Entune software update
Discussion in 'Audio & Video' started by buckrub71, Aug 10, 2019.
  1. Aug 10, 2019 at 6:15 PM
    buckrub71
    buckrub71 [OP] Like Father, Like Son--Semper Fi
    2016 Bronze 1794 CM
    Yesterday a software update pushed into my JBL system. After, the message "new software is not compatible with the system" pops up every start up and requires my to acknowledge. Also, my clock has vanished. I've searched high and low...nowhere to be found. F'ing entune bites! There's also some crappy driver easy speak installed. It uses the mic to blast my voice through the speakers. My crew max is roomy but not that damn big. Anyone know how I can go back a version?
  2. Aug 10, 2019 at 6:21 PM
    AgileTundra
    AgileTundra New Member
    2018 Silver Sky Tundra Platnium 4x4
    Can you post a pic of the version you were updated to?
  3. Aug 10, 2019 at 6:23 PM
    TRDFerguson
    Jake
    Southeast Greater Basin, AZ
    2018 MGM CrüeMax
    You can try downloading the latest from here and reinstalling: https://securedp.toyota.com/download-app/downloads
    Did your update come in over the air? Seems really weird that a Tundra update would have the easy speak stuff... Makes sense in my wife's Highlander, not so much in the truck.
    yoshi82 likes this.
  4. Aug 10, 2019 at 6:52 PM
    buckrub71
    2016 Bronze 1794 CM
    AgileTundra[QUOTED] likes this.
  5. Aug 10, 2019 at 6:54 PM
    buckrub71
    2016 Bronze 1794 CM
    Yes, over the air. It's a 2016. All updates have been OTA. I will give this a shot. Much appreciated.
  6. Aug 11, 2019 at 6:52 AM
    AgileTundra
    This is what I'm currently running. 2018 Platinum
  7. Aug 11, 2019 at 7:17 AM
    Ely010606
    Ely010606 New Member
    SPARKS, NV
    2017 QS SR5 CM TRD 4x4
  8. Aug 11, 2019 at 7:59 AM
    Adam New Member
    Do you have more than one vehicle on your entune account?
  9. Aug 11, 2019 at 1:15 PM
    AgileTundra
    Seems you received an update for a sienna. From what i could find on the inter-webs that easy speak feature is only available for that vehicle.
  10. Aug 11, 2019 at 2:08 PM
    TRDFerguson
    Jake
    2018 MGM CrüeMax
    I can confirm that it is also on the 2019 Highlander. Probably an available option on anything with a third row.
  11. Aug 13, 2019 at 9:54 AM
    buckrub71
    2016 Bronze 1794 CM
    I tired the manual update via the download from Toyota--NO DICE!
  12. Aug 15, 2019 at 6:49 PM
    yoshi82
    yoshi82 New Member
    DAVID
    HOUSTON
    2014 Silver Tundra SR5
    3in ToYtech lift on Tundra and 2.5in in the rear. Tow Mirrors. Toyota grill, and Front bumber. New 6in antenna. Repainted the stepping boards
    im trying to do the update by USB, but i believe that my USB is not working on my Tundra. when im in the screen that shows me the USB option is not lid up, so i read another forum on how to fix this problem. Replace the 15AMP fuse under the driver side Fuse box. So i change the one that says "PWR OUTLET" but it still does the same thing, the USB option is not highlighted on the screen. Im like fixing to get a new radio tire of my system just turning off or resets when ever it wants. Any one has a idea how to fix this situation? i seen the ALpine Halo 9 but $1,400 Jesus!!! any other unit that is good out there under $700
  13. Aug 15, 2019 at 7:01 PM
    gdisarray
    gdisarray Short term member
    2023 Tundra Limited HV
    Tint and wheels. Decked box in the bed. S and B Cold Air filters under the hood. Shiftpower throttle response controller.
    I just got $425 for mine on Fleabay! :D:D
  14. Apr 22, 2020 at 7:47 PM
    southard1686
    southard1686 New Member
    Tundra
    This just happened to me too... 2016 tundra platinum.. Toyota says I have to go to a dealer for the update.. lithia Toyota told me its $169 for the update and $100 for install.. what shit... taking away options and making me pay to get them back is ridiculous
  15. Apr 22, 2020 at 8:09 PM
    TRDFerguson
    Jake
    2018 MGM CrüeMax
    Try running the updates from here first. You should get some over the air updates afterwards, possibly. https://securedp.toyota.com/download-app/getUpdates
  16. Apr 22, 2020 at 8:45 PM
    southard1686
    Tundra
    I tried that. Downloaded it but it’s in kwi format and only Toyota can open it from what they said... I downloaded it, deleted it went tried messing with it for 2 hours and nothing worked. Thank you for sharing that however.
