Victory Roof Rack Safety Warning (please read if you have an over-cab rack)
Discussion in 'General Tundra Discussion' started by TwoWheels, Aug 14, 2020.
  1. Sep 4, 2020 at 9:10 AM
    #301
    The Californian
    The Californian Good Vibes Only
    Eric
    2020 Super White Tundra TRD Pro Crewmax
    Voyagermike likes this.
  2. Sep 4, 2020 at 7:38 PM
    #302
    Zero One Actual
    11 pages! Moderators, please unlock special achievements.
  3. Sep 4, 2020 at 7:59 PM
    #303
    Special achievements, unlocked.
  4. Sep 5, 2020 at 7:47 AM
    #304
    Bannock452
    Bannock452 New Member
    Brandon
    Murrieta, CA
    2016 White Crewmax 4x4 SR5
    King coilovers 35x12.50-18
    First thank you! I definitely overbuilt the mount to start so it would last!
    Second your also right they could have came up with a similar idea since there’s not many other ways to mount in that location.
    That being said they copied almost every single bend and curve for the cutout. Now my mount has a welded side leg and there’s is bent but still has the same bracing curve. There’s many ways to make a different style or add one different mounting location. But all is good and I’m still building and selling a bunch of these to all the loyal Tundra owners! Thanks again!
  5. Sep 5, 2020 at 1:39 PM
    #305
    Tundyfundy
    Bay Area, CA
    Magnetic Grey DC SR5 4x4 2016
    SUSPENSION: Bilstein 6112 coilover (1.9") w/ Powder Coated Springs and Spring Perch (TRD Red), JBA Upper Control Arms, Bilstein 5160's w/Billet Aluminium Reservoir Brackets, +2 Coachbuilder Shackles, Diff Drop Kit, Carrier Bearing Drop Kit, Brakeline Extensions, ABS Extension, Poly Bushings for Leafs, Coachbuilder Shims (2 Each Side), Coachbuilder Bumpstop Extensions, TRD Rear Sway Bar, TRD Front Sway Bar, Air Lift 5000 airbags w jounce bumpers, Daystar Airbag Cradles WHEELS AND TIRES: BF Goodrich KO2's 275/70/r18, BORA wheel spacers 1.25", TRD Wheel Caps,TRD Valve Stem Caps, Spare Tire Lock PERFORMANCE: Bullydog GT Tuner(Performance Tune), TRD Intake, TRD Dual Exhaust (with Modified Exhaust Hangers for Levelling Tail Pipe),TRD Brake Pads, TRD Oil Cap (US), TRD Radiator Cap, TRD Oil Filter, Optima Yellow Top Battery,GP Battery Distribution Blocks, StopTech Slotted Cryo Treated Rotors, Goodridge G-Stop Steel Braided Brake Line Kit PROTECTION: PNP Engineering Type 4 Rock Sliders (With Full Dimple Plate) ,ADD Stealth Fighter Rear Bumper w Red/Blk Shackles and Custom Stomp Pad, TRD Skid Plate with ReadyLift Spacer Kit, Victory 4x4 LCA Skid Plates, JOMAX ABS Sensor Armor, Rear Diff Breather Mod, ARK splash guards INTERIOR: Husky Liners X-Act (Front and Full Coverage Rear and Front Weather Beater Trans Hump), Interior LED Bulbs, WheelSkins Genuine Leather Steering Wheel Cover(EuroPerf), Clazzio Genuine Leather Seat Covers(BLK/DRK GRYwith custom stitching and embroidered headrests), Clazzio Seat Heaters (Front and Rear), Entune Startup Screen MOD, Entune Off Screen Mod, Tinted Windows with Windshield Visor, AJT Key Fobs,Eagle Claws Floor Mat Clips, Bodyglove Visor Organizer,Custom Door Cup Inserts, Glass Break Sensor,AJT Radio Knobs, Custom Dior Cup Inserts EXTERIOR: Full Debadge, LED Brake Light Bulbs, LED Rear Turns, LED Reverse, LED Plate Lights, LED Cargo Lights, LED Third Brake Lights, LED Front Marker Lights, LED Fog Light Bulbs, Lamin-X Fog Light Covers (Amber),2018 OEM LED Headlights, iHacker harness, VLED Universal Puddle Lights, VLED Interior Footwell Lighting (Front and Rear),VLED Extreme Amber Fornt Turns, NSV Knight Rider Light bar, Baja Designs Sport Squadron Pods in Rear Bumper (Driving/wide), Painted Red Tow-hooks, Bed Rail System, Blind Spot Mirrors, Hitch-safe, Tail-gate lock, EAG Raptor Grille, Custom Grille Badge,Full Vinyl Wrap (Matte Black/Matte Pine Green Mettalic), Charvonia Designs Tie Bed Tie-Downs, Bull Ring Bed Rail Anchors, Line-X, Tundra Bed Mat, Bakflip F1 Bed Cover SOUND: Noico 80Mil Sound Deadening and Noico 170 Mil Thermal Insulation (All 4 Doors, Roof, Floors, Rear Panel, Dash). Hertz Uno K170's Component Speakers (Front Doors with Upgraded Sail Panels), Hertz Uno K170 Coaxial Speakers (Rear Doors), JBL C1-075ct Tweeters (Total 4) in Side Dash and Center Speaker, JBL Stadium 5 Amp w/Remote Bass Adjustment Knob and Amp Rack, 12" Infinity Reference Subwoofer in Custom Enclosure w/ “TUNDRA” Logo, Fast Rings Foam Speaker Rings System(4 Doors), Fix 86 DSP
    :smokertransformer:
  6. Sep 5, 2020 at 5:57 PM
    #306
    Uhhhh....
