  1. Oct 4, 2020 at 9:38 AM
    empty_lord
    Indiana, Chicagoland
    05 rollover special
    Well if it’s requested then yes he’s in the wrong.
    we don’t stock em. Found anti-seize on the hub works better. I still run the papers on my trucks. But that’s only because I have a lot someone sold me on Craigslist for 10 bucks lol
  2. Oct 4, 2020 at 9:40 AM
    Darkness
    Darkness Allergic to white
    Luis
    All over SoCal
    The darkest
    It's really dark
    Toyota version of toilet paper hoarding :D
  3. Oct 4, 2020 at 9:48 AM
    empty_lord
    05 rollover special
    Ok just because I have 3 Tacoma transfercases, 8 rear diffs and. Front diffs doesn’t make me a hoarder!
    oscardog86, lsaami, bmf4069 and 3 others like this.
  4. Oct 4, 2020 at 9:56 AM
    Professional Hand Model
    Fred
    Hand Protectors
    Yeah. I’ll buy some more as they are around .96c each. I use both the anti-sieze and the paper gasket which surprisingly has some toughness to them when dry. I might put a thin layer of some Toy FIPG on them and let them dry before putting them on. Should last a lifetime. Hope to find my lost ones soon. :D
    ktundra likes this.
  5. Oct 4, 2020 at 10:21 AM
    Darkness
    Luis
    All over SoCal
    The darkest
    It's really dark
    Selfish collector? :hattip:
    empty_lord[QUOTED] likes this.
  6. Oct 4, 2020 at 11:21 AM
    Rheywood456
    Rheywood456 Sup
    Riley
    Kansas City
    First Gen Tundra
  7. Oct 4, 2020 at 4:26 PM
    jImmegart
    Jonah
    California
    2003 Tundra TRD Sport
    I kind of want to do this same cut but Not sure my truck will fit the look. Plus no going back after I do it
  8. Oct 4, 2020 at 5:28 PM
    ktundra
    ktundra rust be damned
    Lex
    NJ
    06 Tundra DC Limited 4WD
    Bilstein 5100
    Truth be told, it took some time to remove the old paper gasket, even with a wire wheel.
  9. Oct 4, 2020 at 6:57 PM
    Thrussn
    Thrussn Plastidip Hoe
    Gabe
    NM
    Silver 2005 4.7L 4WD Access Cab
    Bilstein 5100s, SickHIDs projector housings, Plastidip everything, TRD Pro style rims, LEDs everywhere, SUPERBUMP bumpstops. Firestone Riderite air bag springs, Deaver G57s, Onboard VIAIR system, Backup Camera, light bar behind the bumper, CGS catback, Exhaust cutout after cats, JBA Shorty headers, JBA Y-Pipe, pioneer deck, pioneer speakers, kicker 10" sub w/ amp, door sound deadening, Dirtydeeds 12 pin injectors, UniChip, Skid Row Skidplate, EZ Oil Drain valve (Better than Fumoto), Oil Catch Can, & 4WD Conversion
    Got bored a while back and ordered some new LED plate lights from big gurl. They came in today and I slapped em in. I kinda dig them!
  10. Oct 4, 2020 at 8:15 PM
    Lil Steve
    Lil Steve Living the dream
    Gilbert, AZ
    I like it! Got a link for those lights?
    Rex Kramer, YardBird and bassman417 like this.
  11. Oct 4, 2020 at 8:43 PM
    SCRunner12
    SCRunner12 New Member
    Robert
    Santa Cruz, CA
    2015 SR5 Crewmax
    Anyone know of any replacement front bottom leather seat covers? Both my driver and passenger are separated at the stitching and all cracked.
  12. Oct 4, 2020 at 9:30 PM
    artsr2002
    artsr2002 2005 Tundra DC SR5
    'Yonder
    Who is this big gurl some of y'all keep referring to? I've had similar license plate lights in my cart on Amazon without the red LED portion. Also, Thrussn, did you plastidip your emblems or order black ones? Link perhaps?
    theblurry1, Darkness and YardBird like this.
  13. Oct 4, 2020 at 9:44 PM
    YardBird
    YardBird Native San Diegan
    Jonesy
    2005 RCLB
  14. Oct 4, 2020 at 9:49 PM
    artsr2002
    'Yonder
    Bwahahahahahaha I can't believe I didn't put that together! LMAO I been shopping Big Gurl for about 300 years. :rofl:
  15. Oct 4, 2020 at 9:50 PM
    YardBird
    Jonesy
    2005 RCLB
    Same here . . . :eek2:
    ktundra and Darkness like this.
  16. Oct 4, 2020 at 9:50 PM
    Lil Steve
    Gilbert, AZ
  17. Oct 4, 2020 at 9:54 PM
    artsr2002
    'Yonder
  18. Oct 4, 2020 at 9:58 PM
    Lil Steve
    Gilbert, AZ
    YardBird and artsr2002[QUOTED] like this.
  19. Oct 4, 2020 at 9:59 PM
    artsr2002
    'Yonder
    Yes sir.
