Door check replacement
Discussion in '2nd Gen Tundras (2007-2013)' started by DVCNick, Sep 9, 2020.
  1. Sep 9, 2020 at 11:19 AM
    DVCNick
    DVCNick [OP] New Member
    2011 5.7 4x4 Double Cab
    So my driver's door has the "popping" noise when opening, and googling around I see it is the "door check" assembly that tensions the door at its various detent positions. Seems the most common issue is the bolts coming loose, but mine are tight and I can see that it is indeed broken.
    I see them online as cheap as $20 which I assume is not OEM. Then there are others for $60 or 80.
    Of course I want a reliable part but don't want to spend four times more than necessary... has anyone used the cheap ones with success?
    Here is another thread for reference:
    https://www.tundras.com/threads/dri...You can try and tighten,you'll shear the bolt.
    Two examples of the part at different prices:
    https://www.amazon.com/NewYall-Fron...-9120--8-1---2&vehicleName=2011+Toyota+Tundra
    https://www.amazon.com/Dorman-Solut...-9120--8-1---2&vehicleName=2011+Toyota+Tundra
  2. Sep 9, 2020 at 11:55 AM
    Rube207
    Rube207 New Member
    Rob
    Atlanta
    2010 Pyrite Mica Limited CM
    I bought a cheap one, and it is definitely not as nice as OEM. It fixed the noise of the broken one, but isn’t nearly as quiet as the other doors. I will buy OEM next time around.
    Mountun Goat and Rph74 like this.
  3. Sep 9, 2020 at 12:28 PM
    DVCNick
    Thanks!
  4. Sep 10, 2020 at 6:44 PM
    DVCNick
    Does anyone know of any specific instructions anywhere for taking off the 2nd gen driver's door trim panel? They are out there for 1st and 3rd gen easy to find; just want to make sure I don't miss or break anything.
  5. Sep 12, 2020 at 6:04 AM
    chinadog
    chinadog New Member
    Knoxvegas
    2018 Midnight Black Metallic 1794, 2013 Black Platinum
    I bought a OEM one from eBay through a toyota dealer. Cost about 60.00.
  6. Sep 12, 2020 at 9:03 AM
    iRenaissanceMan
    iRenaissanceMan New Member
    Yeah, looking at replacing both driver and passenger on mine. Damn, $120 is a lot of bones for the door. Probably going to get the generic or junkyard (if that's be even available)
  7. Sep 12, 2020 at 9:06 AM
    Dorks68
    Dorks68 New Member
    Derek
    2010 Rock Warrior
    I recently replaced my driver side door check with a $20 eBayer. It is working good. Developed a very slight sound 3 weeks after install. Nothing major though. IMO id go with the $20 part again vs OEM
    iRenaissanceMan likes this.
  8. Sep 12, 2020 at 1:39 PM
    iRenaissanceMan
    Thanks! Great to get your recommendation/review of how well the eBay one worked out.
  9. Sep 12, 2020 at 1:45 PM
    iRenaissanceMan
    Do you happen to have a link / brand you bought? I see the one from OP is generic for driver and passenger side. I thought they were unique?
  10. Sep 12, 2020 at 2:33 PM
    Dorks68
    Dorks68 New Member
    Derek
    2010 Rock Warrior
  11. Sep 12, 2020 at 6:35 PM
    DVCNick
    I already ordered the factory one for 87 bucks... Hopefully no issues at least.
  12. Sep 12, 2020 at 6:46 PM
    Yohan11
    Yohan11 New Member
    2012 MGM
    I replaced mine with the newer oem version 68620-0C023 on eBay for $55. It has a beefier collar design at the pin which I’m guessing solves this failure mode.
  13. Sep 13, 2020 at 3:25 PM
    iRenaissanceMan
    Anyone know the size of the nuts? Looks like I'm missing a few. :)
  14. Sep 13, 2020 at 5:11 PM
    DVCNick
    10mm... Not sure about the bolt size or threading though
  15. Sep 13, 2020 at 5:37 PM
    Rex Kramer
    Rex Kramer Vinyl Spinner
    Georgia
    I replace both of them on my '07, and I just noticed the passenger door check on my 2002 has started popping at 171k
  16. Sep 13, 2020 at 6:28 PM
    iRenaissanceMan
    Thanks. Yeah, looking for thread size so I can pick up new hardware from home Depot.
