  1. Sep 27, 2020 at 2:04 PM
    Outbound
    Aaron
    Northern Alberta
    I'm not sure if they're different than Costco US batteries. Should be the same I'd think.
    Also, shit hell. I got one test start and then she won't start. On the charger it goes I guess.
  2. Sep 27, 2020 at 2:10 PM
    Kongap
    Kongap New Member
    2004 SR5 DC
    Oof new battery needing charged
  3. Sep 27, 2020 at 2:14 PM
    Voss
    Voss Dust in the wind
    Valod
    2003 AC TRD 4x4
    New light bar installed
    3D2A2DA5-B12B-466F-8167-BFCF26A332CB.jpg BA009AFD-8AFC-4B8A-A87A-DD60C5301E1A.jpg 3D2A2DA5-B12B-466F-8167-BFCF26A332CB.jpg
  4. Sep 27, 2020 at 2:20 PM
    Outbound
    Aaron
    Northern Alberta
    Son of a bitch. Swapped the old battery back in so i can at least get the truck out of the garage. Now it won't start. All I get is clicking...
  5. Sep 27, 2020 at 2:32 PM
    empty_lord
    Indiana, Chicagoland
    05 rollover special
    um... that very well might be the original battery
  6. Sep 27, 2020 at 2:32 PM
    empty_lord
    05 rollover special
    brand?
  7. Sep 27, 2020 at 2:38 PM
    Voss
    Valod
    2003 AC TRD 4x4
    Dss tuning. Got it on Amazon for $170. Curved 39” with Cree LED lights which I read is same LED manufacturer as the expensive light bars. Obviously won’t be same power but I’m not spending $1k on a light bar lol.
  8. Sep 27, 2020 at 2:38 PM
    Outbound
    Aaron
    Northern Alberta
    That's what I think. It'd not starting the truck anymore now either though.
    With the old battery and the new one, I get the interior lights on and the dash lights up. When I turn the key, all I get are clicks.
    My only ideas are the connector is pooched somehow or I have a fuse blown somewhere though I'm not sure where. I suppose somehow I fried the starter?? That seems unlikely though. I'm going to put the new battery back in, then try to jump start with the car.
    Here's the connector I'm concerned about.
  9. Sep 27, 2020 at 2:41 PM
    Festerw
    Festerw New Member
    Cambridge Springs, PA
    04 Tundra DC
    Yup doesn't look great. If that nut will loosen up clean up those connections too.
  10. Sep 27, 2020 at 2:51 PM
    Outbound
    Aaron
    Northern Alberta
    That's the best baking soda and water will do. It'll have to wait until I replace the whole works. Next spring, finances allowing I'm planning to dump a few grand into this truck to overhaul it. One of the things to do is replace any and all corroded connectors and cables.
    So the truck is running now. I put the new battery back in and The Woman came into the garage to see what I was swearing about. I went to show her how all I was getting were clicks and this time I got vroom. I have no idea. She says she's my good luck charm. For lack of a better explanation, I'm going with that.
    bmf4069 and Kongap like this.
  11. Sep 27, 2020 at 2:53 PM
    empty_lord
    05 rollover special
    uh, that defiantly needs a new terminal the whole bottom of it is gone...
  12. Sep 27, 2020 at 3:09 PM
    Kongap
    Kongap New Member
    2004 SR5 DC
    lol again
  13. Sep 27, 2020 at 3:16 PM
    Thrussn
    Thrussn Plastidip Hoe
    Gabe
    NM
    Silver 2005 4.7L 4WD Access Cab
    Bilstein 5100s, SickHIDs projector housings, Plastidip everything, TRD Pro style rims, LEDs everywhere, SUPERBUMP bumpstops. Firestone Riderite air bag springs, Deaver G57s, Onboard VIAIR system, Backup Camera, light bar behind the bumper, CGS catback, Exhaust cutout after cats, JBA Shorty headers, JBA Y-Pipe, pioneer deck, pioneer speakers, kicker 10" sub w/ amp, door sound deadening, Dirtydeeds 12 pin injectors, UniChip, Skid Row Skidplate, EZ Oil Drain valve (Better than Fumoto), Oil Catch Can, & 4WD Conversion
    Spent the weekend in the mountains. Went through some really cool stuff and got to actually test out my 4wd. Compared to before the conversion, it's insane where I can go now!
