Tundra 200k Mark
Discussion in '2nd Gen Tundras (2007-2013)' started by Kokok67, Sep 21, 2020.
  1. Sep 21, 2020 at 1:35 PM
    Kokok67
    Kokok67 [OP] New Member
    2007 tundra
    Hi folks. Asking for help. My 2007 4.7 Tundra just hit the 200k mark and these issues start popping up:
    VSC - flashing
    skid light - on
    ABS light - on,
    engine light - on.
    brake light on my tail lights turn/remain on (soon as my ignition is on).
    Codes showing are:
    C1201 - (1) Brake boost sensor circuit range/ performance, (2) Engine control system
    P0724 - (1) Brake switch B input circuit High
    What I have done so far and all checked good:
    - changed/adjusted the brake light switch
    - changed both tail/brake lights
    - checked for short using test light and pulled all fuses one at a time
    - checked for bad fuses
    I'm just a weekend mechanic and my knowledge/capabilities ended here. Please help on what else I could do. This truck is my work truck and I don't have the funding to pay a mechanic. Have any of you folks had this issues? Thanks.
  2. Sep 21, 2020 at 7:45 PM
    Filthyphil
    Filthyphil Lions Not Sheep
    Phil
    2000 Toyota Tundra TRD 4.7
  3. Sep 21, 2020 at 7:48 PM
    timsp8
    NY
    Not my chart but might help.
    mtndds98 likes this.
  4. Sep 22, 2020 at 9:03 AM
    blackdemon_tt
    blackdemon_tt Battery Slayer
    Brake switch may have gone bad, check your battery terminals and clamps, ensure they're clean.
    Tierhog likes this.
  5. Sep 22, 2020 at 9:12 AM
    TheBeast
    TheBeast The Beach
    check ABS wheel sensors
