  1. Sep 10, 2020 at 11:54 AM
    #7681
    Darkness
    Darkness Allergic to white
    Luis
    All over SoCal
    The darkest
    It's really dark
    ^ see those little star patterned bolts @Professional Hand Model ? Bet you'll find at least one missing or stripped because they used the wrong tool.
    bmf4069, NUDRAT[OP] and FrenchToasty like this.
  2. Sep 10, 2020 at 12:33 PM
    #7682
    ktundra
    ktundra rust be damned
    Lex
    NJ
    06 Tundra DC Limited 4WD
    Bilstein 5100
    Do you recommend going with the NGK iridium?
  3. Sep 10, 2020 at 12:34 PM
    #7683
    empty_lord
    Indiana, Chicagoland
    05 rollover special
    Well. I do that any time I do a t-belt
  4. Sep 10, 2020 at 12:34 PM
    #7684
    empty_lord
    05 rollover special
    Ngk or denso.
    ktundra[QUOTED] likes this.
  5. Sep 10, 2020 at 12:38 PM
    #7685
    ktundra
    Lex
    NJ
    Bilstein 5100
    You mean the Torx bolt on the camshaft?
    Darkness[QUOTED] likes this.
  6. Sep 10, 2020 at 12:50 PM
    #7686
    Darkness
    Luis
    All over SoCal
    The darkest
    It's really dark
    Torx is 6 point, do they make 5 point ones too?
  7. Sep 10, 2020 at 1:14 PM
    #7687
    I think it’s just called a 5 point torx or 5 point security bit?
  8. Sep 10, 2020 at 1:37 PM
    #7688
    Fred
    Hand Protectors
    Good thing because if you didn’t, that would have deducted 1 Feather Duster from your score.
    bmf4069 and Darkness like this.
  9. Sep 10, 2020 at 1:44 PM
    #7689
    Fred
    Hand Protectors
    From Studies, I think the truck @empty_lord pictured is VVTi?
    All the earlier gens do not have that thingy on the Cam Gears unless I skipped over a video removal of that part stuck on the Cam Gears with the star bolts. There will be something missing I’m sure and I’ll be on here bitching about it. :annoyed::rofl:
  10. Sep 10, 2020 at 1:45 PM
    #7690
    Spobrien84
    Spobrien84 New Member
    2006 Tundra limited
    any oil filter recommended? I seen it somewhere but can't find it
  11. Sep 10, 2020 at 1:46 PM
    #7691
    Fred
    Hand Protectors
    YZZD-3 costs about $4-5 at stealer.
  12. Sep 10, 2020 at 1:49 PM
    #7692
  13. Sep 10, 2020 at 2:02 PM
    #7693
    ktundra
    Lex
    NJ
    Bilstein 5100
  14. Sep 10, 2020 at 2:07 PM
    #7694
    Fred
    Hand Protectors
    2002-03 FSM lacks the thingys on the Cam Gear. Had to double check.
    Darkness and ktundra like this.
  15. Sep 10, 2020 at 2:22 PM
    #7695
    Darkness
    Luis
    All over SoCal
    The darkest
    It's really dark
    So you'll be missing at least one of those bolts! :rofl:or all of them
  16. Sep 10, 2020 at 2:32 PM
    #7696
    empty_lord
    05 rollover special
    ktundra likes this.
  17. Sep 10, 2020 at 2:37 PM
    #7697
    Fred
    Hand Protectors
    I’ve been using two sets of NGK Copper OEM Spec lately. Swapping them every 5k miles to inspect engine health. They run about $2.50-3 a plug even from autostores.
    Next set in a year or two, I’ll be using the Denso TT Iridiums. They are $$$.
  18. Sep 10, 2020 at 2:38 PM
    #7698
    Pucks18
    Pucks18 Fleabit peanut monkey
    2001 Tundra 4x4 Limited trd
    Do u inspect engine health by looking at the top of the piston for carbon build up?
  19. Sep 10, 2020 at 2:53 PM
    #7699
    Fred
    Hand Protectors
    According to @bmf4069 I need to check my cam journals for proper health, but thats kinda hard. :rofl:
    To answer your question, I look at the spark plug tips. Since taking over my maintenance, I’ve noticed my plugs not as oily with all the newer parts installed (ignition coils, injectors, synthetic oil, etc). I think the biggest plug improvement was after doing the o2 Sensors swap (all 4).
    I’ve only done 4 total plugs swaps so I’m still building a record. From readings, the o2 makes the best improvement in plugs. This is all assuming you do not have other problems like antifreeze in your oil. Check out an internet search on Spark Plug Health. Here is some info from the Gas Gurrls. :rofl:
    JessiJane06Tundra and bmf4069 like this.