    Uhhhh.... New Member
    Dave
    Virginia
    2016 Silver Limited DC
    7” BDS, 37s
    Thanks for your service. I definitely don’t miss marching/running in formation in the freezing cold or sweltering heat.
  7. Sep 5, 2020 at 8:23 PM
    #307
    TaquitoBandito
    Joel (AKA Bif)
    Strangely enough, I do miss the cadences. Running alone and singing about not letting my dingle-dangle dangle in the sand just gets weird looks from people.
    Uhhhh....[QUOTED] likes this.
  8. Sep 5, 2020 at 9:01 PM
    #308
    realtorblake
    realtorblake Tundra Thunda
    Redneckistan... aka Cypress, TX
    2019 Crewmax Platinum 5" Zone lift Fox 2.5 /OME suspension 12.5x35x18 ProComp's
    I am going to be deer hunting in Mexico in December and January. I am going to hit you up if I don't find a better solution. Everything down here on either side of the border has thorns like roofing nails. Don't want to take my truck across the border, because of the unreliable and expensive Mexico insurance, but I may have to. What is the lead time to have it shipped to Texas? Not buying anything else Victory for sure.
  9. Sep 5, 2020 at 10:45 PM
    #309
    Zero One Actual
    Don’t let it dangle in the dirt either.
  10. Sep 6, 2020 at 7:50 AM
    #310
    TundraPHX
    TundraPHX Ryan started the fire.
    Jared
    I’ve received @Bannock452 mount recently. Clean and great to work with. 10/10
    Bannock452 and fundra_goes_west like this.
  11. Sep 6, 2020 at 11:27 AM
    #311
    Bannock452
    Brandon
    Murrieta, CA
    Yea it’s definitely a peace of mind to have on board air. Especially down in Mexico. I have mounts in stock and can ship same or next day! Just let me know when your ready and I can get that shipped out!
  12. Sep 6, 2020 at 11:42 AM
    #312
    14burrito
    14burrito IG @14burrito
    2014 SR5 CM 4x4 5.7
    :bananadance::muscleflexing::cheers::mudding::tumbleweed::woot:
    TundraPHX likes this.
  13. Sep 6, 2020 at 4:28 PM
    #313
    TaquitoBandito
    Joel (AKA Bif)
    The worst place to dangle it was in the grass because then you had to pick it up and put it in your... "Rolling, rolling, rolling. Uh-oh, my knees are swollen"
    It was the mid-90's and we couldn't swear...
  14. Sep 6, 2020 at 7:30 PM
    #314
    Zero One Actual
    https://m.youtube.com/watch?v=hbzJnncsK18
    You could run across the earth with this guy.
  15. Sep 8, 2020 at 5:29 PM
    #315
    TwoWheels
    TwoWheels [OP] New Member
    AZ
    2016 Tundra Crewmax
    BDS4.5 CO, BD ONX6 40, Transfer Flow Tank, Firestone Airbags, Softtopper, BedRug, TRD Grill, Datinfab Bedrack, Victory Roofrack, Hushmat, SDHQ Rocksliders, SDHQ hidden lightbar, BajaDesigns Squadron fogs, Method 18s, Falken Wildpeaks
    3 for 3.
    I was contacted by a third member here who dropped their headliner after reading this thread and found both airbags destroyed.
    I will let them share the details.
    Dang.
    saybng and Bob_Wiley like this.
  16. Sep 8, 2020 at 5:39 PM
    #316
    Bob_Wiley
    Bob_Wiley I feel good, I feel great, I feel wonderful...
    Eric
    AZ
    2016 Black SR5 Crewmax 5.7 FFV
    Ouch, that sucks. This is precisely why I could never start my own business — one little screw up can sink a small company.
  17. Sep 9, 2020 at 3:25 PM
    #317
    The Californian
    Eric
    Looking at theirs, I can absolutely see the similarities - theirs looks like the Wish.com version of yours.
  18. Sep 10, 2020 at 6:17 AM
    #318
    Justin.TX
    Justin.TX South Texas Tundra
    Justin
    2015 Tundra TSS CM
    Ummm. Stuff
    Its back up and edited now.
