Brush Grill Guard
Discussion in 'New Member Introductions' started by wostenberg, Sep 27, 2020.
  1. Sep 27, 2020 at 4:08 PM
    wostenberg
    wostenberg [OP] New Member
    William
    Toyota Tundra Crewmax 5.7L 4WD
    I have a 2007 Tundra Crewmax 5.7L 4WD. I want to put a Grill Guard on it. I found a
    SteelCraft® 50-3380C - HD Series Black Grille Guard that on a site says it will not interfere with the front sensors. I have a plastic cover over the steel support. Do I need to do something other than bolting it up?
    Thank you
    YardBird likes this.
  2. Sep 27, 2020 at 5:00 PM
    Welcome from NY.
    It should bolt up to where the tow hooks are.
  3. Sep 27, 2020 at 5:15 PM
    Bakershack
    Kelly
    Spanish Fort, AL
    2020 SSM 1794 4x4
  4. Sep 27, 2020 at 7:21 PM
    wostenberg
    William
  5. Sep 27, 2020 at 7:23 PM
    wostenberg
    William
    So, the tow hooks are removed, or still mounted with the Grill Guard? Does the Grill Guard interfere with the sensors?
    Thank you
  6. Sep 27, 2020 at 7:25 PM
    Most of the time you can put the tow hooks back with the guard. It shouldn't interfere.
  7. Sep 27, 2020 at 8:04 PM
    YardBird
    YardBird Native San Diegan
    Jonesy
    2005 RCLB
    Welcome aboard from SoCal.
  8. Sep 28, 2020 at 1:42 PM
  9. Sep 28, 2020 at 5:37 PM
    Rgross2112
    Rush
    2020 Silver TRD Limited
    Welcome from Pennsylvania
  10. Sep 28, 2020 at 6:59 PM
    Ely010606
    Ely010606 New Member
    SPARKS, NV
    2017 QS SR5 CM TRD 4x4
    Welcome from Nevada
