2020 TRD Pro flood lights loose
Discussion in '2.5 Gen TRD Pro (2014-2021)' started by Trebz, Sep 27, 2020.
  1. Sep 27, 2020 at 7:20 AM
    Trebz
    Trebz [OP] New Member
    Trebz
    2015 4Runner but looking for 2020 Tundra
    I have been noticing at night that my flood lights seem to move when I hit a bump. Taking a closer look last night, both panels that hold the lights in seem to have quite a bit of play. I have not had the time to get underneath the truck to see if there is a way to tighten them up.
    Has anyone else with a 2020 TRD Pro noticed this?
  2. Sep 27, 2020 at 7:40 AM
    https://www.tundras.com/threads/trd-pro-rigid-foglight-fix.62375/#post-1633137
    omgboost and Trebz[QUOTED][OP] like this.
  3. Sep 27, 2020 at 7:41 AM
    Trebz
    Trebz
    Thanks. I searched but did find this. Perfect.
  4. Sep 27, 2020 at 7:52 AM
    Kanobi13
    Kanobi13 New Member
    Zip ties
    Elduder and Beesta like this.
  5. Oct 1, 2020 at 8:17 AM
    No Limit
    No Limit New Member
    Alberta
    2020 Tundra TRD PRO 4” Readylift
    My Dealer fixed mine under warranty. They have had enough of them come into the shop loose that they have come up with a fix bolting the plastic housing to the Truck. I had tried the zip ties and it did not last long but I am on rough logging roads daily.
  6. Oct 1, 2020 at 8:18 AM
    Trebz
    Trebz
    I am going to ask the dealer to address it on my next oil change. If not, zip ties it is.
  7. Oct 2, 2020 at 7:59 PM
    Cake's Pro
    Cake's Pro New Member
    Ethan
    CA
    2019 Tundra Pro
    Tinted windows/tails
    If you take the fog light out you will see there is a "blank" tab on the bracket that you can drill through and then use an additional screw to secure the light in three locations. Did that and a ziptie through the clip part of the bracket. No issius anymore.
  8. Oct 2, 2020 at 8:18 PM
    Elduder
    Elduder New Member
    When I replaced mine with the SS3s I couldnt believe how poorly Toyota had designed the mounting surfaces. Simply adding a second post to screw into would fit the issue.
    Zip ties fixed it for me.
  9. Oct 3, 2020 at 8:34 AM
    TundraTXTSS
    TundraTXTSS New Member
    Conroe
    2020 White TRD Pro
    Window Breakage add on Alarm,Wireless Charger. Console Safe, Rear Dif Breather Relocation, Rear Under seat Storage, Hard wire for Radar Detector, Tonnneau Cover, Brake Sensor Protection,SABM with TRD Filter, Tailgate lock, BFG's, LED Running lights.D-3 Tuner.
    I think I'm going to have the delaership do mine, especially if they are fixing them which they should under warranty. I've had mine change a dome light out, front end alignment and fix a squeak due to the front skid plate rubbing something. Now the truck rides some much better.
