New spring U-bolts?
Discussion in '1st Gen Tundras (2000-2006)' started by PenderBen, Sep 28, 2020.
  1. Sep 28, 2020 at 1:13 AM
    PenderBen
    PenderBen [OP] Forum lurker…
    Gulf Islands, BC Canada
    2003 Tundra AC 4x4
    Hey all.
    I need to get new U-bolts for my springs.
    I got a set of Sumo Springs to install, and from the looks of it I expect to have to cut off the factory U-bolts. Toyota replacements seem ridiculously expensive, so I’m looking aftermarket.
    Anything specific I should be looking for, any particular brands that are better regarded, or just check with places like Napa, or maybe Princess Auto?
    I saw these looking around,
    https://www.partsengine.ca/7668-vp-...MIw9P34aP86wIVUhx9Ch2wQAYnEAsYASABEgLlW_D_BwE
    I’m not actually sure what length I need for a factory setup- I could get out an measure mine :)
    Thanks for any advice.
  2. Sep 28, 2020 at 2:47 PM
    SouthPaw
    SouthPaw The headlight guy
    2000 Limited 4x4 AC
    Not sure about your options over the border but the local truck shops around here will cut/make you new U-bolts to your size and spec. Might be worth calling around and seeing if that is an option. Otherwise, Napa has always been my go to.
  3. Sep 28, 2020 at 7:39 PM
    PenderBen
    2003 Tundra AC 4x4
    Cool, thanks for the input. Sounds like there’s nothing too unique going on here, I should be able to find something locally that’ll do.
  4. Sep 29, 2020 at 6:20 AM
    Kongap
    Kongap New Member
    2004 SR5 DC
    How much was your Toyota parts asking for new u bolts?
    Your link isn’t that far off from A little over $100 for 4 from Toyota parts when I looked
    could also buy longer bolts and cut down to your length:
  5. Sep 29, 2020 at 10:33 AM
    PenderBen
    2003 Tundra AC 4x4
    About $40 something each, although I’ve now found them available for around $20 online, which isn’t bad.
    I might just get what I can locally though so I can get it done sooner.
    Kongap likes this.
  6. Sep 29, 2020 at 11:04 AM
    NetGnome
    NetGnome New Member
    NJ
    Removed lots of rust.
    RockAuto.com has them if you need 6 1/2 or 7 1/2 length
  7. Sep 29, 2020 at 11:30 AM
    Warreng
    Warreng New Member
    Assume you are from Pender Island?
    My Aunt has a place out there that I used to visit as a child. Many fond memories :)
    Nothing to add other then the local spring shop in Calgary made mine for my Gen1 in like an hour. Around $100 i think?
    Cuting the old ones off with a recip. Saw is probably the safest bet as they “pop” pretty good when they let go.
  8. Oct 2, 2020 at 7:41 PM
    PenderBen
    2003 Tundra AC 4x4
    Hey, yup, out on Pender. It’s a nice place to be for sure. There are a surprising number of FGTs here too :)
    Warreng[QUOTED] likes this.
  9. Oct 2, 2020 at 8:02 PM
    Darkness
    Darkness Allergic to white
    Luis
    All over SoCal
    The darkest
    It's really dark
    Not sure if Wheelers Off Road would hurt on shipping to Canada hut I think they're $27 a set there.
