  1. Oct 1, 2020 at 6:47 AM
    That's the truth!! She is adorable though. :)
    GODZILLA and NewImprovedRon like this.
  2. Oct 1, 2020 at 6:53 AM
    Ordered my tire pressure sensors so that I can move my wheel and tire package over after the lift is in.
  3. Oct 1, 2020 at 7:17 AM
    sotex
    sotex Sic 'em Bears!
    Jeff
    San Antonio, TX
    2020 White Tundra SR5 Double Cab 4x2 SX
    This is awesome!
    60driver[QUOTED] and Major like this.
  4. Oct 1, 2020 at 8:24 AM
    Blueknights75
    Ron
    Clayton, NC
    None at all...it is about a half inch from the UCA but no issues whatsoever.
  5. Oct 1, 2020 at 8:34 AM
    NoKenDo
    NoKenDo New Member
    Ken
    Grand Rapids MI.
    2018 Platinum 4x4 Mesquite Brown
    TRD Pro Suspension. Moonroof. Front window tint. Compustar Pro T11 remote starter. N-FAB running boards Bedrug Bedmat XLT DiamondBack HD Tonneau Weather Tech Window Visors
    How about some details on this.
    Joss1799 and twistedcricket like this.
  6. Oct 1, 2020 at 9:45 AM
    Dceclipse
    Dceclipse New Member
    NORCAL
    Bed rail project 4E44E666-E068-4167-8BDF-DCD66A64C6D8.jpg 12D3761D-E82F-44CB-B9C5-DA1A40060312.jpg
    KELZ84, Cosmoblu, GODZILLA and 10 others like this.
  7. Oct 1, 2020 at 10:07 AM
    vl184009
    vl184009 Cheers Boys!
    Vicky
    Southern, Ca.
    2016 MGM CM SR5 4x4 w/Tow Pkg
    Looks good! :thumbsup:
    Dceclipse[QUOTED] likes this.
  8. Oct 1, 2020 at 10:28 AM
    frichco228
    frichco228 Valued Member
    Frank
    Virginia
    2016 Crewmax 4WD, TRD Offroad
    I am considering adding the rear bar. How has it changed the ride on highway, straight line? Does it ride harder?
    2020Platinum[QUOTED] and Beesta like this.
  9. Oct 1, 2020 at 12:03 PM
    Will1606
    Will1606 New Member
    Will
    NJ
    2019 TRD DCLB
    Now that’s a beach worthy mod :101010:
  10. Oct 1, 2020 at 12:39 PM
    TrashcanBand
    TrashcanBand New Member
    CenTex
    Tundra
    RCI Bare Aluminum front skid plate...:BE3D681C-4965-4076-95FA-D365A614ABD1.jpg
  11. Oct 1, 2020 at 1:02 PM
    406Michael
    406Michael New Member
    2014 Limited CM
    I am thinking of changing the sub out of my JBL tundra set up. I am curious, do you have the JBL system in yours? If so how did you hook up your sub?
  12. Oct 1, 2020 at 1:23 PM
    GiantWinston
    GiantWinston New Member
    Justin
    2016 MGM SR5 5.7l 4x4 Crewmax
    Toytec Boss Lift (3.5" front / 2.5" rear) 295/65/R20 Nitro Ridge Grapplers 2018 LED Headlight Conversion Pioneer AVH-W4400NEX Headunit
    This place is a bad influence. Just ordered a TRD rear sway bar.
  13. Oct 1, 2020 at 1:47 PM
    Rabidllamas
    Rabidllamas New Member
    Phil
    WA
    2019 Cement Crewmax TRD OffRoad
    My build- https://www.tundras.com/threads/rabbidllamas-old-man-build.80802/
    Very nice. A great mod for those of us who did not get the factory bed rail.
  14. Oct 1, 2020 at 2:38 PM
    ohreary
    ohreary Party!
    2020 Platinum
    I did front and rear on mine recently and there was a noticeable improvement on handling. I can’t tell if it rides rougher since I’m used to driving lowered cars. The tundra has always felt like a plush ride to me
    GiantWinston[QUOTED] likes this.
  15. Oct 1, 2020 at 2:39 PM
    Will1606
    Will1606 New Member
    Will
    NJ
    2019 TRD DCLB
    Just did the same and had the same thought.:rofl:
  16. Oct 1, 2020 at 2:53 PM
    French Avocado
    Utah / Wyo
    Can someone in this very knowledgeable group explain how the sway bars function and correlate with off road use? It seems to the unknowledgeable (that's me) that the sway bars would impede off road capability because of the lack of independence or the wheels - but I am open to learning. Thanks.
    PS - a very bad influence for the wallet but also very knowledgeable.
  17. Oct 1, 2020 at 2:57 PM
    RobertD
    Robert
    DFW, Texas
    If you are actually off roading, you would want to remove the sway bars for the exact reason you described. I have read that some have quick disconnects so they can take theirs off when they go have fun but can reconnect once they are back on paved roads.
