Best hose nozzle?
Discussion in 'Detailing' started by jclaffee, Jul 28, 2020.
  1. Jul 28, 2020 at 1:35 PM
    jclaffee
    jclaffee [OP] New Member
    Durango, CO
    What is your fav hose nozzle for washing vehicles? I've tried a bunch. They typically self destruct, or have crappy spray patterns. The one I'm currently using is brass, and even it is about to come apart. (And I managed to create a big paint chip with it recently by being a dumba$$). Watcha got?
    YardBird likes this.
  2. Jul 28, 2020 at 3:34 PM
    Hvactech24
    Hvactech24 MGM
    Kentucky
    2013 Rock warrior double cab
    2-1/2” front leveling kit, spider trex wheel spacers, line-x bed liner, change all lights over to led bulbs interior, exterior, and headlights. All bulbs are from headlight revolutions, RCI skid plates. RCI running boards
    0603D854-0DFC-4F88-AAA7-84F296A6E0BD.jpgI have been using these for years, they last for ever have all kinds of pressure, and you can change what kind of flow rate you want from a main stream to flared out I guess they’re great I really like it. Best place to get Them these days is the Home Depot you can get it shipped to the store for free and that’s the cheapest place that I have found them
    Pro Large Firemans Nozzle
    https://www.homedepot.com/p/206057093
  3. Jul 28, 2020 at 5:40 PM
    YardBird
    YardBird Native San Diegan
    Jonesy
    2005 RCLB
    https://www.lowes.com/pd/Orbit-Max-8-Pattern-Nozzle/1000188693
    Every manufacturer has a similar nozzle for use with a garden hose. I'm 'queer' for this type of nozzle because it has a thumb control for 'on and off' and a multi-pattern spray capability.
    But, just as you mentioned, these things aren't built especially well and may only last a short time. I've gone through a bunch of them myself.
    I may have to break down and buy the Fireman's Nozzle, too.
  4. Jul 28, 2020 at 5:55 PM
    jclaffee
    Durango, CO
    Ok, I haven't tried one of these monsters, do I'm going in!
  5. Sep 24, 2020 at 1:39 PM
    DIYDad
    DIYDad New Member
    2020 Tundra 1794
    I use a similar nozzle. Great for blasting grime off the paint before soaping up. However, I like high volume, low pressure for rinsing so I pop off the nozzle and just use the hose wide open.
    I recently discovered these quick disconnects from Eley. They are fantastic & huge. Full 3/4 ID, so they do not restrict flow. O-rings, so they don't leak. with 65lbs of pressure at the tap, and 3/4 hose and fittings, and a nozzle similar to the one pictured above, I can soak my kids from a full 55' away. They can run to the other side of the street, but they can't get away.:rofl:
    https://www.eleyhosereels.com/products/garden-hose-quick-connect-system
  6. Sep 25, 2020 at 3:37 AM
    War Machine
    War Machine SSEM # 5 3MW
    Outside of a pressure washer, this is the way to go.
    ToyoMafia likes this.
  7. Sep 25, 2020 at 4:01 AM
    Haggis777
    Haggis777 I.L.J.C.M.L.
    SW Michigan
    2015 Silver SR5 TRD Tundra Canadian Model
    LEDs interior & exterior, stubby antenna, Bak-Flip cover, 285's, AGM battery, block heater, Pine tree air freshener
    Screenshot_20200925-070129~2.jpg One thing I have connected to my hose sprayer is this shut off.
    SOOOO much more convenient than having to run back to the spigot and shut the water off there. Handy for when I need to remove the sprayer in order to hook up the hose directly to my riding mower deck wash.
    Spend a few extra bucks and forgo the plastic ones and go brass. I have found these last MUCH longer.
    https://smile.amazon.com/dp/B07D3SY4DH/ref=cm_sw_r_cp_apa_i_VZCBFbKQEQ5AQ
    Ted4311 likes this.
  8. Sep 25, 2020 at 4:06 AM
    18" TRD Off Road Wheels
    Guess I'm the only cheap ass here, then?
  9. Sep 25, 2020 at 4:17 AM
    Rex Kramer
    Rex Kramer Vinyl Spinner
    Georgia
  10. Sep 25, 2020 at 4:27 AM
    TH1776
    TH1776 New Member
    FL
    040 PRO
    I have a couple of these and love them for when I need good pressure and flow but don't particularly care for them when washing my trucks because of needing two hands to operate. I do have two hands but, find it more convenient for an old school one handed nozzle with the truck washing.
    It is difficult finding good quality ones though.
  11. Sep 25, 2020 at 5:11 AM
    ToyoMafia
    Magic carpet.
    Cool slaps and plastiDip
    I stay away from brass or metal ones at all times. One slip up can turn into a bad day. I prefer the firehose nozzles.