  14. Sep 27, 2020 at 3:16 PM
    Outbound
    Aaron
    Northern Alberta
    Yup, it definitely does. I need to figure out how to do it though. The one that's on there now is crimped on, so I'll have to work out how to take it off. I don't have enough excess cable to cut the old one off and install a new one unless there's a way to splice more cable in.
    bmf4069, NUDRAT and Kongap like this.
  15. Sep 27, 2020 at 3:18 PM
    Casper421
    In the woods
    06 DC
    Nice, glad the conversion went well! What part of NM is that?
    Thrussn[QUOTED] likes this.
  16. Sep 27, 2020 at 3:21 PM
    Thrussn
    Gabe
    NM
    It's actually the La Plata mountains in Colorado. It's definitely one of my favorite places to disappear to.
    Darkness and theblurry1 like this.
  17. Sep 27, 2020 at 3:26 PM
    You're going to wait until spring to fix that? I wouldn't go anywhere remote. You might get stranded.
    speedtre likes this.
  18. Sep 27, 2020 at 3:35 PM
    Outbound
    Aaron
    Northern Alberta
    The nut and the smaller connectors on top will be done in spring. I'm going to figure out the main battery terminal connector ASAP.
  19. Sep 27, 2020 at 4:50 PM
    Professional Hand Model
    Fred
    Hand Protectors
    We shall Enshrine it.
  20. Sep 27, 2020 at 4:55 PM
    Fred
    Hand Protectors
    Darkness and Kongap like this.
  21. Sep 27, 2020 at 5:01 PM
    empty_lord
    05 rollover special
    It shouldn’t be crimped. The positive terminal should be bolted on to the crimped end. Toyota sells the new terminal for cheap.
  22. Sep 27, 2020 at 5:05 PM
    Outbound
    Aaron
    Northern Alberta
    Looking at it again, it appears you're right. I'll swing into Toyota tomorrow and snag a new one.
  23. Sep 27, 2020 at 5:23 PM
    Fred
    Hand Protectors
    Yeah boyz. Long day under the hood. Got her torn down, while cleaning up all the parts along the way, and started some put back. Cam Seals and Crank Seals are in place along with the Water Pump.
    Should be a good start to the day tomorrow as it seems all the proper parts are with me and nothing was busted in shake down. Glad I bought a Pulley Removal Tool along with the Cam Holding/Crank Pulley Holder. Valuable to have!
    Momba took care of business on the Crank Bolts and Cam Bolts easily.
    Most of my time was spent cleaning everything so when its time for put back no time is wasted. Key is bagging all your bolts/nuts per part an labeling so you know where everything goes back. The amount of bolts and parts could be overwhelming if you aren’t meticulous.
    Looks like my Oil Pump Seal is the Genesis of the weep showing at the oil pan. I snugged those bolts a hair on the oil pump cover (5 bolts in total) and ran a bead of FIPG 103 over the top mating surface. If she wants to bubble up hopefully the sealer will push the weep down toward the sides of the engine. Hoping that just the bolts snugging does the trick. Sure beats pulling the engine for a 50 cent O-Ring.
    Lots of work and nothing sexy about it, but here are a few pictures.
