  1. Sep 10, 2020 at 7:40 PM
    #7711
    empty_lord
    Indiana, Chicagoland
    05 rollover special
    i left it green. i like having some green with the white..
    Tundra2 and ktundra[QUOTED] like this.
  2. Sep 10, 2020 at 8:27 PM
    #7712
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
    Just like @empty_lord I left that alone too.
    ktundra[QUOTED] likes this.
  3. Sep 11, 2020 at 4:55 AM
    #7713
    Professional Hand Model
    Fred
    Hand Protectors
    I drilled and removed mine out. The new LED up in there is nice and bright and I enjoy the white light.
  4. Sep 11, 2020 at 4:58 AM
    #7714
    Cam journals might be a bit hard to check. You can check the cam lobes for wear though.
    But don't be a wuss, take a cam cap off and check the journals.
  5. Sep 11, 2020 at 5:03 AM
    #7715
    Fred
    Hand Protectors
    My woo woo hurts just thinking about this. :rofl:
    bmf4069[QUOTED] likes this.
  6. Sep 11, 2020 at 5:11 AM
    #7716
    If you were really dedicated, you would drop the oil pan and unbolt a rod to check the rod bearings and crank journals. :eek2:
    But, being a low oil pressure system, and never having heard of one singe rod bearing failure, that may not be necessary....... for the normal person. But we are talking about the infamous PHM here.....
    Darkness, CodyP, TX-TRD1stGEN and 3 others like this.
  7. Sep 11, 2020 at 5:16 AM
    #7717
    Fred
    Hand Protectors
    Watched a video of some guys doing a rebuild of the 4.7L on their 1st Gen Tundra last night. One of the piston rods broke which lead to the rebuild.
    Looked like a cool little project that took some time. Last little bit of the video they were running to Oriellys to pick up a $140 Bosch o2 Sensor and some other made in china crap. Too bad they didn’t come here for parts help. Overall, they did a very nice job using quality stuff.
  8. Sep 11, 2020 at 5:17 AM
    #7718
    Fred
    Hand Protectors
    I actually looked at doing this a few years ago, but couldn’t get the bolts loose. :rofl:
    bmf4069[QUOTED] and Tundra2 like this.
  9. Sep 11, 2020 at 5:32 AM
    #7719
    Pretty sure I watched the same video. A couple young guys right? He broke a rod by going through a huge mud puddle and sucking water into the engine. I don't think he mentions it in the video but says it on his instagram page.
  10. Sep 11, 2020 at 8:55 AM
    #7720
    Pucks18
    Pucks18 Fleabit peanut monkey
    2001 Tundra 4x4 Limited trd
    Think I've seen that video. I think it broke when he drove through a large deep puddle of water. Not sure if that had anything to do with that?
  11. Sep 11, 2020 at 8:56 AM
    #7721
    Pucks18
    What does it being a low oil pressure system have to do with that? I'm a curious noob
  12. Sep 11, 2020 at 9:00 AM
    #7722
    Darkness
    Darkness Allergic to white
    Luis
    All over SoCal
    The darkest
    It's really dark
    Legend has it, he once used an ancient Peruvian technique to do a full clay bar job on his truck using clay sourced from Machu Picchu. He then used a micrometer to test how thick his paint was before adding natural wax from bees collected in the Changbai Mountains (pre-covid) and applied it using lamb skin from Khuvsgul Mongolia and a sacred Tibetan hand motion.
  13. Sep 11, 2020 at 9:01 AM
    #7723
    Darkness
    Luis
    All over SoCal
    The darkest
    It's really dark
    Sounds like that guy that showed up here and ran through a mud puddle, then said his motor was knocking.
    lsaami and FirstGenVol[QUOTED] like this.
  14. Sep 11, 2020 at 9:08 AM
    #7724
    Darkness
    Luis
    All over SoCal
    The darkest
    It's really dark
    Went to chick fil a yesterday for lunch, never noticed they write what you drive on the order slips. Murdered my name as usual.
  15. Sep 11, 2020 at 9:48 AM
    #7725
    Fred
    Hand Protectors
    You are real good. Nailed it! I would add the knowledge was passed down from Elders in the Adjacent Unnamed Changbai Mountain Region that immigrated over the tall peaks during Monsoon Season. :rofl:
  16. Sep 11, 2020 at 10:15 AM
    #7726
    Outbound
    Aaron
    Northern Alberta
    I'll be putting a new battery in my truck nezt month. I use a block heater at home but at work the truck doesn't get plugged in.
