  1. Sep 8, 2020 at 9:05 AM
    Professional Hand Model
    Fred
    Hand Protectors
    Last batch of parts ordered today. Been receiving some items ordered last week already. Getting stoked!:yes:
    NUDRAT, abcinv, ktundra and 1 other person like this.
  2. Sep 8, 2020 at 9:09 AM
    ktundra
    ktundra rust be damned
    Lex
    NJ
    06 Tundra DC Limited 4WD
    Bilstein 5100
    I was just thinking the same... that's what the doc ordered when they told me to fill the cup. :)
    shifty`[QUOTED] likes this.
  3. Sep 8, 2020 at 9:11 AM
    Pucks18
    Pucks18 Fleabit peanut monkey
    2001 Tundra 4x4 Limited trd
    What is the average price for paying someone to install a remote start system?
    theblurry1 likes this.
  4. Sep 8, 2020 at 9:14 AM
    ktundra
    Lex
    NJ
    Bilstein 5100
    I cringe when I see scotch locks used to tap into wiring, but this one installer depended on just twisting the wires together and taping them up. Removing the black tape from all over was the most annoying. Sticky goo all over the place.
    bmf4069 likes this.
  5. Sep 8, 2020 at 9:16 AM
    ktundra
    Lex
    NJ
    Bilstein 5100
    I've seen advertisements at around $100-$150 installed. Costs will go up if you need a transponder kit (keys with chip).
    For comparison, parts alone: basic Viper one-button kit runs $49, a step up gets remote trunk/accessory output, and power door locks for $79.
  6. Sep 8, 2020 at 9:48 AM
    Pucks18
    Yea I'm planning on going to best buy or some small owned business maybe too, and getting one installed for the tundra
  7. Sep 8, 2020 at 9:57 AM
    I've been out of the professional install world for 15-20 years, so you'll need to listen to @ktundra on this one.
    Scotchlocks are ass! I'm glad PosiLock entered the market to put a better product out. I just wish they made a right-angle tap-style product to make it easier to use with looms and in harnesses. Not ideal to have your tap perpendicular to a harness.
    bmf4069 likes this.
  8. Sep 8, 2020 at 10:04 AM
    Fred
    Hand Protectors
    Front Door Drop.
    Its the Aisin Fan Bracket ($109) and Heavy Duty Gates Accessory Belt ($34). The Bracket feels quality. The Belt is much stouter than the Basic Duty Continental ($21) one I put on 2 years ago. :yes:
    Thrussn, NUDRAT, abcinv and 4 others like this.
  9. Sep 8, 2020 at 10:57 AM
    ktundra
    Lex
    NJ
    Bilstein 5100
    Awesome, I see that you've got a 2001. They are fairly easy to wire up, no transponder, no fancy existing remote key entry / alarms to interface.
    I would try and get recommendations in your area from Yelp or perhaps Groupon and see how long they've been in business. All told, a reasonable install should run anywhere between $100 to $200. I'd ask if the installer will be using T-harnesses, soldered connections, or wire taps. Good shops will start with T-harnesses and soldered connections.
  10. Sep 8, 2020 at 11:01 AM
    I cringe just seeing them in general. I hate em.
  11. Sep 8, 2020 at 11:54 AM
    The amount of damage they do to wire casings and sometimes to the stranded wire is ridiculous!
    FrenchToasty and bmf4069[QUOTED] like this.
  12. Sep 8, 2020 at 4:52 PM
    CodyP
    CodyP Such a n00b
    Cody
    CDA, ID
    2006 Tundra 4x4 DC
    please don't use best buy to install anything on a vehicle....you're better off having Stevie Wonder do it.
    270Fan, 035VZFE, bmf4069 and 4 others like this.
  13. Sep 8, 2020 at 4:55 PM
    912
    912 @best_gen_tundra
    Fulltime RV traveler
    2005 DC 4x4
    But if you get Stevie to do it, you'd have the upside of meeting a legend and might even be able to talk him into a song or two. :rofl:
    bmf4069, Darkness, ktundra and 2 others like this.
