Are these rotors worth buying? Stoptech Sportstop Drilled Rotor
Discussion in '1st Gen Tundras (2000-2006)' started by MartyE12345, Sep 16, 2020.
  1. Sep 16, 2020 at 7:00 AM
    MartyE12345
    MartyE12345 [OP] New Member
    Martin
    2000 Toyota Tundra SR5 Access Cab
  2. Sep 16, 2020 at 11:40 AM
    Drilled/slotted will bring up debate. I'm of the opinion that they belong on the track, and serve no purpose on a truck. If your brakes haven't been upgraded to the 13WLs yet, then I'd get this kit. I have it on mine, as do a few others.
  3. Sep 16, 2020 at 11:46 AM
    King R 808
    King R 808 New Member
    2020 White Tundra TRD Pro
    TRD Big Brake Kit.
  4. Sep 16, 2020 at 12:02 PM
    Darkness
    Darkness Allergic to white
    Luis
    All over SoCal
    The darkest
    It's really dark
    @bmf4069 :rofl:
    Big brakes on a first gen are upwards of $2k and their benefit is questionable.
    I would go with Brembo blanks or something similar. I'm with BMF on this, drilled brakes have less area for the pad to bite on and won't benefit a daily driving truck. Same goes for slotted. Just don't go cheap and any plain rotor will do.
    ventorph, deptrai, bmf4069 and 4 others like this.
  5. Sep 21, 2020 at 12:16 PM
    HiMiler
    HiMiler New Member
    Spencer, MA
    ‘05 Double cab Tundra
    I bought the Stoptech kit (drilled/slotted rotors and pads) from TireRack and have almost 100k on them. Not a squeak, shimmy or speck of dust anywhere! I do mostly highway miles and know that the slots and holes are largely for show, but this was a good buy. If you’re looking for more braking, you’ll need more than this kit, however.
  6. Sep 21, 2020 at 7:35 PM
    Surf_spear_Mex
    Surf_spear_Mex New Member
    Patrick
    05 tundra ac
    Power stop z36 extreme are pretty damn nice and can be had for $180 for the full kit on amazoooo
  7. Sep 21, 2020 at 7:54 PM
    Johnsonman
    Johnsonman New Member
    Austin
    Sequoia
    Yes - drilled rotors will be Felt by your feet. I mean just that, when depressing the brakes, especially medium to hard, you will feel the holes. Not hear them just feel them not to be as smooth as regular or slotted rotors.
    I like slotted because they help disperse water better than not having slots. Drilled are for better cooling. If you can find angled vane rotors, those are best at cooling because the angled vanes grab the air and funnel it thru to the center. I found those from Centric. Otherwise seem like a good deal.
  8. Sep 21, 2020 at 8:02 PM
    shackleford rusty
    shackleford rusty New Member
    TEXAS!
    ^^this^^
    consider frozen rotors; will be installing these on the tundra as soon as factory brakes are done.
    had an '05 titan with rotors that belonged on a sentra... warped... warped again... replaced with frozen rotors. they are cryogenically frozen and this is no gimmick. mixed those with some green box hawk pads. i drove the pickup like i stole it, and those rotors would NOT warp.
    currently own a '19 cm limited tundra. these are the best factory brakes i've ever had on a 1/2 ton pickup.
    when these pads go, the whole setup will be replaced with power slot frozen rotors and green box hawks.
    NickDPT likes this.
  9. Sep 22, 2020 at 5:02 AM
    ktundra
    ktundra rust be damned
    Lex
    NJ
    06 Tundra DC Limited 4WD
    Bilstein 5100
    Am I reading that right? A set of new rotors, and calipers, *and* brake pads, for just $206? Seems like a sweet deal.
  10. Sep 22, 2020 at 10:52 AM
    Yup. That's why we get it. Helluva deal.
    yoshi82, Darkness and ktundra[QUOTED] like this.
  11. Sep 22, 2020 at 7:07 PM
    Lil Steve
    Lil Steve Living the dream
    Gilbert, AZ
    Don't forget to factor in the almost $70 core charge. Shipping the cores back is on your dime so after that's all done the total will probably be around $250. Still a good price for the kit, and in my case of having the WE calipers this WL kit will be an upgrade. I believe you already have WL's on the 06. Oh, and Rock Auto is currently out of stock on this particular kit.
    ktundra[QUOTED] and Darkness like this.
  12. Sep 22, 2020 at 7:10 PM
    CodyP
    CodyP Such a n00b
    Cody
    CDA, ID
    2006 Tundra 4x4 DC
    just because they are slotted or cross-drilled doesn’t mean they will be better than stock blanks. Give me a few minutes to find the supporting video and testing if you guys really wanna nerd out on brake pads and rotors.
    Here's one for brake pads
    https://www.youtube.com/watch?v=DZ8O2tJOGLE&t=251s
    yoshi82, Kongap, Jerry311SD and 3 others like this.
