I need options for 2.5”to 3” longer rear shocks
Discussion in 'Suspension' started by PeakIT, Oct 1, 2020.
  1. Oct 1, 2020 at 9:32 PM
    PeakIT
    PeakIT [OP] Old Member
    Utah
    2019 OR Tundra Double cab
    Coachbuilder 3” shackles, King extended travel, SPC upper arms, 5:29 gears, FN FX rims,35"tires, leer shell, grill
    So about 6 months ago I ordered King extended travel suspension for my 2019. The front ones came a few months later after California opened back up from the Covid thing. But the 2.5” longer 2.5 series shocks still have not been built by King. They dont know when they will get to them and keep pushing them farther out. I even asked of 3.0 bypass would be faster and they said no.
    What other options do I have for rear shocks 2.5” to 3” longer than the OR factory ones ?
    i believe these are the 2019 TRD OR OEM specs
    Collapsed length: 14.98 in
    Extended length: 24.45 in
    So i would need extended length 27” or is there a upper mounting bracket that sits lower?
  2. Oct 1, 2020 at 9:34 PM
    speckmon
    speckmon Must. Have. Pow.
    Thornton, CO
    '07 mountain road bomber
    ADS are essentially the same thing.
    Shit return the kings and go full ADS, it's a popular equivalent.
    chugs likes this.
  3. Oct 1, 2020 at 9:42 PM
    13TundraRW
    13TundraRW New Member
    Kyle
    San Diego, CA
    2013 White Tundra CM RW
    MCM UCA, MCM Shackles, 2.5 ADS C/O, Durobumps Front, Deaver U748, 2.5 ADS Bypasses, Wheelers/Timbren bumps rear, SoftTop
    Yeah ADS makes a deaver spec bypass and resi shock. Not sure on the length tho. Call up ads or Matthew at MCM fab and they can help you out.
  4. Oct 1, 2020 at 10:07 PM
    SC_TRD
    SC_TRD Big BASTRD 4x4 Enthusiast
    Colin
    Round Rock, Tx
    2012 CrewMax & 2008 Sequoia