  14. Sep 8, 2020 at 10:55 PM
    Ehernz1221
    Ehernz1221 New Member
    Ed
    03’ Tundra 5sp LB
    This is the 2003 I just picked up, this before pic is without the new OEM Green paint. Spray in bedliner and tool box, I had the interior covered in camp seat to match the exterior. Just keeping it simple but clean. Also went through and replaced a bunch of old cracked seals, added new suspension with a 2.0 level kit up front. It’s a 5 speed and only has 132k so she’s ready to drive. I’ll post pics of the after tomorrow.
  15. Sep 8, 2020 at 11:01 PM
    artsr2002
    artsr2002 2005 Tundra DC SR5
    'Yonder
    Took mine out to the local big blue box store for some siding panels. Took the long way around to get it up to normal operating temperature and gave it a bit of a workout. When I replaced the rotors a week or so ago, I noticed the end link bushings were pretty much gone. I have received new replacements and will be taking care of those soon.
  16. Sep 9, 2020 at 6:43 AM
    oscardog86
    oscardog86 New Member
    Southern California
    Nice find man, cant wait to see your pics of it after the paint job and upgrades! Is it 4x4? I have a manual Tundra as well, nice to see another one out there!
  17. Sep 9, 2020 at 10:14 AM
    Fred
    Hand Protectors
    Big Gurrl Aisin Water Pump/TB Kit came in today. High quality feel and finish on all parts. The WP is even stamped Aisin even though the description said it would not. Came with a nice instruction manual and a TB Stamp for putting under the hood for better resale tingles.
  18. Sep 9, 2020 at 10:18 AM
    Fred
    Hand Protectors
  19. Sep 9, 2020 at 10:21 AM
    Fred
    Hand Protectors
    Pretty cool clip system for these new water hoses. Looks like you slip them on and then pull the clip hold back clamp and they snap on to the spot you choose.
    theblurry1, ktundra and bmf4069 like this.
  20. Sep 9, 2020 at 10:24 AM
    Fred
    Hand Protectors
    The new Accessory Belt Tensioner looks redesigned.
    theblurry1 and bmf4069 like this.
  21. Sep 9, 2020 at 10:26 AM
    empty_lord
    Indiana, Chicagoland
    05 rollover special
    It was. And technically there’s a new ac bracket too. But you should be fine without it
  22. Sep 9, 2020 at 10:32 AM
    Fred
    Hand Protectors
    Reman’d Alternator.
    theblurry1, FrenchToasty and bmf4069 like this.
  23. Sep 9, 2020 at 10:49 AM
    Fred
    Hand Protectors
    Looks like AISIN Reccos their Special FIPG. Cross checking against the Toyota 103 and its the same shtuff?
    Lil Steve likes this.
  24. Sep 9, 2020 at 11:03 AM
    Fred
    Hand Protectors
    Yeah. Think I’ll Roll with the Toy 103 as I still have an entire tube from my valve Cover Job 2 years ago. The Goo is still Gooey in the tubey upon checking up on it.
    ktundra likes this.
  25. Sep 9, 2020 at 11:19 AM
    empty_lord
    05 rollover special
    Na. Toyota has special fipg for coolant contact. But from Toyota a tube is $80
  26. Sep 9, 2020 at 11:23 AM
    Fred
    Hand Protectors
    If you are saying not to use the Toy 103, then I’d chose to use the Aisin AB1207B.
    Unless the $80 shtuff is the only thing worth using? Seems steep and I’ll pay.
  27. Sep 9, 2020 at 11:38 AM
    w666
    w666 D. None of the above
    Maryland
    04 Access Cab SR5 V8 4WD
  28. Sep 9, 2020 at 12:13 PM
    empty_lord
    05 rollover special
    mths Aisin should work fine
  29. Sep 9, 2020 at 2:23 PM
    My Aisin timing belt kit came with a small tube of the sealant for the water pump. Enough to do it twice. Don't ask me how I know....
  30. Sep 9, 2020 at 2:28 PM
    Fred
    Hand Protectors
    I hope to not become as expert as you in this. :D
    NUDRAT, ktundra and Filthyphil like this.