  19. Sep 18, 2020 at 12:07 PM
    #319
    ardnutma
    ardnutma New Member
    I'm the third guy in the group that took Victory's statement about drilling into a "safe zone" to mean "no risk of airbag damage" when in fact, you are drilling directly over the airbag for each of the 8 holes required to install this rack. After I installed the rack, I logged into this forum to write a positive review and stumbled on to this thread. I dropped my headliner the next day, and found that I had punctured both the drivers and passengers side airbags with the drill bit. The local body shop suggested that I file a claim with my insurance company, and in the end, USAA ended up covering the $3500 repair (minus deductible).
    I reached out to Victory via email to ask for reimbursement and for them to change their installation instructions. I just got a back call back from them yesterday. Kevin from Victory was very professional. He told me that they would not cover any repair costs, but would allow me to return the rack for a full refund. Now that I have 8 holes in my roof, returning the rack isn't a very good option. He took the time to listen to my concerns, which included changing the installation instructions and notifying everyone who purchased this rack of the risk of airbag damage so that they could take inspect their vehicles. He didn't agree to take any action on either one of these concerns. Kevin seemed like a reasonable guy, and I hope he make the right decision here. I wouldn't want to be in his position.
    Overall, this has been a real PIA experience that could have been prevented had Victory provided better installation instructions. After dealing with this, I reviewed both RhinoRack and Prinsu installation instructions. Prinsu had a very obvious warning in the instructions: "Be very careful not to drill excessively deep as airbags are located below". RhinoRack didn't mention the airbags at all. Unfortunately, I went with Victory, who's installation instructions implied that there was no airbag risk in drilling.
    Thanks again to TwoWheels for bringing this to my attention so that I could restore my truck to the safety level it provided when I purchased it.
  20. Sep 18, 2020 at 12:24 PM
    #320
    The Californian
    Eric
    I don't even own one of their products, but seeing responses like this just frustrates me to no end. As someone that has ran calls on major car accidents where people that should have died, survived because of airbags, I just don't know how someone could live with themselves, or sleep at night knowing their negligence could literally lead to wiping out a whole family, and not just say "I need to contact these people immediately." The instructions were a mistake, accidents happen - but the lack of action at this point is complete negligence, and the blood is on their hands due to it.
    It makes me sick to think about it, and it should make you sick too. @brimy311
  21. Sep 18, 2020 at 12:35 PM
    #321
    fisherman951
    fisherman951 MT dreams
    Tony
    2017 crewmax 4x4
    Get a lawyer
    saybng likes this.
  22. Sep 18, 2020 at 3:01 PM
    #322
    timsp8
    NY
    His lawyers probably told him not to say anything. Seems like he just listened. If someone they sold a rack to was in a wreck and sued them, anything he said or did could come back on him negatively. Lawyers first response is to not say or do anything.
  23. Sep 18, 2020 at 3:21 PM
    #323
    TundraPHX
    Jared
    Yep. He listened. Didn’t admit fault with his words or by paying any sort of damages. Taking back the rack at full price doesn’t implicate him in anything. He’s 100% working with his attorney on this one.
  24. Sep 18, 2020 at 4:00 PM
    #324
    Sunnier
    Sunny
    San Diego, CA
    Problem is, if there are dozens damaged out here... doing the right thing would put him out of business due to high financial costs to make it right.
    Unfortunately, any future deaths that can be attributed to airbag failures in trucks with Victory racks sold before that video was updated, will for sure put him out of business... and possibly out of personal assets as well. No win here.
  25. Sep 18, 2020 at 4:25 PM
    #325
    Burdturger
    Burdturger New Member
    Anyone share this psa to other forums? How do we know only tundras are affected?
    Bob_Wiley likes this.
  26. Sep 18, 2020 at 4:27 PM
    #326
    Hartsy8
    Hartsy8 Resident Hockey Guy
    Max
    2020 MGM 1794
    Think of all the Tacos and 4runners. Yowza
  27. Sep 18, 2020 at 5:42 PM
    #327
    TaquitoBandito
    Joel (AKA Bif)
    USAA is usually pretty good at getting their money back - I'm kind of surprised their lawyers haven't called Kevin.
  28. Sep 18, 2020 at 5:49 PM
    #328
    betotundra
    betotundra Toyota for Life
    I know nothing about USAA's business, but they might have their money back already, it's just that there's no way we could know.
  29. Sep 18, 2020 at 5:57 PM
    #329
    Warreng
    Warreng New Member
    @TwoWheels, way to handle this thread, you kept cool and to the point
    Was hilarious to hear all the forum experts give advice on drilling sheet metal.
  30. Sep 18, 2020 at 6:12 PM
    #330
    Navi
    Navi New Member
    2019 CrewMax Limited
    Might make for a good class action suit if the class could get certified. Needs a lead plaintiff, then class members can be added.