  17. Apr 22, 2020 at 8:51 PM
    TRDFerguson
    Jake
    2018 MGM CrüeMax
    ...why would you need to open the file? That's the binary that should be in the root of the USB drive. Copy the kwi to USB, plug into the USB port under the stereo, run the updater from the HU. I've done this on several vehicles in the past, but who knows if they've done some weird shit recently.
  18. Apr 22, 2020 at 9:06 PM
    southard1686
    Tundra
    Idk. When I saved it to the thumb drive it was for the newer version.. da11, but when I plugged it into the USB port under the radio even after 30 minutes nothing popped up for new update available.. go to settings and update option and nothing ever became available.. maybe it was a mistake I made but I saved everything from the site to my desktop, then desktop to thumb drive. Didn’t work with any of TE 4 times I downloaded it
  19. Jul 11, 2020 at 6:41 AM
    staplegun
    staplegun New Member
    F
    Same EXACT problem here - did you get this resolved? Dealer is worthless!
  20. Jul 11, 2020 at 7:31 AM
    buckrub71
    2016 Bronze 1794 CM
    I went the customer service route and had to jump through hoops of resetting etc. My case was elevated and "approved" to be assessed at my local dealer cost free. I was told they had to be sure I didn't do anything. Since I was planning to upgrade my system anyway, I just trashed it. So was it resolved? No. However, you can likely get some support through customer service. Good luck!
  21. Jul 11, 2020 at 8:06 AM
    southard1686
    Tundra
    So. Mine got solved. Apparently with the update, there was a corroded file with the over Air feature. They had to get an entire new radio/navigation setup. Once that got put it everything works fine.. here’s the issue, unless it’s under warranty you gotta pay for it. Luckily mine was still covered. Took two weeks to get it in, and 30 minutes for install
  22. Jul 11, 2020 at 8:06 AM
    staplegun
    F
    Thanks for reply. I sent a letter to Toyota USA, I spoke with a Shonte Barrow she’s Ted Ogawa’s executive secretary and explained in full detail this issue. Don’t expect much. I’m searching for compatible head unit, probably a Kenwood equipped with navigation. Hate to tear into dash and wire in a new microphone, etc...pretty disillusioned with Toyota.
  23. Jul 11, 2020 at 8:08 AM
    southard1686
    Tundra
    Yeah, I’m thinking that’s what you gotta do.. dealer tried updating and said they couldn’t. After two hours they were saying they tried a everything and couldn’t get past the file.. WTF
  24. Jul 11, 2020 at 9:51 AM
    staplegun
    F
    What route have you guys gone - head unit wise that has navigation?
  25. Jul 11, 2020 at 3:14 PM
    buckrub71
    2016 Bronze 1794 CM
    Dasaita. Absolutely love it! There's a beefy thread on here. Some guys prefer known brands. All I can say is hell yeah. Coupled with a JL package from James I had soon forgotten about my crappy JBL "premium" system. I find myself looking for reasons to run out so I can fire up the sound.
    It allows for everything you can do on an android since it runs that OS. It's essentually an android tablet on the dash. However, though it has a built in navi, I use Waze or Google Maps. I have my Samsung phone run a routine that connects my mobile hotspot when the phone connects to Bluetooth on the unit. Some folks opt to use the Android auto or Carplay (iphone) but I just use my hotspot and run her like a tablet for Amazon music, Netflix, prime video, etc.
    There are also a number of pretty cool car launchers that offer an overlay user interface.
  26. Jul 11, 2020 at 6:17 PM
    staplegun
    F
    Thanks! I'll definitely look into that unit.
  27. Oct 2, 2020 at 11:31 AM
    210tundra
    210tundra New Member
    I know this is an old post but my 2016 tundra started to have this issue as well. I tried updating my system via flash drive and it says I have the current software. I made an appointment w/ the dealership but it sounds like that's a waste of time. Do I just need to start looking into a new head unit or has someone figured out something so I don't need to give them $100+ just for a "diagnostic test"?
  28. Oct 2, 2020 at 11:46 AM
    buckrub71
    2016 Bronze 1794 CM
    As noted above, I opted for a replacement unit--whole system actually. For info on trying to solve it, see post #20.
  29. Oct 2, 2020 at 1:59 PM
    staplegun
    F
    I sent a letter to Toyota North America. Ms Shonte Barrow, Tetsou "Ted" Osagawa’s executive assistant responded and she ultimately set up or arranged a new unit through a local dealer, my cost was $140. Send a letter to Ted Osagawa (CEO) Toyota Motors North America 6565 Headquarters Drive Plano, TX 75024 AND email as well: tetsuo.ogawa@toyota.com. I sent an email and a letter via USPS Registered mail. Please follow up on this website. Toyota NA played coy with this whole nonsense...so be ready.
    Saltyhero13 likes this.
