  1. Sep 27, 2020 at 12:42 PM
    #8161
    ktundra
    ktundra rust be damned
    Lex
    NJ
    06 Tundra DC Limited 4WD
    Bilstein 5100
    Any recommendations on a good broken bolt extractor set? Are Harbor Freight any good?
  2. Sep 27, 2020 at 12:52 PM
    #8162
    Yes, this time it clicked before I even moved. Normally it doesn't make the noise until I start moving.
  3. Sep 27, 2020 at 1:27 PM
    #8163
    Towed a boat!!! The truck did great, the trailer was a POS, felt like my drive shaft was going to explode at 65-70, but it was either the boat vibrating from the air sail it was creating or bouncing on the tires. It was a good time but I’m pooped, had to make the trek down the mountain to the hospital and back up because my buddy hooked himself deep in the finger. Steaks didn’t go on untill almost 930
    Voss, GODZILLA, mtntop and 10 others like this.
  4. Sep 27, 2020 at 1:42 PM
    #8164
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
    Are we talking a rounded bolt head, or snapped head off?
  5. Sep 27, 2020 at 2:48 PM
    #8165
    ktundra
    Lex
    NJ
    Bilstein 5100
    Snapped off bolt head
  6. Sep 27, 2020 at 3:01 PM
    #8166
    Festerw
    Festerw New Member
    Cambridge Springs, PA
    04 Tundra DC
    Invest in a set of left hand drill bits. I've had better luck with those than extractors.
    Lil Steve likes this.
  7. Sep 27, 2020 at 3:13 PM
    #8167
    Kongap
    Kongap New Member
    2004 SR5 DC
    Hahaha same bolt I snapped off! I drilled it out and used a bolt and nut
    ktundra[QUOTED] likes this.
  8. Sep 27, 2020 at 3:56 PM
    #8168
    ktundra
    Lex
    NJ
    Bilstein 5100
    I swear, these 10mm bolts are good for nothing, not much torque and snap!
    Given that this housing is plastic anyways, they should have just used a body screw/wood screw that goes directly into the plastic.
  9. Sep 27, 2020 at 4:04 PM
    #8169
    Kongap
    Kongap New Member
    2004 SR5 DC
    I blame the salt. i think I broke 3 bolts total during the new water pump install.look at dat rust
  10. Sep 27, 2020 at 4:13 PM
    #8170
    ktundra
    Lex
    NJ
    Bilstein 5100
    Are those from the timing belt covers? I'm afraid of of running into that when it comes time for me to change my timing belt/water pump. Very afraid.
  11. Sep 27, 2020 at 4:21 PM
    #8171
    Kongap
    Kongap New Member
    2004 SR5 DC
    That bolt was probably from the radiator. Thank jeebus the new radiator had new brackets.
    the bolts for the covers were fine for me. The cover mounting holes themselves didn’t fair too well however. I think the plastic had deteriorated over the many years of crazy temperature swings we have in Ohio. The metal sleeves were ok, the plastic around it, not so much.
    In hindsight, I should’ve salvaged some when I went to the junk yard looking for a skid plate but iirc they were worse off/destroyed or not a 2UZ-FE
  12. Sep 27, 2020 at 4:36 PM
    #8172
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
    I use these at work all the time. I have a set at the house.
    Link
    Here's where I tried using them on my frame.
    Lil Steve and ktundra[QUOTED] like this.
  13. Sep 27, 2020 at 5:02 PM
    #8173
    empty_lord
    Indiana, Chicagoland
    05 rollover special
  14. Sep 27, 2020 at 5:30 PM
    #8174
    NUDRAT
    NUDRAT [OP] 6 lug life
    SW CT
    Between 'Ridgelines'
    Did MB use a collapsing steering column in 1966? IIRC, they became mandatory in USA in 1967.
    1 headlight, no dash lights?
  15. Sep 27, 2020 at 5:32 PM
    #8175
    MrDirtjumper
    MrDirtjumper Ol’ dickhead
    Josh
    Slam Angelo, Texas
    06 DC TRD, 2wd to 4wd Conv.
    This one.
    bmf4069 and ktundra[QUOTED] like this.
  16. Sep 28, 2020 at 5:47 AM
    #8176
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
    Poked my eyes, and ears into 3rd gen territory. Talking about spending $125 on reverse lights.
    @Professional Hand Model, now would be an excellent time for that gif. You know the one.
  17. Sep 28, 2020 at 5:56 AM
    #8177
    Fred
    Hand Protectors
    Whoa! High Dolla!
    ktundra and Tundra2[QUOTED] like this.
