  1. Sep 30, 2020 at 2:45 PM
    RBB
    RBB Member
    Vancouver Island B.C. Canada
    Barcelona Red Mettalic 2020 Tundra TRD off road
    Blackout badges, tailgate insert, sill protectors
    Just looked it up. Looks like they deliver to Canada
  2. Sep 30, 2020 at 2:54 PM
    ElNopal
    Willis TX
    19 Cavalry Blue CM
    No assumptions amigo! It IS bad ass AND I LOVE the color! Very nooice, well done!
    NewImprovedRon likes this.
  3. Sep 30, 2020 at 3:28 PM
    belanger9
    belanger9 New Member
    Edmonton, AB
    2016 TRD Off Road Inferno
    A bunch
    You should be able to get it through any dealer. I got mine when I purchased the truck since it came with a chrome grille. Can't remember if it was 500 total or 700 for both grille and bulge.
    RBB[QUOTED] likes this.
  4. Sep 30, 2020 at 3:35 PM
    willx
    willx New Member
    will
    2020 tundra sr5 crewmax
    Got my 6112 front struts and 5100 rear installed. Came with a free bed accessory.
  5. Sep 30, 2020 at 3:35 PM
    Hartsy8
    Hartsy8 Resident Hockey Guy
    Max
    2020 MGM 1794
    Changes the whole look of the truck! Love it! Patiently waiting for mine to show up
    ElNopal likes this.
  6. Sep 30, 2020 at 3:37 PM
    Oh, that bed accessory isn't going to be free in the long run.:thumbsup:
    dpast88, Cosmoblu, Wrongside and 6 others like this.
  7. Sep 30, 2020 at 3:38 PM
    Vuducrumax
    Vuducrumax New Member
  8. Sep 30, 2020 at 3:39 PM
    That blue and black combination looks great.:thumbsup:
    HulkSmurf14 likes this.
  9. Sep 30, 2020 at 4:13 PM
    Blueknights75
    Ron
    Clayton, NC
    Yes it is sir.
  10. Sep 30, 2020 at 4:16 PM
    Blueknights75
    Ron
    Clayton, NC
    No rub at all once I removed the front little air dam mud flap thing if front of the front tire and cut the skid plate a little which honestly didn’t bother me as my next purchase will be the PRO skid plate which is narrower.
  11. Sep 30, 2020 at 4:31 PM
    Bradleybb
    Bradleybb New Member
    Georgia
    2021 CM TRD OR
    Transmission cooler TRD REAR SWAY RCI front skid
    2F9040E0-624E-4F75-BAEF-57C9241F802E.jpg 66005EF2-F85B-4251-A067-71838E45A04F.jpg Got my dechromeing started today , along with the truxedo sentry ct tonneau,
    TRD pro HL nice to have the LEDs ..thanks to iHacker for pnp wire harness
    Got work on chrome bumpers
  12. Sep 30, 2020 at 4:38 PM
    PaulROahu
    PaulROahu New Member
    Paul
    Kaneohe, Hawaii
    2017 5.7 Tundra Platinum 4x4 MGM
    Sorry was offline for a while here it is
  13. Sep 30, 2020 at 4:43 PM
    PaulROahu
    Paul
    Kaneohe, Hawaii
    Forgot if it was EBay or Amazon. Cheap less than $20 and has special socket with cap. Just remember to put it with your rim lock socket bag/container
    Skippy likes this.
  14. Sep 30, 2020 at 4:58 PM
    GravityGear
    Aurora, CO
    Is that free? Looks expensive.
    GODZILLA likes this.
  15. Sep 30, 2020 at 5:08 PM
    That is a damn fine looking truck! Love the reds that Toyota has used.
    NewImprovedRon and ElNopal like this.
  16. Sep 30, 2020 at 5:11 PM
    Now I just need to see about painting the insert black.
    ElNopal likes this.
