Help with fog lights
Discussion in '2.5 Gen Tundras (2014-2021)' started by tehans, Sep 24, 2020.
  1. Sep 24, 2020 at 7:28 AM
    tehans
    tehans [OP] New Member
    I have a 2014 I got used, appears to be stock light bulbs. Checked the fuse in the engine compartment, relay both are good, no voltage to the connector at the bulb. Bulb seems good measures like 6 ohm resistance. Any idea? is there another fuse inside the cab? if so where is it located? Thanks in advance.
  2. Sep 24, 2020 at 10:16 AM
    tehans
    That was it, thanks. Is there a mod where they can be on when the headlights are off? Is there a good aftermarket LED light that is yellow and has some side projection into the ditch but still good forward beams?
    NewImprovedRon likes this.
  3. Sep 24, 2020 at 10:20 AM
    MSU Tundra
    MSU Tundra Numerous rodeos experienced
    Mississippi
    2017 Tundra and 2013 LC200
    Check these out. I have them and they're an easy install and have good side projection.
    https://www.diodedynamics.com/ss3-led-fog-light-kit-for-2014-2020-toyota-tundra.html
    I believe there is a mod that allows you to turn them on anytime...try the search function to find it.
  4. Sep 24, 2020 at 10:26 AM
    AZBoatHauler
    So.Arizona
