2007 Supercharged high mileage beast
Discussion in '2nd Gen Tundras (2007-2013)' started by forrestgump8326, Sep 11, 2020.
  1. Sep 11, 2020 at 6:39 PM
    forrestgump8326
    forrestgump8326 [OP] New Member
    2007 Toyota Tundra SR5 Crewmax 5.7 S/C
    TRD Supercharged
    Greetings y'all. I have an old, but not so tired '07 trd supercharged Crewmax. Recently started puffing smoke at startup, then quickly progressed through all the bad valve guide seal symptoms (smoking after deceleration, clearing up under acceleration etc.)
    I pulled the plugs & valve covers, and discovered the spark plug tube seals were beyond bad. Rock hard and brittle. IMG_20200911_203310.jpg After replacing those, I found that I still had an oil burning issue. So I have decided to change the valve stem seals.
    My question to you guys is, what other rubber should I be replacing while I've got the timing chain off? I'd like to stick to a fairly frugal budget. Timing chain is the original, but seems to be in pretty good of shape.
    Cg13055, Mountun Goat and omgboost like this.
  2. Sep 12, 2020 at 12:31 PM
    Filthyphil
    Filthyphil Lions Not Sheep
    Phil
    2000 Toyota Tundra TRD 4.7
    Sorry can’t help but I am definitely interested in your situation, how many miles has it been super charged?
  3. Sep 13, 2020 at 7:25 AM
    forrestgump8326
    TRD Supercharged
    It has been supercharged since quite early in its life. ~20k miles is when the TRD kit was installed. So far, the list of parts I'm gonna service while I'm down I'm there includes: Timing chain, timing chain guides, timing chain tensioners, water pump, serpentine belt, and valve stem seals.
  4. Sep 13, 2020 at 7:48 AM
    Rex Kramer
    Rex Kramer Vinyl Spinner
    Georgia
    Good luck with your repairs... is there a link that details your functional hood scoop?
  5. Sep 13, 2020 at 8:02 AM
    forrestgump8326
    TRD Supercharged
    It's a fully functional fiberglass ram air hood. Ive considered cutting some vents in it to help with heat dissipation, but I just love the way it looks currently.
    https://www.carolinaclassictrucks.com/Fibertec-Performance-811442.html
  6. Sep 14, 2020 at 8:54 PM
    Rmeeks
    Rmeeks New Member
    How many miles are on the truck now?
    Cool project, please post pics while tearing down. I would like to see
  7. Sep 15, 2020 at 8:43 AM
    forrestgump8326
    TRD Supercharged
    I think it was at like 258k before I disconnected the battery. Original unopened motor and transmission.
    And supercharger. It's a pretty remarkable vehicle.
  8. Sep 15, 2020 at 8:45 AM
    forrestgump8326
    TRD Supercharged
    Considering a slight change of plans. Tempted to pull the motor out.
    Cg13055 and Mountun Goat like this.
  9. Sep 15, 2020 at 8:47 AM
    AZTundra
    Paul
    Phoenix, AZ
    Is that the coolant reservoir that's routed to the front? Any specific reason that was done? It should be mounted to the supercharger on the drivers side with a bracket.
    Chrslefty likes this.
  10. Sep 15, 2020 at 9:33 AM
    forrestgump8326
    TRD Supercharged
    It mounts there on trucks with the tow package I believe.
    snivilous and AZTundra like this.
  11. Sep 15, 2020 at 10:26 AM
    sensei
    sensei master and teacher of nothing
    trd boosted, trd bbk, fox stage 4, corsa, amp, jl/kenwood
    correct, mine is in front of the radiator also and i have the tow package. installed by the book by toyota. that's awesome to get 258k miles. i bought my 08 new and boosted with 30k miles in 2010. i have 85k now so if i can get another 12yrs and 80k i'll be super happy. not my daily.
  12. Sep 15, 2020 at 11:18 AM
    AZTundra
    Paul
    Phoenix, AZ
    Thanks for the response. Never saw that before so I was curious.
  13. Sep 15, 2020 at 11:35 AM
    forrestgump8326
    TRD Supercharged
    So after pulling the radiator and fan, I'm encouraged by all this new space I have now. Still tempted to pull the motor, but I'd really rather hold off on that until it's time for the performance build. I'd like to see how long I can keep this stock original drivetrain on the road. For those of you who care, this truck has been driven some long, hot miles. Religious, high quality oil changes, but it has been driven like a supercharged tundra should be.
  14. Sep 15, 2020 at 11:37 AM
    forrestgump8326
    TRD Supercharged
    The Magnuson is a good tool holder
    omgboost, FundraTRD, TheBeast and 8 others like this.
  15. Sep 16, 2020 at 5:14 AM
    Rmeeks
    Rmeeks New Member
    Nice work. Im curious to find out the problem, never heard of this issue on thr tundrs
    forrestgump8326[OP] likes this.
  16. Sep 20, 2020 at 8:05 PM
    Rmeeks
    Rmeeks New Member
    Made anymore progress??
  17. Oct 7, 2020 at 12:39 PM
    Rmeeks
    Rmeeks New Member
    Thought about this today
  18. Oct 7, 2020 at 12:49 PM
    TheBeast
    TheBeast The Beach
    talk about a sleeper at the light ;)
  19. Oct 21, 2020 at 3:47 PM
    forrestgump8326
    TRD Supercharged
    Sorry guys, got busy with life and had to step away from the truck project. I've recently resumed, and got really really tired of trying to work on the motor in the truck. So I pulled the motorIMG_20201017_082736.jpg
  20. Oct 21, 2020 at 3:48 PM
    forrestgump8326
    TRD Supercharged
  21. Oct 21, 2020 at 8:35 PM
    Rmeeks
    Rmeeks New Member
    Awesome awesome
    Whats the plan?
  22. Oct 22, 2020 at 6:55 AM
    forrestgump8326
    TRD Supercharged
    Today I will be pulling the cylinder heads, to see how much of a rebuild I need to do. I strongly suspect that the bottom end needs nothing, and my valve stem seals are what the issue is. But while I have the motor out, I gotta spend a little bit to make sure my cylinders/rings are in good shape.
  23. Oct 23, 2020 at 7:27 PM
    Rmeeks
    Rmeeks New Member
    Look forward to seeing internals
    Filthyphil likes this.
  24. Oct 23, 2020 at 7:38 PM
    blackdemon_tt
    blackdemon_tt Battery Slayer
    dayum, interested as well... sub'd...
  25. Oct 25, 2020 at 9:58 AM
    forrestgump8326
    TRD Supercharged
  26. Oct 25, 2020 at 10:02 AM
    forrestgump8326
    TRD Supercharged
    I didn't take the best pictures of the cylinders, but it is absolutely remarkable how little wear there is. Almost no wear ridge on the cylinder walls, factory crosshatching visible in all 8 cylinders. I'll take a better picture tomorrow. The cylinder that was burning oil is clearly visible from the carbon deposits on the intake and exhaust valves. (cylinder 7)
  27. Oct 25, 2020 at 10:29 AM
    Filthyphil
    Phil
    You can damn near see the cross hatching in that last picture.
  28. Oct 27, 2020 at 7:41 PM
    Rmeeks
    Rmeeks New Member
    What do the heads look like?
  29. Nov 2, 2020 at 9:09 AM
    forrestgump8326
    TRD Supercharged
  30. Nov 2, 2020 at 9:09 AM
    forrestgump8326
    TRD Supercharged
    I am happy to report I found the problem