  17. Sep 30, 2020 at 5:45 PM
    60driver
    60driver New Member
    Spring Lake, NC
    2016 Tundra CM Platinum Sunset Bronze
    2.5 Toytec Aluma front coilovers JBA UCAs Wheelers Off-road front bumpstops 2.0 Toytec Aluma rear shock OME greasable shackles and bushings OME Dakar Leaf Springs ARE CX Topper with Prinsu Toprac Northstar AGM deep cycle Renogy 100w solar panel with Renogy wanderer controller and BT1 module Yokohama Geolandar X-AT 35x12.5R17 Black Rhino Stadium 17x8.5 +10 Offset
    Build 98% complete. Still a couple things to tweak and I need to finish the cutting board.37D177D7-36A7-4081-BC51-99AB64776BFB.jpg
  18. Sep 30, 2020 at 6:09 PM
    Glennjermin
    Glennjermin New Member
    Glenn
    Virginia
    2014 Toyota Tundra SR5 Crewmax 4x4
    Icon Add A Leaf springs Bilstien 5100 shocks Freedom Off Road UCAs Snugtop rebel camper shell Prinsu Roof Rack Decked System
    I updated and added a new box to my roof rack.
    Cosmoblu, Major, TOYOTARIG and 7 others like this.
  19. Sep 30, 2020 at 7:05 PM
    Bradleybb
    Georgia
    2021 CM TRD OR
    So did you have to swap out your insert , I did
    Toyota bs updateing parts cost you more $$$$
  20. Sep 30, 2020 at 7:27 PM
    No I didn't. Both inserts were the same.
  21. Sep 30, 2020 at 10:00 PM
    jr1016
    jr1016 New Member
    Ric
    Sacramento, CA
    2020 CM TRD Sport
    Wait you can't use the TRD skid plate after lifting the truck? I'm planning to get mine leveled and put 285/70/18 then eventually get the TRD skid plate for the oil filter access.
  22. Sep 30, 2020 at 10:21 PM
    2020Platinum
    2020Platinum www.youtube.com/NitroZ18Fishing
    Patrick
    Northeast PA
    2022 TRD Pro (Lunar Rock)
    A lot. See my channel for all installs/mods!
    Yepper, you can still use it, just need the spacer kit with the spacers/longer bolts if you drop your diff for the clearance
    jr1016[QUOTED] likes this.
  23. Sep 30, 2020 at 10:36 PM
    PaulROahu
    Paul
    Kaneohe, Hawaii
    What fun activities did your Tundra load/pull today
  24. Oct 1, 2020 at 12:11 AM
    TheyCallMeBruce84
    TheyCallMeBruce84 New Member
    Bruce
    NC
    2020 Tundra Limited Barcelona Red
    WeatherTech side window deflectors - I derped them on the inside edge before installing so they are completely opaque.
    TRD Rear Sway bar - test drive will be later this morning.
  25. Oct 1, 2020 at 2:35 AM
    Beesta
    Beesta New Member
    Jay
    Loudoun County
    2019 Pro Midnight Black Metallic
    You’ll be fine for only leveling ... anything more than 3” is no go ....like Pat said .. RC makes a kit for skid plate hardware kit
    jr1016[QUOTED] and 2020Platinum like this.
  26. Oct 1, 2020 at 3:38 AM
    Haggis777
    Haggis777 I.L.J.C.M.L.
    SW Michigan
    2015 Silver SR5 TRD Tundra Canadian Model
    LEDs interior & exterior, stubby antenna, Bak-Flip cover, 285's, AGM battery, block heater, Pine tree air freshener
    Ditto...after having WeatherTechs in my former truck, a buddy showed me the Huskies he had in his Ram. Definitely prefer the Husky fit and quality more than WeatherTechs.
  27. Oct 1, 2020 at 3:54 AM
    Beesta
    Beesta New Member
    Jay
    Loudoun County
    Not a damn thing ..... Nice pictures .... i think you need more bikes on roof rack ... Tundra Power !!!
  28. Oct 1, 2020 at 4:22 AM
    Skippy
    Skippy Standing for the Flag
    San Antonio US of A
    2016 Tundra 1794
    Where do you get the spacer kit? Is that something the dealer has. I've got the TRD plate on my 2016 with a dropped front differential, and tired of the popping noise. I could put in the Diamond x rubber spacer, but would rather have something a little more permanent
  29. Oct 1, 2020 at 4:24 AM
    Beesta
    Beesta New Member
    Jay
    Loudoun County
    https://www.readylift.com/tundra-trd-pro-skid-plate-spacer-kit.html
    Skippy[QUOTED] and 2020Platinum like this.
  30. Oct 1, 2020 at 6:02 AM
    Firefed22
    Firefed22 New Member
    2019 Tundra Crewmax TRD Sport
    Nothing yet, but headed that way!!!!
    no rub issues or upper control arm problems?
