  1. Sep 17, 2020 at 5:49 AM
    #7921
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
    This isn't even the worst one I've seen.
    Super white, 2005-ish? (Cat eye) Chevy 2500.
    Its got to have at least at 16 inch lift in the front, and a 4 inch drop in the back.
    Hub spacers out the wazooooo. I'm talking like each outer edge of the tires is touching road paint at all times. Of course he has elected to install the remote controlled, color changing wheel lights that were somehow mounted BEHIND the actual rim. Not up in the wheel well like rock lights. Looks BoNkErS!
    Color changing led headlights that he has set to "rotate" through the variety of colors. Very distracting, and illegal.
    Anytime I see him he ALWAYS has his head lsung out the window so he can see the road. Doesn't matter if its hot, or cold. Rain, or shine. Heads out the window. Super practical.
  2. Sep 17, 2020 at 5:51 AM
    #7922
    Professional Hand Model
    Fred
    Hand Protectors
    :bananadead:
    Tundra2 likes this.
  3. Sep 17, 2020 at 5:51 AM
    #7923
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
    bmf4069 likes this.
  4. Sep 17, 2020 at 5:54 AM
    #7924
    Pucks18
    Pucks18 Fleabit peanut monkey
    2001 Tundra 4x4 Limited trd
    When your at work buzzing off of Kratom you will argue with anything
    ktundra and Tundra2[QUOTED] like this.
  5. Sep 17, 2020 at 6:11 AM
    #7925
    ktundra
    ktundra rust be damned
    Lex
    NJ
    06 Tundra DC Limited 4WD
    Bilstein 5100
    Ditto. Managed to find mine on Craigslist that had a fair amount of rust, but not rotting, and within reach for the price. Knocked down the asking price by indicating the tb/wp needs replacement.
  6. Sep 17, 2020 at 6:13 AM
    #7926
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
    I never would have guessed that my lil 1st gen would come to the rescue, and my hood lights provide light for turn signal changing. :rofl:
  7. Sep 17, 2020 at 6:16 AM
    #7927
    ktundra
    Lex
    NJ
    Bilstein 5100
    Here's a video for a Hellwig unit:
  8. Sep 17, 2020 at 6:17 AM
    #7928
    ktundra
    Lex
    NJ
    Bilstein 5100
    Wow, that's bright!
    Tundra2[QUOTED] likes this.
  9. Sep 17, 2020 at 6:20 AM
    #7929
    Fred
    Hand Protectors
    The Starship. Captains Log Star Date 2020. Moved into Klingon Territory and changed a light signal on a turd Sequoia. Live long and prosper in wurrld peas.
  10. Sep 17, 2020 at 6:27 AM
    #7930
    Fred
    Hand Protectors
    Once you know what to look for and read you can see through these smeggsliss scam liars descriptions. Every once in a while an honest person will openly say the truck has rust and post the actual picture of the rust and not some shot from way back looking from the passenger wheel towards the rear of truck shot.
    ktundra likes this.
  11. Sep 17, 2020 at 7:10 AM
    #7931
    I've never seen garbage like that before, this is really a thing? Is it national, or just limited to a specific area in one state?
    That looks stupid as hell and impractical. If you want that, get hydraulics. One of my buddies lost a rear mount on his show truck while driving home from Daytona when I was younger and his rear passenger cylinder mount broke off when he pushed his truck up high to pancake it at a stoplight to turn heads. Looked almost like the 1st pic you posted, whole truck was leaning to the rear passenger side.
    Two Brothers?
  12. Sep 17, 2020 at 7:12 AM
    #7932
    Fred
    Hand Protectors
    Tundra2 likes this.
  13. Sep 17, 2020 at 7:13 AM
    #7933
    Fred
    Hand Protectors
    Tundra2 and ktundra like this.
  14. Sep 17, 2020 at 9:09 AM
    #7934
    robabeatle
    robabeatle New Member
    AZ
    2002 Tundra 4x4 LTD AC
    Bilstein 6112 & 5160, Katskinz, audio upgrades
    I like this. Basically the instructions are useless!
    I wonder how helpful jacking the vehicle up is. Definitely or eh if you want?
  15. Sep 17, 2020 at 9:12 AM
    #7935
    Pucks18
    Some may despise this but I'm actually thankful our trucks had such shitty factory frames, cause now I have a 7 year old from on a 20 year old truck. Think about it, even if we had quality frames they would still get pretty damn rusty after 20 years. +1 for frame recall
    ktundra likes this.
  16. Sep 17, 2020 at 9:15 AM
    #7936
    Fred
    Hand Protectors
    Without knowing which instructions you possess: When I installed my Hellwig7700, I did not jack up truck. Best thing to do is assemble everything on the floor and picture how it will install on the truck. Disassemble and install the extensions (loosely). Then install sway bar (loosely). Make sure the Mojo feels proper. Snug bolts/nuts to spec from top to bottom. 2 hours tops.
    robabeatle[QUOTED] likes this.