    Northstar or Odyssey for a battery in super cold temperatures down to -40F? AGM worth the extra cost?
  17. Sep 11, 2020 at 10:44 AM
    #7727
    empty_lord
    05 rollover special
    Sanded to 3000 grit and now with 2k clear coat. (Drying)
    [​IMG] [​IMG]
  18. Sep 11, 2020 at 10:47 AM
    #7728
    I'm not 100% sure why or how, but I know higher pressure oil systems like to eat rod bearings. My SHO motors need rod bearings replaced every 120k or when they go bad due to lack of proper oil changes. They'll start knocking on startup, no motor oil condition or level, which my 3.2L car is currently doing. Starts up in the 30s then drops to about 2 psi. PFA because, you know, we like pics. Like, a lot.
    But yeah, I'm sure I butchered that reason so I'm sure someone smarter than me has the right answer.
    Darkness likes this.
  19. Sep 11, 2020 at 11:20 AM
    #7729
    Festerw
    Festerw New Member
    Cambridge Springs, PA
    04 Tundra DC
    Dude I work with just offered 14k to buy my truck. Used vehicle market is bananas right now.
    Not going to lie I though about it since I only paid 9 for it 3 years and 40k miles ago.
  20. Sep 11, 2020 at 11:26 AM
    #7730
    Darkness
    Luis
    All over SoCal
    The darkest
    It's really dark
    Let's just keep an eye out for some turd gens
    :infantry:
  21. Sep 11, 2020 at 11:40 AM
    #7731
    I understand supply/demand basics but I'm just really unclear what is causing this. I guess people are more comfortable buying cheaper used vehicles right now because of the economy? Or fewer people are trading in their vehicles so there are fewer used vehicles to pick from. At the same time, they are saying 20% of Toyota dealerships don't have a single Tacoma on the lot.
    I've been watching that unfold on Tacomaworld. Some people are claiming they got offers from Carvana for MORE than they paid for their trucks 2 years ago. Or in other cases they are only losing $1-2K. Just for kicks, I put my vin# in and they offered me like $2,500 :D
    The problem with selling high is that you'd just end up overpaying for the replacement. The same thing is happening in the housing world right now.
    Darkness and FrenchToasty like this.
  22. Sep 11, 2020 at 11:41 AM
    #7732
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
  23. Sep 11, 2020 at 12:12 PM
    #7733
    Been shopping for GX460/4Runner rotors/calipers today. This is going to be an expensive upgrade unless I go aftermarket. Even NAPA wanted the same price for rotors as Toyota so I took them off the list for now. I tried car-part.com but there were no wrecked units within 100 miles of me. I'm about to call some local dealerships and see if they will price match Cool Springs since shipping rotors is so expensive.
    Tundra2 likes this.
  24. Sep 11, 2020 at 12:16 PM
    #7734
    Festerw
    Festerw New Member
    04 Tundra DC
    That's why I said no, did think about it though as the wife is currently working from home until next year sometime so we don't really need 2 vehicles.
  25. Sep 11, 2020 at 12:39 PM
    #7735
    I know what you mean. I've got a friend that wants to sell me his 2003 Pontiac Bonneville. It's nearly mint with only 80,000 miles. It was his grandpa's and has been meticulously maintained. He wants $1,200 for it. We've been talking about buying it all year as a D.D for me. But now that COVID has us both working from home it's really hard to justify a 3rd vehicle. It's totally a grandpa mobile but it would be a nice daily.
    Darkness, GODZILLA and Tundra2 like this.
  26. Sep 11, 2020 at 1:02 PM
    #7736
    Sounds like a smokin' deal.
  27. Sep 11, 2020 at 1:03 PM
    #7737
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
    Buy, and resell? Unless the fella would never forgive you.
  28. Sep 11, 2020 at 1:17 PM
    #7738
    lsaami
    lsaami Let ‘er buck
    Minnesota
    2000 Tundra 4x4 "$1100 Build"
    I got a complete aftermarket kit (13WL) on Amazon. Been super happy With them. They haven’t even surface rusted yet!
  29. Sep 11, 2020 at 1:25 PM
    #7739
    He's a good friend and I would feel shitty doing that. He just doesn't know anything about cars. I think I'm going to help him sell it for more. He should be able to get at least $2,500 for it I would think.
    ktundra, NUDRAT[OP], Darkness and 2 others like this.
  30. Sep 11, 2020 at 1:41 PM
    #7740
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
    Best course of actions!
    ktundra likes this.