  13. Sep 22, 2020 at 7:26 PM
    Surf_spear_Mex
    Patrick
    05 tundra ac
    Drilled/slotted look good and add 12hp atleast...
    I have the z36, I tow a lot. They are excellent, smooth as oem but much more powerful in the braking sense. I added stainless stop tech lines and the pedal feel firm and assuring with 5-6k pounds out back.
    ktundra, Darkness and Mountun Goat like this.
  14. Sep 23, 2020 at 6:55 AM
    Professional Hand Model
    Fred
    Hand Protectors
    Excellent video.
    ktundra likes this.
  15. Sep 23, 2020 at 7:32 AM
    CodyP
    CodyP Such a n00b
    Cody
    CDA, ID
    2006 Tundra 4x4 DC
    I really thought it was. Give a bit more insight into OE parts and why sometimes it's not worth venturing out from them.
  16. Sep 23, 2020 at 8:37 AM
    sunnysideTRD
    sunnysideTRD New Member
    Sunny
    2019 Tundra TRD Pro Voodoo Blue
    Standard 2019 TRD Pro but will be a project car and add as I go
    This is a great thread. Thanks for the write up, learned a lot.
    ktundra likes this.
  17. Sep 23, 2020 at 9:53 AM
    ccdawnpatrol
    ccdawnpatrol New Member
    Salt Lake City, UT
    2017 SR5 MGM CM 4x4 5.7L
    So I have a 17' SR5 with 32k on them and just noticed a shutter/shake when towing/braking hard mainly on downhills or some highway speeds when weighted down. Does anyone have any advice on how to check and see if the rotors are warped or if new brake pads are needed? I have always wanted to get a bigger set up since we tow both a boat and camper for a good portion of the year. Thanks for any help/advice.
    @bmf4069 , did you do a self install on that set you mentioned above? How have they been working for you? I figure that since I am looking at some Falken AT3W's then getting both tires and brake done at the same time would save some money and time, no rush though.
  18. Sep 23, 2020 at 10:06 AM
    Surf_spear_Mex
    Patrick
    05 tundra ac
    If there's shudder or vibes when braking it's time for new rotors. The z36 mentioned before are your best bet for extreme duty and towing imo
    bmf4069 and ccdawnpatrol[QUOTED] like this.
  19. Sep 23, 2020 at 10:45 AM
    I did, but with mine being older I did that set to get the bigger calipers and rotors off of 03-06 tundras. You should be fine with a standard rotor/pad swap. I wanna say stoptech makes a kit that doesn't need new calipers.
    Brakes are super easy to do yourself and are a great way to ease in to working on your own stuff if you're so inclined. And yeah, @Surf_spear_Mex is on point with his diagnosis.
    Darkness likes this.
  20. Sep 23, 2020 at 11:08 AM
    Darkness
    Luis
    All over SoCal
    The darkest
    It's really dark
    @bmf4069 being awfully nice to the turd gen crowd this month. Is this a new leaf?
    bmf4069 likes this.
  21. Sep 23, 2020 at 1:45 PM
    Lil Steve
    Gilbert, AZ
  22. Sep 23, 2020 at 6:34 PM
    I dunno, I was asked specifically about an issue, so I figured I'd help. Jokes on @ccdawnpatrol though, seeing how I break everything I try and fix. :D
  23. Sep 24, 2020 at 5:46 AM
    Fred
    Hand Protectors
    I just went through about 300 photos in my album to clean up some space. Many of those were screen grabs of your brake work which I copied so feel a little better about knowing that you’ve been helpful here. I also used your axle bearing pics to learn about undoing the shit work these goofy mechanics did on mine.
    I think the only thing you messed up was the valve cover job and then disappeared for a few months. :rofl:
    bmf4069[QUOTED] and ktundra like this.
  24. Sep 24, 2020 at 7:17 AM
    ccdawnpatrol
    Salt Lake City, UT
    THis the product your purchased? https://www.amazon.com/Power-Stop-K...208966530901&ref_=sbx_be_s_sparkle_mcd_asin_1
  25. Sep 24, 2020 at 10:39 AM
    Lil Steve
    Gilbert, AZ
  26. Sep 24, 2020 at 11:18 AM
    Yeah, I was pissed off at that one and had to throw a little hissy fit. We'll see what happens with my upcoming jobs this fall....
  27. Oct 1, 2020 at 7:13 AM
    Surf_spear_Mex
    Patrick
    05 tundra ac
    This one bud
    ccdawnpatrol likes this.
  28. Oct 1, 2020 at 8:20 AM
    If you're gonna upgrade brakes I would go all out and move up to the GX460 calipers and rotors. Go big or go home.
  29. Oct 1, 2020 at 9:39 AM
    fighthedude
    fighthedude New Member
    I am looking at brakes as well... i have an 06 double cab. What year gx460 do i need to get? Any thread on this?
  30. Oct 1, 2020 at 10:00 AM
    Fred
    Hand Protectors
    Yeah. All new master cylinder, booster (sized proper), and brand new calipers with Toyota Pads. Do it all right at the same time. :yes:
