Tire & Wheel setup for 2021
Discussion in '2.5 Gen Tundras (2014-2021)' started by phurls8, Sep 23, 2020.
  1. Sep 23, 2020 at 4:50 AM
    phurls8
    phurls8 [OP] New Member
    I know this has been generally covered on previous posts, so forgive me for the repetition. I'm buying a 2021 Tundra and want to mount 295/70R18's. I plan on using a 2" leveling kit but will use a lift kit if necessary.
    My question: Will 295/70R18's fit with a 2" leveling kit using the stock 18" wheels with 60mm offset?
    In some threads, "trimming" was mentioned based on certain configurations. What would this entail?
    I found a wheel I like with a 25mm offset and would consider using if the tire rubs with the setup mention above. I used the offset calculator and the results are below.
    Thoughts or comments would be appreciated.
  2. Sep 23, 2020 at 4:57 AM
    timsp8
    NY
