  1. Sep 9, 2020 at 2:09 PM
    #4081
    TaquitoBandito
    Joel (AKA Bif)
    We went from a house built in 2005 with multiple closets to a home built in the 1890's with a small stairwell closet. Fortunately a previous owner opened the attic up for storage (with a spiral staircase). We figured out really quick that nearly every piece of furniture we buy has to have some kind of storage element to it.
    SomeGuy4 and Baja Mike[QUOTED] like this.
  2. Sep 10, 2020 at 5:54 PM
    #4082
    TaquitoBandito
    Joel (AKA Bif)
    Thanks - they can be a bit of a pain to maintain but it's completely worth it. We are thinking ours was built around 1895. It's when the original landowner purchased deed and he had 6 or 9 kids, I can't remember. So I'm thinking he didn't wait too long to build. The staircase looks like it dates back to that time frame. He was also the first Commissioner for Smithville in Bastrop County and the head of some farmer coop. Also served in Company B of 4th Texas Cavalry and was later Quartermaster for the ExConfederates of Bastrop County. I'm with you on geeking out over the home history.
    aperezsh, Baja Mike and SomeGuy4 like this.
  3. Sep 10, 2020 at 6:02 PM
    #4083
    Outbound
    Aaron
    Northern Alberta
    I tested the new Nest Protect smoke detector out today by smoking up the house making smash burgers. Great success. I got a kick out of it when my phone alerted me that "Smoke is in the hallway. Check what's happening" before it started screaming at me. I was able to silence the Nest Protect before it went off. As the smoke cleared, the Nest sent another alert that "Smoke is clearing in the hallway".
    Pretty neat system. I'm convinced enough to buy a second one for the basement and eventually upgrade my thermostat and doorbell too.
  4. Sep 10, 2020 at 6:04 PM
    #4084
    TaquitoBandito
    Joel (AKA Bif)
    Oh yeah, they are great! Not cheap but a great purchase.
    Mmmmmm. Smash burgers...
    Outbound[QUOTED] likes this.
  5. Sep 10, 2020 at 6:14 PM
    #4085
    I covered the plants and winterized sprinklers for snow. ONE day of snow. Been in the 90’s and then had snow, now back to late 80’s. Oh, Colorado.
    2manytoys, Trooper2, SomeGuy4 and 2 others like this.
  6. Sep 10, 2020 at 6:19 PM
    #4086
    TaquitoBandito
    Joel (AKA Bif)
    I forgot to add that we have the thermostats, the doorbell, the front door lock, and the alarm system. It's all pretty awesome. The door lock is set up so when you unlock it with the code, it turns off the alarm. It's also set up so it will auto lock itself if you have it unlocked for more than 5 minutes.
  7. Sep 10, 2020 at 6:59 PM
    #4087
    Outbound
    Aaron
    Northern Alberta
    That's pretty cool. I hadn't really considered the door lock. Any idea how it would fair in -40 temperatures?
  8. Sep 10, 2020 at 8:25 PM
    #4088
    TaquitoBandito
    Joel (AKA Bif)
    I was like "-40 temperatures..?!" and then saw you are from Alberta. Damn.
    I found this "The Nest × Yale Lock is certified ANSI/BHMA A156. 36, Grade 2. It was designed to work in outside temperatures as cold as –22° and as hot as 140°F (–30° to 60°C)*. IP65 rating* - The Nest × Yale Lock can withstand dust, rain, and snow."
    https://support.google.com/googlenest/answer/9251009?hl=en
    I thought Northern Michigan got cold.
  9. Sep 10, 2020 at 9:09 PM
    #4089
    bobbilly
    bobbilly New Member
    Just an update to my earlier question on countertops. Appreciate all the input. The wife and I ultimate decided on quartz for the fact it’s what we(she) liked.
    Onwards to the next piece of the puzzle.
  10. Sep 10, 2020 at 9:26 PM
    #4090
    WAtundra4x4
    WAtundra4x4 Retired from active retirement.
    Den
    Wet side WA
    2018 Cement Tundra TRD crewmax limited
    Forward looking camera, Stub Antenna, 3M clearshield. A few other non lifted items.
    I have a portable back hoe that would be easier to move with another set of wheels. By having the wheels move down for a move I would not have to go through tHe process of moving the outriggers and swapping them. I purchased some square and round tubing, along with a hub, spindle and matching wheels. I dis some welding, painting and assembly. Attached are photos of my craftsmanship. The design is similar to another guys who did a YouTube video. I also added a bolt on thumb. 38244C89-EFFF-4B0B-AB38-C0679B77DE1D.jpgCA7A0F26-2ECA-4C78-9037-71867BC54D87.jpgF37A7469-6958-4879-9009-50941C84946D.jpg800BF0F9-EB73-4CBA-A67A-277E1595FCCC.jpg7408BDB5-14EA-4282-A88F-E03F9A56FDD8.jpgA933C3C2-9614-4898-9B87-C209B0152A4A.jpg82700B1E-089B-4EEA-BAE5-379A5D523E8B.jpg7FB45745-5482-42E3-8F71-409F47BB3C24.jpg
  11. Sep 11, 2020 at 4:56 AM
    #4091
    YorkT
    YorkT New Member
    I posted this picture way back in the spring of our ugly paneled I beam cover. After several outdoor projects, I could finally return to finishing the rec. room and got the new beam up. . I pretty much just have some trim work to do and then it is finally completed.
