Anyone running 285/65r20 on factory 20" wheels?
Discussion in 'Wheels & Tires' started by PRO19, Sep 7, 2020.
  1. Sep 7, 2020 at 9:34 PM
    PRO19
    PRO19 [OP] New Member
    Sam
    2020 TRD Sport 4x4
    Stock for now
    I have a TRD Sport with factory 20's that I plan on doing some 285/65r20's on. Is anyone here running this combo? If so any rubbing? Would love to see some photos!!
    Brettstation37 likes this.
  2. Sep 8, 2020 at 12:59 PM
    2019-1794 New Member
    2019 1794 Crew Max 4x4
    Had that size before my new tires and wheels, you'll need at least a level and take off the front mud spats and bend the skid plate out of the way to clear those with no rub.
    Brettstation37 and PRO19[OP] like this.
  3. Sep 8, 2020 at 5:14 PM
    Ron-O
    Ron-O New Member
    Ron
    Just had them put on tonight. 285/65r2020200908_175037.jpg
  4. Sep 8, 2020 at 5:17 PM
    Brettstation37
    Brettstation37 New Member
    Brett
    Catskills NY
    2020 Tundra CrewMax TRD Sport
    Good needed info, I was told for my 2020 sport with 3” level 1” block in rear that only a 275/65/20 would fit...
  5. Sep 8, 2020 at 5:18 PM
    Ron-O
    Ron-O New Member
    Ron
    Took the front splats off, bent the skid plate. Minor rub on the swaybar but not until full lock. So far so good. And still fits in the garage!
    PRO19[OP] and 2019-1794 like this.
  6. Sep 8, 2020 at 5:20 PM
    I like that look a lot, nice and clean.
    PRO19[OP] likes this.
  7. Sep 8, 2020 at 7:34 PM
    PRO19
    Sam
    2020 TRD Sport 4x4
    Stock for now
    Looks great. What is your suspension specs? any rubbing?
  8. Sep 9, 2020 at 4:51 AM
    Ron-O
    Ron-O New Member
    Ron
    Boss Offroad level kit, 6112s at top setting (2 shims drivers side, 1 passenger side), 5100s on rear with 1.5 shackles. Stock UCAs. Bent skid plate to remove rub but still need to bend a little more or just trim it. Might have a little rub on the mudflap but a heat gun will cure it. Haven't had a chance to really dig into anything until this weekend.
  9. Sep 9, 2020 at 10:18 AM
    I think this is an underrated tire size for these wheels, amazed I don’t see more setups like it.
    Medic343 and PRO19[OP] like this.
  10. Sep 9, 2020 at 10:28 AM
    Ron-O
    Ron-O New Member
    Ron
    I think the biggest issue if the $50 jump in price. I only lucked out finding a local place selling them to me at $340 each mounted and balanced. 275/65r20 were $290.
  11. Sep 9, 2020 at 10:31 AM
    I think they both look good on that wheel, the 285 wins out slightly because that little bit of extra width is noticeable and the weight difference in the two sizes is only a few pounds I think.
  12. Sep 11, 2020 at 5:21 PM
    Remy18
    Remy18 New Member
    Jon
    2016 Black Platinum Tundra
    3”lift 285/65/20
    986DFA53-CDD7-421C-9C3A-DD63F19289C0.jpg I’ve had 285/65/20’s on for 3 years now, only down fall is limited tires and high prices.
  13. Sep 14, 2020 at 2:07 PM
    GaFFLe
    GaFFLe New Member
    Atlanta, GA
    2020 Toyota Tundra Platinum
    Undercover bed sway cases
    What step is that and is it made in all black?
  14. Sep 15, 2020 at 1:42 PM
    Remy18
    Remy18 New Member
    Jon
    3”lift 285/65/20
    Toyota steps, came with truck
  15. Sep 15, 2020 at 1:48 PM
    Northern Toyota
    Northern Toyota New Member
    2023 Tundra TRD Off Road, 2022 Tacoma TRD off road premium
    Tires and bilstein
    My 2020 sport fits that size just fine, all stock
  16. Sep 22, 2020 at 5:53 AM
    attillatundra
    attillatundra New Member
    That is great to hear. Can you post some pics?
  17. Sep 22, 2020 at 9:52 AM
    Northern Toyota
    Tires and bilstein
    Here's two
  18. Apr 16, 2021 at 10:57 AM
    LAPlatinum
    LAPlatinum New Member
    I know this thread is old but wanted to ask are you running stock uca, any issues on clearance. Are you also using wheel spacers?
  19. Dec 25, 2024 at 1:04 PM
    Oz_zy
    Oz_zy Member
    2016 magnetic grey tundra tss off-road
    Morimoto headlights+tailights +3rd brake light Morimoto xb led fog light Db custom tundra grill with led 3 inch lift with elka 2.5 ifp suspension with bds uca. Jba lth with full 3 inch midpipes w/factory cats along with full 3 inch true dual stainless steel exhaust with x pipe with 2 corsa pro series mufflers And s&b intake
    How do you like the discover at3 xlt?
    Ive been looking at these and can't decide. Stuck between these, mickey thompsan baja at or toyo at3
