Gas saving mode at 25mph
Discussion in '2.5 Gen Tundras (2014-2021)' started by Coffee*8), Oct 2, 2020.
  1. Oct 2, 2020 at 6:55 PM
    Coffee*8)
    Coffee*8) [OP] New Member
    Pennsylvania
    2020 Tundra Crew Max
    + Trans cooler
    I drive like an old man. Stay under 30 if the sign says 25 mph.
    In my new 2020 tundra when I take my foot off the gas at 25-30 mph it will go into gas saving mode and shut off the injectors. It will also down shift so the trucks speed will start to fall. When I hit the gas there is a clunk in the drive train. This clunk worries me.
    If I speed up to 35 mph and do the same, no clunk. Goes into gas saving mode but it does not down shift. When put foot back on gas it just picks up like it should.
    Do others also experience this clunk?
    My wife tells me to just drive faster and problem solved.
    Can a dealer reprogram the trans to not go into gas saving mode if it needs to downshift?
    When the truck is cold it does not go into gas saving mode and when I take my foot off the gas at 25-30 it does not down shift or clunk. Only happens after truck warms up and gas saving mode starts kicking in.
  2. Oct 2, 2020 at 7:59 PM
    betotundra
    betotundra Toyota for Life
    Interesting.
    :popcorn:
  3. Oct 2, 2020 at 8:03 PM
    Makoy339
    Makoy339 Simplicity = Reliability !!!
    Super White TRD
    TRD parts
    Sorry Sir but you're mistaken. Tundras and Gas Saving doesnt belong in the same sentence.
    The engines on the Tundras doesn't have cylinder deactivation.
  4. Oct 2, 2020 at 8:04 PM
    TILLY
    TILLY Gently Used Member
    Massachusetts
    2019 MGM TRD Sport D/C
    Well I'll just come out and say that there is no such thing as a "gas saving" mode that shuts down injectors on a Tundra.
    Spyker, AZBoatHauler, Beesta and 7 others like this.
  5. Oct 2, 2020 at 8:06 PM
    hagrid
    Spraynard
    Pittsburgh
    K1600GTL ZX-14R
    paynuss stretchers
    Hi!
    I'm the guy in your mirror trying desperately to get around you. And the clunk is from towing any kind of trailer without a transmission cooler.
  6. Oct 2, 2020 at 8:31 PM
    TILLY
    Massachusetts
    As far as the clunk goes, i think I've experienced this on a few occasions when i hit the gas just after a recent downshift that's not exactly complete, i expect this is probably normal. Experiment with giving it a second to adjust to the new gear before giving it gas, and it will probably be fine. This is what i did, and it seems to eliminate the clunk. Good luck.
  7. Oct 2, 2020 at 8:55 PM
    Jtundra81
    Jtundra81 Just a member
    Joe
    2019 cement tundra crewmax
    I have the same With my 19, wouldn't worry much about it
  8. Oct 2, 2020 at 9:05 PM
    Coffee*8)
    Pennsylvania
    + Trans cooler
    What is it called then?
    Take your foot off the gas while driving the gallons per hour go to zero, miles per gallon goes to 9999 and horse power goes to 0.
    will start using gas if:
    • put foot on gas
    • slow down to 20mph
    • put it in neutral
  9. Oct 2, 2020 at 9:09 PM
    LA184
    LA184 Living the Dream
    2014 4x4, 4.6L Radiant Red Tundra
    4 in lift, 35s, Black Rhino Armory Wheels, Custom Rock Sliders, SDHQ ABS Guards, Warn Winch Bumper, Warn Evo VR 12-S Winch, 4.88 Re-Gear, Rear E-Locker.
    hahaha:rofl:
  10. Oct 2, 2020 at 9:10 PM
    TILLY
    Massachusetts
    What are you looking at? Do you have an aftermarket gauge setup?
    GODZILLA and Tundyfundy like this.
  11. Oct 2, 2020 at 9:20 PM
    Vizsla
    Vizsla 2 = 2.5
    :monocle:
    14burrito and Tundyfundy like this.
  12. Oct 2, 2020 at 9:45 PM
    SLA10
    SLA10 New Member
    2019 Tundra TRD Pro
    Your just engine braking, no more fuel is being used and you'll continue to decelerate, if going downhill or braking the truck may downshift. Your mpg page will max out any other gauges will reflect max fuel economy, but your bleeding off all your speed and will burn more gas to catch up if your not going downhill or coming to a stop.
    AZBoatHauler, Darkness, Snaz and 4 others like this.
  13. Oct 2, 2020 at 9:55 PM
    knoxville36
    knoxville36 New Member
    Knoxville, TN
    2024 GMC Sierra 1500 Elevation w/3.0 Duramax
    What is going on? Does he have an F-150 with cylinder deactivation and is on the wrong forum?
    Beesta, Tundra234, 14burrito and 3 others like this.
  14. Oct 2, 2020 at 10:04 PM
    Coffee*8)
    Pennsylvania
    + Trans cooler
    Well, what ever it is called, It causes a clunk in the drivetrain when turning off. Does anyone else experience it?
    steps to reproduce:
    warm up truck
    get to 30 mph on a flat or down grade.
    release gas pedal
    wait for the truck to feel like it is slowing down by the engine
    when it gets to 25 mph put foot back on gas -- does the drive-train clunk?
    I went on a drive around and did more testing with it. seems start using gas by itself (no clunk) at 22 mph (can hear engine tone change and my scanguage will show it using gas at the next screen refresh). But when use the gas pedal at 25 it will clunk. The clunk seems to be coming from the engine.
    Think the 2015 would not turn off the gas unless I was going much faster, I don't remember it turning off the gas under 30 mph (at least nothing I could feel in the drive train)
    jtwags likes this.
  15. Oct 2, 2020 at 10:47 PM
    Friday thread!!!
  16. Oct 2, 2020 at 11:14 PM
    You don't seem to understand what people are saying. Your Tundra is not turning off the fuel. There is no system in this truck for fuel preservation. The 5.7 L motor is an oldie, and it gives no shits about MPGs. I do not care what your computer gauges say about fuel economy, your truck is not turning off injectors. You take your foot off the gas and it will use a minimal amount, just like any pre 1990 engine would. This is old tech. You have no fuel preserving systems in this vehicle. Any kind of a clunk that you're hearing has nothing to do with your fuel economy.
    Beesta, Bammer, 1lowlife and 4 others like this.
  17. Oct 2, 2020 at 11:29 PM
    ViktorG
    ViktorG Lexus/Toyota Master Tech
    Viktor
    Calgary, Canada
    2010 RCSB and 2008 DCLB
    World's fastest supercharged Tundra - 2010 RCSB - 10.8 @122 - All wheel drive conversion, lowered, supercharged 2008 DCLB - All wheel drive conversion, 13" lift on 37's
    I can assure you that all modern fuel injected engines (Toyota 5.7L included) stop injecting fuel under most coasting conditions.
    This is called deceleration fuel cut.
  18. Oct 2, 2020 at 11:39 PM
    So you're telling me that when I'm coasting down a hill, and my engine is still running, it's running without fuel? How is it maintaining combustion with no fuel?
    Beesta and Catmann1972 like this.
  19. Oct 2, 2020 at 11:46 PM
    preacher35
    preacher35 RIGHTEOUS MEMBER
    2018 MGM Platinum Crewmax 4x4
    No, you are correct. The motor is STILL RECEIVING fuel from the throttle body. Granted, it is the minimal amount, to keep the motor at idle, but it is indeed, still receiving fuel.
    Tundyfundy likes this.
  20. Oct 2, 2020 at 11:48 PM
    And that's why in my first post I said that it is running on minimal fuel, but it doesn't shut off fuel the way cylinder deactivation does. Tundras don't have anything like that. They're operating on older technology. That's why I bought one.
    10TundraSR5 and Clemsonman14 like this.
  21. Oct 2, 2020 at 11:51 PM
    ViktorG
    Viktor
    Calgary, Canada
    The wheels are turning the axles, which turn the differential, then the driveshaft, then the transmission and finally the engine through the torque converter clutch.
    There is no combustion happening, the engine is just spinning over.
  22. Oct 2, 2020 at 11:53 PM
    ViktorG
    Viktor
    Calgary, Canada
    Cylinder deactivation shuts cylinders off during cruise conditions, not during deceleration.
    Tundra does not use cylinder deactivation, but it certainly uses deceleration fuel cut.
  23. Oct 2, 2020 at 11:56 PM
    ViktorG
    Viktor
    Calgary, Canada
    You are incorrect in that statement sir.
    There is no fuel injected during deceleration fuel cut and there is no combustion in the cylinders.
    (I am a Toyota master tech)
  24. Oct 2, 2020 at 11:59 PM
    o_O so that glorious V8 engine sound that I hear through my exhaust even while coasting down a hill is what? That's combustion happening inside the engine. If it's ceased combustion, even if the engine were being turned, it would stop making the noises associated with combustion. It would just be the mechanical sounds of the engine moving, rather than the small explosions of combustion that make that beautiful V8 sound that is so nice.
    Rex Kramer likes this.
  25. Oct 3, 2020 at 12:00 AM
    ViktorG
    Viktor
    Calgary, Canada
    Here is a page from the repair manual talking about torque converter lock up during deceleration fuel cut, allowing the engine to be turned by the wheels during deceleration through the locked up TC clutch to save fuel.
    RPO 579C, betotundra and Wynnded like this.
  26. Oct 3, 2020 at 12:04 AM
    I understand all of that, and I'm not saying that anything that you said previously isn't true. I'm saying that fuel is still used while coasting. It does not cease combustion. Fuel economy is improved, but fuel is still used.
    Beesta likes this.
  27. Oct 3, 2020 at 12:13 AM
    ViktorG
    Viktor
    Calgary, Canada
    Under a lot of coasting conditions (but not all), there is no fuel being injected into the engine whatsoever.
    Once the engine rpm drops to a certain point, or the accelerator is applied, or the transmission is put in Neutral, fuel injection restarts.
    There is really no point for me to try to convince you any further.
    I have been a shop foreman at a Lexus dealership and a Toyota master tech for 15 years.
    You could just google “deceleration fuel cut” and read up on it.
  28. Oct 3, 2020 at 12:18 AM
    Coffee*8)
    Pennsylvania
    + Trans cooler
    Viktor,
    Is having a clunk noise that you can hear/feel normal when the accelerator is applied during the 'deceleration fuel cut' normal?
    Has Toyota changed the system between 2015 and 2020? In my 2015 never heard/felt this.
  29. Oct 3, 2020 at 12:25 AM
    ViktorG
    Viktor
    Calgary, Canada
    You might be feeling the torque converter clutch disengagement but it should not really be noticeable.
    Since the truck is brand new, the best thing would be to stop by the dealership and ask for a road test with a tech, as well as asking them to let you drive another 2020 model to compare.
    It is very hard to diagnose over the internet...
  30. Oct 3, 2020 at 12:30 AM
    ViktorG
    Viktor
    Calgary, Canada
