831Tun heartless Bastrd
    Warren
    Santa Cruz
    '16 CM limited
    Yep, call Pat, pretty much the fastest way to get the parts. The other vendors are just middlemen and are gonna have to do the same thing then sell to you.
    chugs likes this.
  8. Oct 5, 2020 at 9:37 AM
    longcat
    Jon
    DFW / Texas
    Just in case anyone ever needs the info later. The answer is to call TC directly as 831Tun stated. Just got off the phone and I should have them tomorrow. Parts about $55 in parts to replace the bolt, nut, two washers, and the tapered spindle adapter. Overnight shipping is another matter but is what it is. Live and learn.
  9. Oct 5, 2020 at 11:06 AM
    Kerch71
    Kerch71 Surgical Precision
    Mechanicsville VA
    Call Total Chaos. They're a great company and very helpful. I've had to get parts from them before. Seriously doubt you will be able to find those parts anywhere else.
