Unknown plug
Discussion in '2.5 Gen Tundras (2014-2021)' started by Barrel85, Sep 21, 2020.
  1. Sep 21, 2020 at 12:09 AM
    Barrel85
    Barrel85 [OP] New Member
    William
    2018 Black Tundra TRD
    6A9360EC-F837-4E62-A805-A72ADE0C96E3.jpg 26607AAE-716A-4876-9EE5-5C6A726F4230.jpg Can anyone tell me what is the blank used for next to driver side 12v charger? I removed this blank to use as a light bar switch location and found a plug in the back of the blank.
  2. Sep 21, 2020 at 12:14 AM
    18" TRD Off Road Wheels
    Glass break sensor if equipped.
  3. Sep 21, 2020 at 12:18 AM
    Barrel85
    William
    Thanks for the quick response!
  4. Sep 21, 2020 at 12:20 AM
    Barrel85
    William
    Do you happen to know if I can get a oem style switch to fit this to use for a light bar?
  5. Sep 21, 2020 at 12:23 AM
    I've not installed any extra switches but many others have. I know @ElNopal has switched there, and I think @2020Platinum does too. There are a ton of switch options, and I know switch pro is very popular, but idk if they do single switches.
  6. Sep 21, 2020 at 12:24 AM
    Barrel85
    William
    Thanks for the help.
  7. Sep 21, 2020 at 2:14 AM
    There is a company that makes direct fit switches....I'll try to find the link. I don't remember the company's name.
  8. Sep 21, 2020 at 2:17 AM
  9. Sep 21, 2020 at 2:39 AM
    Barrel85
    William
  10. Sep 21, 2020 at 4:28 AM
    timsp8
    NY
    There are also switches on Amazon by different companies that say they fit Toyota blanks.
  11. Sep 21, 2020 at 4:39 AM
    ElNopal
    Willis TX
    19 Cavalry Blue CM
    Yes, aftermarket switches will fit. However, make certain that they are for Toyota’s Small Switch openings. My favorite switches to use are from CH4X4. There are a lot of them that come stock with the accessories and/or symbols description. You can also customize your own to suit your needs.
    https://www.ch4x4.com/
    GODZILLA[QUOTED] likes this.
  12. Sep 21, 2020 at 10:01 AM
    Barrel85
    William
    Thanks for all the info. It’s been a big help
    ElNopal likes this.
  13. Sep 21, 2020 at 6:21 PM
    2020Platinum
    2020Platinum www.youtube.com/NitroZ18Fishing
    Patrick
    Northeast PA
    2022 TRD Pro (Lunar Rock)
    A lot. See my channel for all installs/mods!
    as stated above, www.ch4x4.com is where I got all my “OEM” switches...I did customize the words and image but they are exact size of OEM!