  17. Sep 13, 2020 at 7:19 PM
    swallace
    swallace Insert profound statement —> here <—
    Steven
    Tri-Cities, WA
    2014 Silver Sky Metallic CM 4.6L 4x4
    6112/5160, DD 10”, Amp steps, Alea leather, more…
    I had the same problem on my 2014. I replaced with Dorman brand which was around $60. I wasn’t happy. Didn’t feel or sound the same, and wasn’t smooth at all. I was disappointed because this wasn’t even a cheap $20 one. I returned it and am currently waiting for OEM one in the mail this week. If you want OEM feel, go OEM.
    Mattyc likes this.
  18. Sep 14, 2020 at 5:46 AM
    DVCNick
    Not sure why this didn't seem to pop up in my earlier searches but I have found a video specifically on the 2nd gen door trim removal:
    https://www.youtube.com/watch?v=chR6DiAk5rQ
    Now just waiting on the part to get in, and my truck to get back from paint correction.
  19. Sep 14, 2020 at 9:35 AM
    iRenaissanceMan
    Thanks!!
    DVCNick[QUOTED][OP] likes this.
  20. Sep 19, 2020 at 12:08 PM
    iRenaissanceMan
    Figured I'd report back in case anyone lost the nut there. Ended up buying M6-1.0 grade 8 nylon lock nut from Lowe's. They fit perfectly. U used a small washer to help spread the load. $1 total cost.
    DVCNick[OP] likes this.
  21. Sep 19, 2020 at 1:19 PM
    DVCNick
    I'll update mine as well... got the truck back this morning and did the swap a couple hours ago.
    Everything went well except removing the window switch housing. Watching the video above I was left with the impression that the front of that housing was on some sort of pivoting tab in notch or something, so I was trying to rotate it out lifting up the back first... wrong. the front and rear clips are the same, and so I broke off the front one. Ideally the entire thing should be lifted straight up.
    The good news is that the plastic trim piece with the broken clip appears to be screwed to an inner housing that actually contains all the switches and wiring, so should be able to replace it super easy without having to mess around with the actual switches or wiring. Even with one clip it is pretty tight though, so if the piece is expensive I probably won't bother.
    Popping is gone, so mission accomplished.
  22. Sep 19, 2020 at 1:37 PM
    iRenaissanceMan
    Dvcnick, did you buy OEM? If not, how do you like the generic?
  23. Sep 19, 2020 at 1:41 PM
    DVCNick
    I ended up buying OEM.
    There isn't even any grease on it and it feels right to me... guess I should put some on there anyway.
  24. Sep 19, 2020 at 1:46 PM
    iRenaissanceMan
    Funny. I looked at my truck and no grease. I have a brand new VW and looked there... Yup, all 4 door checks have a trail of grease. I'm gonna go lube up the truck's door checks now. :)
  25. Sep 19, 2020 at 1:47 PM
    DVCNick
    The rest of mine have some grease... I assume original from 2011.:cheers:
  26. Dec 7, 2020 at 8:58 AM
    ToyotaTundraMike
    ToyotaTundraMike Not A New Member
    2015 Tundra
  27. Apr 2, 2021 at 4:10 PM
    kenadavis
    kenadavis New Member
    Ken
    South Florida
    2006 Tundra Limited Access Cab
    Looks like this works for 2007 and up..
    Anyone know where to find this part for a first gen tundra (2006)?
    Not looking for oem.
  28. Apr 2, 2021 at 8:21 PM
    BlueCrushSC16
    BlueCrushSC16 New Member
    Charleston, SC
    Thanks for the info. I've been meaning to fix the popping from my drivers door.
  29. Apr 3, 2021 at 5:13 AM
    kenadavis
    Ken
    South Florida
    Read back a few posts. Some have said the popping issue was fixed with this part while others have said it didn’t fully fix it.
    Mine completely snapped a little while back when I backed in into my electric box with my driver door opened. Hyperextended my door and crunched it up pretty good. I’ve finally had the chance to fix the body and bend the hinges back into place to re-align the door. Now I’m just looking to replace the door check without spending another hundred bucks.
  30. Apr 6, 2021 at 9:16 AM
    WFD473
    WFD473 Long Live The V8
    Northeast Illinois
    2014 MGM SR5 CM 4x4
    My driver's door was making the popping sound over the last couple weeks. Was about to order a new door check, but thought I'd check and see if it was loose first. Lo and behold, both nuts were loose! Tightened them up and greased all 4. Smooth as butter now.
    NewImprovedRon likes this.