    Haggis777, FirstGenVol, drobb and 4 others like this.
  12. Sep 11, 2020 at 5:06 AM
    #4092
    Outbound
    Aaron
    Northern Alberta
    Yup, it gets cold here. It doesn't hit -40 often, but it does do it every year. -15F is pretty much standard for day time temps in January and February with nights dropping to -30F and -40. Then there's the cold snaps where -40F is the day time temp and we usually get 1 or 2 nights where it hits almost -60F.
  13. Sep 12, 2020 at 6:14 PM
    #4093
    Baja Mike
    Baja Mike Baja Aficionado
    South Bay, Ca.
    2016 Tundra TRD 4x4 SR5 white
    Painted the shed/barn.
    After:
  14. Sep 12, 2020 at 6:51 PM
    #4094
    Trooper2
    JR
    Houston, TX (Suburban South)
    Love these. Ours has a dark pink bloom that smells better that any perfume I have ever smelled. I wish we could bottle it, Lol
  15. Sep 12, 2020 at 7:55 PM
    #4095
    Darkness
    Darkness Allergic to white
    Luis
    All over SoCal
    The darkest
    It's really dark
    Yeah these, my pink and my white/yellow smell amazing. My white/pink/yellow doesn't have a scent at all, its odd.
    Trooper2[QUOTED] likes this.
  16. Sep 12, 2020 at 8:12 PM
    #4096
    Danimal86
    Daniel
    Sacramento, CA
    2017 White Tundra SR5
    Jesus, did you plastidip a shed?
  17. Sep 12, 2020 at 8:18 PM
    #4097
    Baja Mike
    South Bay, Ca.
    LOL. Just the base and corners. It's Behr exterior paint. Firecracker red with a matte finish.
  18. Sep 12, 2020 at 8:20 PM
    #4098
    Danimal86
    Daniel
    Sacramento, CA
    I saw the pladtidip cans in the before pictures and started to worry:eek2:
    Baja Mike[QUOTED] likes this.
  19. Sep 12, 2020 at 8:21 PM
    #4099
    Baja Mike
    South Bay, Ca.
    If I could have done the whole shed with two cans, I would have.
  20. Sep 13, 2020 at 6:21 PM
    #4100
    biebs96
    PA
    Not technically a home improvement, but it will be used within the home.
    stumbled upon some super nice oak scraps..
    after some cutting...
    and lots of sanding, and dremeling...
    and a bunch more sanding, all the way to 2000 grit..
    followed by a mineral oil bath..
    new kitchen spoons!
  21. Sep 14, 2020 at 3:55 AM
    #4101
    GiddyUp
    GiddyUp New Member
    Nathan
    2018 Tundra CM
    92D8AD57-F1D0-4803-801A-DD2F8B77C7A0.jpg Mud room improvements. On to the washer/dryer surround next. Then caulk, sand and paint.
  22. Sep 14, 2020 at 4:02 PM
    #4102
    GiddyUp
    GiddyUp New Member
    Nathan
    2018 Tundra CM
    And then... finished product. Build out around washer dryer is next.
  23. Sep 14, 2020 at 8:19 PM
    #4103
    ZPhilip
    ZPhilip Custom title here
    Philip
    West Chester, PA
    What did you use to paint this? Looks fantastic
  24. Sep 15, 2020 at 5:49 AM
    #4104
    GiddyUp
    GiddyUp New Member
    Nathan
    2018 Tundra CM
    I used Sherwin Williams Super Paint Satin with a 4” block brush and a whizz roller. It laid down real nice.
    My first career was with SW so if anyone has paint questions... I may have some info left in the brain bank.
    TaquitoBandito, saybng and GODZILLA like this.
  25. Sep 15, 2020 at 6:01 AM
    #4105
    DaBoro54
    DaBoro54 Beach Fisher
    Leveling kit, 285/70R18 EXOs
    Alright guys and gals. Been working on the house for about a month. Will go on the market in a week or so. Now to decide if we are going to list it or sell it ourselves.
    wish me luck
  26. Sep 15, 2020 at 8:21 AM
    #4106
    saybng
    saybng Just a member.
    Gary
    Ventura CA
    16 Tundra 1794 CM in BLACK!
    Goodluck:thumbsup::fingerscrossed:
    DaBoro54[QUOTED] likes this.
  27. Sep 15, 2020 at 4:20 PM
    #4107
    2010bigdog
    2010bigdog New Member
    Chuck
    Chicago
    2018 MGM SR5 TRD
    doing mine now. Trying to figure out how I want to lay it out
    GiddyUp[QUOTED] likes this.
  28. Sep 15, 2020 at 7:12 PM
    #4108
    OV-1794
    OV-1794 New Member
    Here is a few cabinet build pictures. Hoping to finish by the end of the week. The Blum undermount slides are nice but a PITA!
  29. Sep 15, 2020 at 7:25 PM
    #4109
    TaquitoBandito
    Joel (AKA Bif)
  30. Sep 16, 2020 at 6:41 AM
    #4110
    DaBoro54
    Figure I would add a little of what we have before and after .
    whole house is painted two and two new baths all down in the last 4 months