  24. Sep 27, 2020 at 7:07 PM
    empty_lord
    05 rollover special
    your cam seals are so much easier. lol
    [​IMG] [​IMG]
  25. Sep 27, 2020 at 10:20 PM
    theblurry1
    theblurry1 ~
    Castle Rock, CO
    2001 Thunder Grey Tundra AC Limited 4x4 V8
    (Camper conversion underway.) Rebuilt engine w/265K miles, A.R.E. camper shell (w/cab pass-through, rooftop fan, and side windows delete), bedlinered steel ladder rack (w/wooden rooftop deck and hammock mount), all LED lights (red dash, 4" side floods, 32" rear bar), Android head unit, 1.5" lift from Bilstein 5100 struts, 32" DuraTrac tires on factory rims, 1.5" wheel spacers, Moog suspension parts, SuperSprings leaf kit, diff drop, Reese trailer brake control, GoRhino Hitch Step, debadged, F-150 rear bumper, Sequoia center console unit upgrade, partial rear bench seat delete, dashcam, aftermarket speakers, 50% sound deadening coverage, custom tools unit.
    Made the cushions/mattress for my bed bench seat unit. The bed is super cozy and the shell is starting to actually feel like a camper in there.
    I don't know how to sew and I don't have a wife, so I came up with a solution that will still let the mattress breathe to prevent mold.
    First step was to cut the 3" mattress down to length/width as my camper bed is ever so slightly smaller than a twin.
    The one I chose features a 2" regular foam base with 1" of some kind of gel foam on top. An electric bread carving knife made super clean cuts that might've even impressed @Professional Hand Model.
    I cut a 2.5" frame out of 1/8" plywood to staple the fabric to. While ideally removable cushion covers could have simply be sewn to fit the foam, this project was dragging out and I needed the bed done.
    Spray adhesive helps hold the plywood to the foam. I cut that frame freehand, by the way!
    Next, I wrapped the cover around the mattress to meet the frame. I love the modern grey color with white stitching to reference my white interior.
    Uniform folds on the corners (I'm sure I could have cut it square, but I didn't want waste $40 of fabric if I botched).
    Lastly, I put another sheet of lighter, basic fabric over the bottom for a finished look. No pic available.
    I am a huge fan of how these cushions turned out. Just need to add Velcro because they will definitely not stay put while offroading.
    Trailscape, imDementeD, Voss and 14 others like this.
  26. Sep 28, 2020 at 5:25 AM
    Fred
    Hand Protectors
    And I’m not sad about that!:rofl:
    I worn out by the point of getting to the cams. The replacement of them is easy. I punched a small hole and made it bigger. Used some 90° needle nose jabbed in the hole as leverage with the cover lip and pried them. On the crank seal, I punched down in at 45° with a sharp knife at the lip and pry/popped that thing off.
    Pretty stoked on the challenge so far. Interesting note: the pass side cam seal port had some clogs in the little weep holes compared to the drivers side. Looked like little bits of excess sealer squeezings. I used my Krentist Tool and removed.
  27. Sep 28, 2020 at 5:41 AM
    lsaami
    lsaami Let ‘er buck
    Minnesota
    2000 Tundra 4x4 "$1100 Build"
    Realized I missed your comment
    my research has shown that because of the tight center block, they are actually well-behaved and quiet like and all-terrain on the highway when they're aired up. Time will tell. They're heavy suckers at about 64lbs a tire
  28. Sep 28, 2020 at 5:44 AM
    Fred
    Hand Protectors
    Wow! My Michelins are 53lbs each. I believe the stock tires P-Rated are around 45lbs each for comparison.
    NUDRAT and lsaami[QUOTED] like this.
  29. Sep 28, 2020 at 6:46 AM
    empty_lord
    05 rollover special
    Mine are 78 lbs without the wheels :anonymous:
    FrenchToasty and bmf4069 like this.
  30. Sep 28, 2020 at 7:16 AM
    chrisb
    chrisb scumbag
    noblesville, IN
    06 AC 4x4
    long time, no see.
    Yesterday, I put some leaf spring clamps/straps on the Tundra to mitigate axle-wrap.
    The short test-drive I took feels like it's all gone. No packing the driveshaft with grease. No thunk when accelerating from a stop.
    I'll know better when I next take the Tundra to work.
