Gas Mileage
Discussion in 'General Tundra Discussion' started by Tundrax23, Sep 13, 2020.
  1. Sep 13, 2020 at 9:21 AM
    Tundrax23
    Tundrax23 [OP] New Member
    2015 Tundra crewmax
    I usually was getting 293 miles on a full tank of gas, but I Disconnected the battery due to doing some work on speakers, but once i reconnected the battery, I am now getting 395 miles on a full tank, and my MPG went down to 12mpg from 13mpg. What happened? What does everyone else get for their miles till empty? Thanks
  2. Sep 13, 2020 at 9:24 AM
    18" TRD Off Road Wheels
    Disconnecting the battery resets the computer, so your distance to empty inflates as a result. It will balance back out after a few tanks.
  3. Sep 13, 2020 at 9:36 AM
    Welcome from NY.
    Like Adam said drive it and it will reset.
    Tundrax23[OP] and YardBird like this.
  4. Sep 13, 2020 at 9:39 AM
    YardBird
    YardBird Native San Diegan
    Jonesy
    2005 RCLB
    Welcome aboard from The Pacific South West.
    Tundrax23[OP] likes this.
  5. Sep 13, 2020 at 11:24 AM
    timsp8
    NY
    Mine goes up to 600 dte if I unhook the battery. I usually get around 11 mpg. It goes back down to 400 dte after a tank or 2.
  6. Sep 13, 2020 at 12:09 PM
    The Dude
    The Dude New Member
    Chandler, AZ, not anymore :(
    My battery just died. I unhooked to charge it and when reconnected DTE was same as I left it, about 230 miles
  7. Sep 13, 2020 at 12:38 PM
    Tundrax23
    2015 Tundra crewmax
    What is an average Miles till empty? Mine is 293 and it just seems too low
  8. Sep 13, 2020 at 12:51 PM
    The Dude
    The Dude New Member
    That's pretty much it. Mine is ~300 just about every time. The most I've seen was 312, and it was due to constant highway driving
  9. Sep 13, 2020 at 12:53 PM
    Depends on your tank size, and most of the trucks are more conservative. Guys will run until the computer says no more miles, and fill up to find they had several gallons left. Mine has the 38 gallon tank and I don't push the skinny pedal too hard most days.
    The Dude likes this.
  10. Sep 13, 2020 at 1:34 PM
    timsp8
    NY
    26 gallons x 13 mpg is 338 miles. DTE on these tanks also don’t go to actual empty. I’ve never run it low, but it seems the 38 gallon tank has 5-7 gallons left when on E. 26 gallon tank might have 3-5 or so. So 293 calculated by the computer seems right.
  11. Sep 13, 2020 at 1:37 PM
    26 has 6 gallons left at E. My DTE at fill up averages around 295. I'm averaging around 11 in town.
