5100 top setting with 285/75/18??
Discussion in 'Suspension' started by Skoden, Sep 14, 2020.
  1. Sep 14, 2020 at 7:39 PM
    Skoden
    Skoden [OP] New Member
    Jared
    Manitoba Canada
    21 mgm pro cm
    Anyone running 285/75r18 with 5100’s top setting? Just wondering if they would fit. If so pics? Thanks in advance.
  2. Sep 14, 2020 at 9:41 PM
    Voss
    Voss Not a new member
    2003 AC TRD 4x4
    Pretty sure the issue with top setting is not a good idea. Mainly cause the upper control arm can’t handle the lift and 2nd, that’s a lot of pressure on the Bilstein ring. If you go on trails/off-road, top setting can fail.
  3. Sep 14, 2020 at 9:56 PM
    JimboSlice413
    JimboSlice413 Super Nice Guy
    Bakersfield
    They'd fit height wise no problem but that isn't your limiting factor, its your body mount. 295/70s barely squeak by without a BMC and a 285/75 is slightly taller.
    Also, wheel offset is a factor
  4. Sep 15, 2020 at 5:03 AM
    Skoden
    Jared
    Manitoba Canada
    21 mgm pro cm
    Ok ya that’s what I kinda thought. They would be on the trd wheels so +60 offset Thanks again.
  5. Sep 15, 2020 at 11:43 PM
    KTMRider
    KTMRider New Member
    Ken
    2020 Tundra
    King's all around, Dirt Deeds 10" exhaust, 18x9 Method 305 NV, Falken Wildpeak A/T3W 305/65/18 tires, tinted windows (shhhhh)
    5100's, top setting, 305 x 65 x 18 Falcon Wildpeak on Method 305NV's. Took off front mud thingy....
    Yota707 likes this.
  6. Sep 15, 2020 at 11:45 PM
    Yota707
    Yota707 New Member
    Bay Area
    2015 Tundra TRD
    Auto detail, vinyl wrap specialist. Truck has a 300gal fresh water tank for spot free water while detailing and a Honda pressure washer
    How’s the ride quality on top setting? Did you do a diff drop or anything extra?
  7. Sep 15, 2020 at 11:57 PM
    KTMRider
    KTMRider New Member
    Ken
    2020 Tundra
    Ride quality is very good, nothing else done to the front. No diff drop. I did just add the Icon expansion leaf pack to the back to give me back some rake for my dirt bike hauling. it actually made the back ride even better than just the 5100's in the back.