  18. Sep 28, 2020 at 6:09 AM
    #8178
    That's an upgrade!
    Hell yeah! If you blow it right, it'll always release!
  19. Sep 28, 2020 at 6:10 AM
    #8179
    Seems a little backwards, worrying about reverse.
    Tundra2[QUOTED] likes this.
  20. Sep 28, 2020 at 6:11 AM
    #8180
    I mean we're talking about guys that trade in their 2018 TRD Pro's on the 2021 TRD Pro just so they can get the newest color. I need to figure out what all those guys do for a living. I'm still young enough to change careers. :D
    mtntop, TX-TRD1stGEN, CodyP and 5 others like this.
  21. Sep 28, 2020 at 6:23 AM
    #8181
    Yeah, but you should be able to get an Irwin set that's as good or better from any big box auto parts place, possibly hardware store.
  22. Sep 28, 2020 at 6:30 AM
    #8182
    PS - it's worth noting: You DO NOT want to skimp on bolt extractors. You will want penetrating lube. Drill deep, penetrating oil while hot, let it draw in as it cools, then back out slowly! The last thing on the planet you want to do is accidentally snap off one of those hardened-steel extractors inside the bolt you wanted to remove. If you do, you may as well call it a day and relinquish the fact you won't be getting that stub out again. Drilling out snapped-off hardened steel is an exercise in time and frustration you DO NOT want on your hands.
    PPS: It costs you nothing but 10 minutes time to heat up and pre-spray bolts like this with penetrator before removing. Can't recommend that enough if you're remotely concerned about snapping something off.
    I always thought Jakob Dylan was a dim bulb compared to his dad. And now, seeing this, I have 'One Headlight' stuck in my head.
    mtntop and bmf4069 like this.
  23. Sep 28, 2020 at 9:09 AM
    #8183
    I can't tell if I'm missing an inside joke, or there is another adjustment for the 06 headlights but any size screwdriver will work on my 02. The adjustment wheel is right on top.
  24. Sep 28, 2020 at 12:34 PM
    #8184
    rock climber
    rock climber New Member
    2001 Sequoia 4X4, 2000 AC 4X4
    Just a thought, the LED bulbs are dirt cheap and it's only a 15 minute swap. T10 green bulbs. I have some leftovers that I'll send you
  25. Sep 28, 2020 at 2:53 PM
    #8185
    SouthPaw
    SouthPaw The headlight guy
    2000 Limited 4x4 AC
    Careful as the adjustment wheels are 'designed' for certain size Phillip and they strip easy. I can't recall the exact size of the top of my head but I'll be the first to tell how easy they strip when you use the wrong one lol.
    mtntop likes this.
  26. Sep 28, 2020 at 2:54 PM
    #8186
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
    :spending:
    I would be inclined to say that most are in debt up to their eyeballs.
    "Oooooh, a new color. Yeah, let me trade this in. You'll give me 22k trade in? Ok, sign me up. I want that one."
    And then the dealership rolled the remaining balance owed on the previous truck onto the new truck, and yahoo will sign the paper anyways. Didn't do the math.
    I mean hell, I'm from Western Kentucky...
    I can still count all my teeth, just half of 'em are in my pocket.
    Voss, mtntop, Darkness and 6 others like this.
  27. Sep 28, 2020 at 4:09 PM
    #8187
    Pucks18
    Pucks18 Fleabit peanut monkey
    2001 Tundra 4x4 Limited trd
    They should be worried about paying off that 50k truck
  28. Sep 28, 2020 at 4:40 PM
    #8188
    ktundra
    Lex
    NJ
    Bilstein 5100
    I splurged at Harbor Freight, $5.99 includes the 24" flat blade, and Philips head.
    Seriously, half that length would have sufficed, but they didn't carry such a beast
    @FirstGenVol , my 06 Double Cab has a different headlamp. The vertical adjustment is down at the bottom of the lamp.
  29. Sep 28, 2020 at 5:12 PM
    #8189
    Fred
    Hand Protectors
    artsr2002 likes this.
  30. Sep 28, 2020 at 7:44 PM
    #8190
    NUDRAT
    SW CT
    I work in CT. CT gets snow, often & sometime plentiful. There's a guy at work, bought himself a Ram truck 4x4, lots of bling.
    Calls off every time there is snow. "I'm not going to drive my 50k$ truck in the snow." WTF? He's a teamster for Gawds sake....
    bmf4069 and ktundra like this.
