Tranny return question
Discussion in 'General Tundra Discussion' started by DerekS, Sep 23, 2020.
  1. Sep 23, 2020 at 8:08 AM
    DerekS
    DerekS [OP] New Member
    DerekS
    Orlando, FL
    White Tundra XSP-X 5.7L
    Xtang trifold hard cover, K&N Air filter
    image.jpg Anyone know which line is the return here?
  2. Sep 23, 2020 at 8:19 PM
    SuperWhite20
    SuperWhite20 New Member
    Robert
    Georgetown TX
    2020 Tundra Crewmax SR5 4X4
    TRD Sway bar. Deck Rails, Maxliner rear floor mat, Driver side grab handle. Dee Zee bed mat
    Disconnect both lines coming from the transmission. Put the hoses in a glass jar. Have someone just crank the engine but shut it off right away! The one not spraying fluid is the return line.
  3. Sep 23, 2020 at 8:29 PM
    Coffee*8)
    Coffee*8) New Member
    Pennsylvania
    2020 Tundra Crew Max
    + Trans cooler
    Drive it for a while until it warms up. Then feel both lines, the hot one is the feed, the cold one is the return.
    You could also trace the hoses back to the thermostat on the transmission. The top straight barb is out. The bottom bent barb is in.
    SuperWhite20 likes this.
  4. Sep 24, 2020 at 3:41 AM
    DerekS
    DerekS
    Orlando, FL
    Awesome thank you
  5. Sep 24, 2020 at 3:44 AM
    timsp8
    NY
    My top one in the engine bay gets hot first, but they cross over each other a couple of times.
  6. Sep 24, 2020 at 5:03 AM
    JohnLakeman
    Outside of Weird, TX
    2017 MGM DC TSS 4.6L
    The suggestion by @SuperWhite20 is the surest method. Observation by @timsp8 matches my best "guess" from Toyota parts drawings, but seems counter-intuitive to me.
    Let us know what you determine. :thumbsup:
    SuperWhite20 and timsp8 like this.