  17. Sep 17, 2020 at 9:17 AM
    #7937
    robabeatle
    AZ
    Excellent. Thanks.
  18. Sep 17, 2020 at 9:22 AM
    #7938
    Fred
    Hand Protectors
    Seeing the bags of nuts and bolts without them assembled make the job look harder. Once you get the dry run accomplished it will all make sense.
    Things I did that were not in instructions:
    1) Installed grease on threaded rod before screwing down. Prevents future seize.
    2) Spray painted all the nuts/bolts black afterwards.
    3) Generously lubed the bushings and ferrules.
    ktundra and robabeatle[QUOTED] like this.
  19. Sep 17, 2020 at 9:57 AM
    #7939
    CodyP
    CodyP Such a n00b
    Cody
    CDA, ID
    2006 Tundra 4x4 DC
    No wonder why people put hellwig rear swaybars on the 1st gens....THERE ISNT A FACTORY ONE TO BEGIN WITH! And I just realized that
  20. Sep 17, 2020 at 9:57 AM
    #7940
    035VZFE
    035VZFE Restored a Tundra top to bottom
    James
    Vero Beach, Florida
    2009 Passat B6 2.0 Turbo
    ECS Tuning DV Spacer ECS Tuning Turbo Muffler Delete ECS Tuning Luft-Technik CAI System A-Spec 60mm Charge Pipe Straight piped from resonator back, stock cat and downpipe
    Something comical i just thought of. My tundra is at 240k with original engine and transmission and running great. My dad's chevy has 150k with it's third engine just swapped in. First engine seized, second had a scored cylinder wall, and the current one burns coolant just like fuel.
    Crazy. I still love that car though.
  21. Sep 17, 2020 at 9:58 AM
    #7941
    Fred
    Hand Protectors
    There was a rare factory rear sway bar on the 03. Very rare.
  22. Sep 17, 2020 at 10:44 AM
    #7942
    CodyP
    CodyP Such a n00b
    Cody
    CDA, ID
    2006 Tundra 4x4 DC
    It's just crazy to me that you wouldn't have a factory one...
  23. Sep 17, 2020 at 10:49 AM
    #7943
    035VZFE
    James
    Vero Beach, Florida
    Everywhere in south FL where I live. One of the dorks that lives a couple houses down did that to his old durango and bent the axle :rofl:
    Tundra2 and shifty`[QUOTED] like this.
  24. Sep 17, 2020 at 11:06 AM
    #7944
    robabeatle
    AZ
    Am I remembering correctly that years ago you posted about there being no need for a rear sway bar? I thought I read that when researching?If so, what changed your mind?
  25. Sep 17, 2020 at 11:09 AM
    #7945
    One of our plumbers is out from a shoulder surgery, when he came home they found their water heater leaking, haven’t had hot water in two weeks. Some of the guys at the shop pitched in and got him the unit he wanted(he’s a plumber, he wanted the fancy shit of course) and put a comfort T in the master bathroom
    Me and another guy went over and piped it in and got his family some hot showers going!
    I’m not a “plumber” but I did all the soldering and piping. I tried to keep it clean.
    NUDRAT[OP], 035VZFE, Tundra2 and 7 others like this.
  26. Sep 17, 2020 at 11:25 AM
    #7946
    NUDRAT[OP], 035VZFE, Tundra2 and 4 others like this.
  27. Sep 17, 2020 at 11:44 AM
    #7947
    Fred
    Hand Protectors
    I’d love to see that quote. In context, I already had the OEM front bar (rusted broken links and bar hanging) and was thinking about not reattaching it when having the front rebuilt. Had gotten used to boat like turns I guess? Shop guy talked me into it as the very small forum (at the time) here was mostly anti-sway bar. Once I decided to do it and felt the niceness again with it reattached, then I continued the journey on the rear bar. Think it was @Rex Kramer who recco’d the rear sway. Most of the 60+ reviewers were 1st Gen Tundra.
    Most I’ve done off roading is beach driving. Some peet and dirt trails. I’d argue that a sway bar works well in anything on this truck but rock crawling which at that point I’d be in a Jeep. Is a rear sway necessary? No. Is it excellent on street driving? Yes. Keeps that inner tire down and stuck to road without spinning even with LSD.
  28. Sep 17, 2020 at 11:48 AM
    #7948
    Fred
    Hand Protectors
    POTB Award of the Month for @FrenchToasty !
    bmf4069[QUOTED] and Tundra2 like this.
  29. Sep 17, 2020 at 11:49 AM
    #7949
    Rex Kramer
    Rex Kramer Vinyl Spinner
    Georgia
    I have been a big fan of installing a rear anti roll bar on all of my vehicles that don't have them since the late 1970's, the first Toyota truck that I installed a rear bar on was a 4WD T100, then my 4WD '02 Tundra and now my 2WD '07 Tundra.
  30. Sep 17, 2020 at 11:51 AM
    #7950
    Fred
    Hand Protectors
    Other than having the front end rebuilt I’d say adding the rear sway bar is second best ‘mod’ thus far. Thanks for the recco.
