2020 TSS questions before lift
Discussion in '2.5 Gen Tundras (2014-2021)' started by Tundra234, Sep 22, 2020.
  1. Sep 22, 2020 at 6:22 PM
    Tundra234 [OP] New Member
    Coming from a 2nd gen to a 2020, I am new to the whole TSS system. I will be installing my Toytec Alumas and shackles in a few days. Will I have any issues or have to do anything with the TSS? Also, when I move my wheels over,, will I need to take it somewhere to have the sensors programmed? I have an older version of the Techstream software and cable but I have a Windows 10 laptop so I haven't used it in a few years. Thanks.
  2. Sep 22, 2020 at 6:26 PM
    Blueknights75
    Ron
    Clayton, NC
    You may or may not have an issue with the TSS. Some have had issues as well as warranty issues because of the lift causing the issue. I went top setting on 5100 Billstein on front to level and my TSS system still functions perfect.
    When I changed my SR5 wheels to PRO I just had the sensors moved over to the new wheels with no issues.
  3. Sep 22, 2020 at 6:31 PM
    I wouldn't think a 3/2 lift would cause any issues but I'm new to the 3rd gen. The wheels are the wheel and tire package from my 2013.
  4. Sep 22, 2020 at 7:11 PM
    Yoder18
    Yoder18 Veteran underwater basket weaver
    Mitch
    Front range Colorado
    18 tundra trd off-road
    •Toytec Radflo 3” with 1.5 shackles •+25mm icon rebound wheels matte black. •Prox15 tonneau/Softtopper •315/70r17 ridge grapplers •Wheelers front bumper stops •Spray in bed liner •Vleds floorwell leds front and back and interior led kit •Boss front bumper spacer •First choice fabrication welded sliders •8” ss dirty deeds exhaust •Tech12volts remote start with carlink •Vleds front turn signals leds •AFE pro dry s air filter •Baja xl sport amber fogs •Victory 4x4 strike bumper w hoop •Ajt designs chrome delete for vent rings and cup holder/gear shifter (black) •Wet okole seat covers •Husky floor liners •RCI skid plate and transmission skid •Jomax SpEed sensor guards •Rear diff breather location mod
    Shouldn’t man I’ve got the radflos on 3” and 1.5 Toytec shackles in the back and I haven’t had an issue at all. Finally bit the bullet on the third gen lol congrats man!
  5. Sep 22, 2020 at 7:12 PM
    Danman34
    Danman34 New Member
    Danny
    2018 White Tundra TRD Sport
    Shouldn’t have any issues with the sensors. Going 3/2 keeps a little rake and that tends to keep the sensors happy.
    You won’t be able to simply put the current wheels on the new truck without swapping sensors. The 20’ tpms sensor are model year specific. So your existing sensors will not work in the new truck. You’ll need to swap your oems into them.
  6. Sep 23, 2020 at 12:27 PM
    tundra4466
    tundra4466 New Member
    2020 1794 4x4
    I just went from an 11 to a 2020 and have the Aluma lift with 1.5” shackles on the way so I’ll find out with you. They said the coilovers are preset at 2.5” lift so I’ll probably leave them as is and see how it does with a 1” rake unless I can find 2” shackles or add a 1/2” block in the back I’ll jack them up to the 3”.
    From everyone I’ve talked too there’s no rhyme or reason to the tss issues it’s just 50/50 if it happens or not on each truck.
  7. Sep 23, 2020 at 12:32 PM
    Mine were preset at 3". :notsure:
  8. Sep 23, 2020 at 12:33 PM
    tundra4466
    2020 1794 4x4
    Maybe they lied to me.. my last set was at 3”.
