4wd hi light flashing
Discussion in '2nd Gen Tundras (2007-2013)' started by butterball1, Aug 31, 2020.
  1. Aug 31, 2020 at 7:06 AM
    butterball1
    butterball1 [OP] New Member
    2008 tundra
    I have a 2008 tundra ,I have the 4wd hi light flashing not going into 4wd .Before I take actuator motor off to replace ,which wires are actually sending battery to the motor i want to put a meter on them first to make sure I have electric going to actuator
    Mountun Goat likes this.
  2. Aug 31, 2020 at 7:40 AM
    Mountun Goat
    Mountun Goat She baaaaaahd
    EhBerta, Canadia
    It’s a Goat.
    I’m not sure on which wires, but my 2008 has been doing this on and off for a year or so. Hopefully I can gain some knowledge from this thread too.
    :popcorn:
    Tundra2 likes this.
  3. Aug 31, 2020 at 9:37 AM
    Trident
    Trident New Member
    2007 Tundra DC 4X4
    I'm not the best at remembering to engage 4hi every so often in my truck. Around last Xmas, it took almost 5 miles of fire roads before it would engage successfully. Flashing 4hi the entire time until it engaged. Took way longer than I thought possible. Since then, it's worked properly.
  4. Sep 1, 2020 at 12:07 AM
    FWD Tundra
    FWD Tundra New Member
    Washington
    2013 Tundra 4WD Double Cab
    Exercising the engage switch once a month is a good thing to do, once you have it fixed. I usually run it in 4Hi for about 10 miles then off and on a few times after that to keep it in shape.
  5. Sep 29, 2020 at 9:39 AM
    Mountun Goat
    EhBerta, Canadia
    It’s a Goat.
    FYI I tried switching my truck into 4-lo/4-hi/ 2wd and back a few times and seems good now.
    Good thing to remember to switch em into low often.