    YardBird likes this.
  20. Oct 5, 2020 at 5:25 AM
    ktundra
    Lex
    NJ
    Bilstein 5100
    So, I went into the rabbit hole to find this gem on toyota-4runner.org forums:
    I spent a bit of time thinking about this gasket when doing my axle seals last week. It's purpose is not to stop the drum sticking. It is there to keep gear oil out of the brake drum.
    The outer axle seal is there to direct oil out of the ABS cavity and into the oil slinger on the back of the axle flange. The oil slinger sends the oil out a little hole in the front of the axle flange that lines up with holes in the brake drum. IF this gasket is in place the oil will end up on the OUTSIDE of the brake drum not inside it! It's a clever as F**k design when you think about it. In theory if this system is all in place you could have a axle seal failure and you would see the oil coming out the front of the brake drum not from the inside. It's a bit hard to put in words but if you have the parts on your hands as I did last week you can see how it is designed to work.
    I'm ordering 2.
    __________________
    -1996 4Runner. 3RZ 5-Spd. 4x4 Base model. OME2906 rears with 2004 Tacoma Dual Rate Fronts on Bilstien 4600s.
    -1993 Corolla Wagon 7AFE
    -2001 Echo (tbd if can be resurrected)
    NUDRAT and shifty` like this.
  21. Oct 5, 2020 at 5:53 AM
    It's all made at the same factory and rebranded with different names, usually in all caps, you can easily find more: https://www.amazon.com/s?k=tundra+t...ag+light+assembly&i=automotive&ref=nb_sb_noss
    This is how they protect themselves from making quality products. If the brand doesn't exist a year from now, they don't need to warranty and don't worry about brand reputation. It's a way of flooding the market with garbage products with no QA/QC. Sometimes the products are so simple you can't get it wrong, so maybe it doesn't matter. A lot of times it's not the case.
    Amazon is a scourge.
    Lil Steve[QUOTED], Thrussn and CodyP like this.
  22. Oct 5, 2020 at 5:56 AM
    CodyP
    CodyP Such a n00b
    Cody
    CDA, ID
    2006 Tundra 4x4 DC
    In more ways than one...
    shifty`[QUOTED] likes this.
  23. Oct 5, 2020 at 6:14 AM
    chrisb
    chrisb scumbag
    noblesville, IN
    06 AC 4x4
    I realize I'm days late to this party, but my Porsche sat in one of these for nearly a decade. The container was next to dude's house, in the country in central IN. Our weather is just like yours, except a bit more humid. If it had been stored anywhere else on that dude's property, it would have just dissolved.
    No ventilation. Just the big double doors used to load/unload the container.
    Can't recommend enough.
    (back to catching up on this thread)
  24. Oct 5, 2020 at 6:22 AM
    empty_lord
    05 rollover special
    Yea... it doesn’t keep the oil out though! Lol
  25. Oct 5, 2020 at 6:37 AM
    Thrussn
    Gabe
    NM
    These are the exact ones I ordered
    https://www.amazon.com/dp/B07V3DHN5X/ref=cm_sw_r_cp_apa_fab_t.XEFbRV3AQ69
    I plastidipped my emblems. It's been a couple years and I should peel and hit them again soon. I used the matte black and then coated it with their plastidip glossifier. It helps the dip hold up in the sun by an impressive amount while also adding a gloss finish. I wouldn't plastidip anything without that glossifier after being able to use it for a while.
  26. Oct 5, 2020 at 6:38 AM
    Fred
    Hand Protectors
    This is true. My paper gasket was just 2 weeks old when the Stealer repair failed. Oil soaked my brand new high dolla MK Yakihama shoes.
    Keep in mind there are two styles of paper gaskets. The round one in my picture and there is one that has a clip off the roundness. Not sure if the quote from @ktundra is about the latter. Never used that style before.
    I don’t see how any paper gasket can keep oil off the shoes with where/how it enters the drum.
  27. Oct 5, 2020 at 6:45 AM
    Fred
    Hand Protectors
  28. Oct 5, 2020 at 7:33 AM
    artsr2002
    'Yonder
    Excellent. Did you remove them or just mask them off?
  29. Oct 5, 2020 at 8:15 AM
    Arringtonpalmer
    Arringtonpalmer New Member
    Sam
    New Hampshire
    2004 Limited Double Cab
    ARB Bumper, Warn Evo, UTE H66 tray, OME 2884 and Nitrochargers.
    Fixed the access cab pop-out windows. The connector had cracked on both ,one totto point where it was NMC. I've had the window pinned closed for a couple years. These ones are aluminum, and came with a right sized punch to pop the pins out.
    Lubbed them up with silicone on re-install and they are smooth. Great ten dollar ten minute fix, why did I wait so long?
    ktundra, hammeron, bmf4069 and 2 others like this.
  30. Oct 5, 2020 at 8:25 AM
    ktundra
    Lex
    NJ
    Bilstein 5100
    I guess I'll save my $$$ and apply anti-sieze compound as @empty_lord reccomended.