  18. Oct 1, 2020 at 2:57 PM
    sotex
    Jeff
    San Antonio, TX
    Added rear under seat storage for my DC. OEM $115
    ElNopal likes this.
  19. Oct 1, 2020 at 4:10 PM
    belanger9
    belanger9 New Member
    Edmonton, AB
    2016 TRD Off Road Inferno
    A bunch
    It ties the frame and the rear axle tighter together. It still allows for up and down travel but doesn't allow the frame and axle to be twisted differently. So if you end up with one rear tire up on a rock it will restrict how much the other tire can travel down. So for off roading it's definitely not a preferred mod.
  20. Oct 1, 2020 at 4:46 PM
    Dceclipse
    NORCAL
    Thanks! and for those of us who doesn’t wanna pay $250 oem bed rail too lol
    Rabidllamas[QUOTED] likes this.
  21. Oct 1, 2020 at 4:47 PM
    Dceclipse
    NORCAL
    thank you sir :hattip:
  22. Oct 1, 2020 at 4:51 PM
    Dceclipse
    NORCAL
    Unistrut bed rails done and Retrax pro installed. 2D8684A0-19FF-4300-A059-D151F5F83129.jpg AC876749-95F5-4529-AF87-E465974A2CEB.jpg
    Watson, GarTX526, Joss1799 and 6 others like this.
  23. Oct 1, 2020 at 5:19 PM
    somecrazyguy
    somecrazyguy New Member
    Steven
    New Braunfels TX
    2020 Limited 4x4 Crewmax Silver Sky
    Finally had a leveling kit installed in the front and a 1 inch block in the back, both from ready lift. I love it!
    RBB, tbutler, Cosmoblu and 12 others like this.
  24. Oct 1, 2020 at 5:31 PM
    RobertD
    Robert
    DFW, Texas
    Looks good!
  25. Oct 1, 2020 at 5:35 PM
    somecrazyguy
    Steven
    New Braunfels TX
    Thanks! I probably need to do something with the tube steps next. Not sure chrome steps go with black rims ...
    Beesta likes this.
  26. Oct 1, 2020 at 5:45 PM
    BarcelonaSX
    BarcelonaSX New Member
    2019 Barcelona red SR5 SX
    Bilstein 6112 front coilovers @2.5”. Bilstein 5100 rear shocks with toytec shackles @1”. 20x9. Xd grenade wheels with 295/60/20 ridge grapplers. Tinted windows. Gibson single side dual exhaust.
    So. The ride from stock to bilstein. I honestly forget. Lol it was almost 20k miles ago and I only put about 3k on the stock suspension before I ripped it apart. I do know with the bilsteins it soaks up the hard bumps really well at speed. As for the bags. I don’t notice much difference. I also have a 1” shackle lift out back so I think that keeps the truck off the bags for the most part when unloaded and at the min 5psi. I tow a 21 foot center console a few times a year.... 5000 or so lbs. also considering A travel trailer.
  27. Oct 1, 2020 at 5:46 PM
    RobertD
    Robert
    DFW, Texas
    You can spray then with bed liner or find a set of the black being sold on here. Many people sell theirs when they get sliders.
    somecrazyguy[QUOTED] likes this.
  28. Oct 1, 2020 at 5:59 PM
    GiantWinston
    Justin
    I agree. My other vehicle is a fun car I like to being to the track. I could use a little stiffer ride on the truck as a daily/towing, but plan on taking it off during offroading.
    100% agree.
    Now this I am very interested in. Will begin to research. This comment also adds to the "bad influence on the wallet but very knowledgeable" group.
    GODZILLA likes this.
  29. Oct 1, 2020 at 6:07 PM
    60driver
    60driver New Member
    Spring Lake, NC
    2016 Tundra CM Platinum Sunset Bronze
    2.5 Toytec Aluma front coilovers JBA UCAs Wheelers Off-road front bumpstops 2.0 Toytec Aluma rear shock OME greasable shackles and bushings OME Dakar Leaf Springs ARE CX Topper with Prinsu Toprac Northstar AGM deep cycle Renogy 100w solar panel with Renogy wanderer controller and BT1 module Yokohama Geolandar X-AT 35x12.5R17 Black Rhino Stadium 17x8.5 +10 Offset
    1/2” marine grade Baltic birch ply for everything but the inner pantry shelves and drawer interior. For those, I used big box-store birch ply. 56” fulterer Locking slides for the lower, 30” for the upper pantry countertop reveal, both up to 450lbs. Accuride slides for the drawer. I used rustoleum tan truck liner for the inner/outer. Chuck box in the rear is a lift-off top, coffee table hinges for the pantry lid.
  30. Oct 1, 2020 at 6:28 PM
    RobertD
    Robert
    DFW, Texas
    Just due to how things are right now, my Tundra has been back burner. But I've spent a lot of time on this forum since April/May just learning and talking with people. I started with a wishlist of like 3 items, I don't even want to count it now :rofl:
    But it's fun getting to read and learn about all sorts of topics. Some that will relate to future projects, and some just because it's fun to learn what others are doing.