  20. Sep 10, 2020 at 3:38 PM
    #7700
    ktundra
    Lex
    NJ
    Bilstein 5100
    Well, I managed to get the ever elusive lighter socket out. Not to escape without breaking something...
    FirstGenVol, Tundra2 and FrenchToasty like this.
  21. Sep 10, 2020 at 3:39 PM
    #7701
    I have the same gift as well
    bmf4069 likes this.
  22. Sep 10, 2020 at 3:44 PM
    #7702
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
  23. Sep 10, 2020 at 3:56 PM
    #7703
    ktundra
    Lex
    NJ
    Bilstein 5100
    Tundra2[QUOTED] likes this.
  24. Sep 10, 2020 at 4:03 PM
    #7704
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
    I tried that too, and it didn't work well for me.
    I think the type of plastic is weird. The glue never wanted to bond. Maybe yours will be better.
  25. Sep 10, 2020 at 4:07 PM
    #7705
    Fred
    Hand Protectors
    Goofy XM Radio Installers must have mangled mine back in 2003. They tacked on with some tacky clay type stuff. Didn’t realize their mangling until last year when replacing the bulb (did mine still in place through the ash tray). Ended up taking off that broken black trim and it looks fine without it. Not necessary unless you want it.
  26. Sep 10, 2020 at 4:26 PM
    #7706
    ktundra
    Lex
    NJ
    Bilstein 5100
    I retraced the steps to properly unmount it. This is a serious puzzle contraption. "Do you want to play a game?"
    1. Take out ashtray. Remove two screws that retain the ashtray bracket.
    2. Carefully pull down on ash tray bracket, which will be held back by lamp cable.
    3. Firmly push the plastic ash tray lamp connector to the side, like you will break it. It will actually pop out gracefully.
    4. You will now have access to back of lighter socket to the left. There is a black ringed shell that can be popped back with a nudge of a screwdriver. Push it back, out of the way. If you haven't turned off the car, do so now. You don't want to waste blowing a perfectly fine fuse.
    5. Using a screwdriver, you will nudge off the wire connector. It's shaped like an L. There is a small wedge that bridges the inside corner of the L. Use a screwdriver wedge it and back it off the lighter socket.
    6. Reach inside and rotate the lamp connector with fingers and pull off. If your goal is to change the bulb, you can stop here.
    7. To remove the socket from the dash, you will need to nudge out the inner metal sleeve (towards the cabin). In order to do that, you will see two L shaped openings inside the socket. There are small plastic tabs a the short part of the L (closest to cabin), use a small screwdriver to depress them a little, while you use your other hand to push out the socket from the back. Rock back and forth. Alternate pushing on the white tabs with the screwdriver. It will eventually push out.
    8. The white ring is left behind. There are two inside tabs that keep the ring from popping out, one at 12 o'clock, the other at 6 o'clock positions. Gently use a screwdriver and pry the 6 o'clock position from the front. Don't force too hard, or you end up cracking the black trim. Just pop out the bottom rim, a bit over 1/4".
    9. This is the tricky part. You will need to rotate the ring 180 degrees so that the 12 o'clock tab is position at 6 o'clock. Then try to push this out by hand from the back. You'll need to carefully angle out the white ring, as the lamp socket in the back will try and get in the way.
    To re-install, go backwards from the last step.
    bmf4069 and FrenchToasty[QUOTED] like this.
  27. Sep 10, 2020 at 4:28 PM
    #7707
    ktundra
    Lex
    NJ
    Bilstein 5100
    Ahh, you are right. It's like bakelite plastic, which is heat resistant, like the ashtray plastic. Gonna try PB epoxy.
  28. Sep 10, 2020 at 5:16 PM
    #7708
    Fred
    Hand Protectors
    Once I saw the video of a guy doing the 180° on the bulb socket I knew I could do it in place without removal and/or worse breakage. Lots of important wires running in through that juncture that affect other systems. High Risk Zone.
    Took me three tries until seeing the video and then it all clicked. 1 hours job tops after 3 fails (3-4hours in fails total).
    ktundra likes this.
  29. Sep 10, 2020 at 5:38 PM
    #7709
    empty_lord
    05 rollover special
    Got free wheels from a 08 prius. Put them on to get rid up f the stock steel wheels, put my old corollas leds in, and out the tundras horn on the corolla... I have to make a harness to put the other one on too..[​IMG] [​IMG]
    [​IMG] [​IMG]
    GODZILLA, bmf4069, NUDRAT[OP] and 3 others like this.
  30. Sep 10, 2020 at 7:33 PM
    #7710
    ktundra
    Lex
    NJ
    Bilstein 5100
    Regarding the ash tray lamp, do you guys also remove the green lens on the bracket if you are going to choose a white color?
    Just smash it out?
