285/75/18 Will it Rub?
Discussion in 'Wheels & Tires' started by cdmagor, Aug 21, 2018.
  1. Jul 14, 2020 at 3:14 PM
    #61
    Haren_85
    Haren_85 New Member
    SR Adventure mobile, constant work in progress.
    The fronts were set at the top setting in these photos, I have since dropped it down one setting and I prefer it at that level. I don't know which add a leaf it is, had my buddy add that on for me. Love the set up, especially when I have the sway bar off if I am going to be on gravel/dirt roads predominately.
    jewsNbrews likes this.
  2. Jul 16, 2020 at 3:31 AM
    #62
    StoneyWV
    StoneyWV New Member
    Calvin
    2020 Tundra TRD Sport
    Rough Country Level,
    2020 Double Cab Sport with 1.75 Rough Country front level running 275/70/18 Falken Rubitreks and have zero rub because I used the +40mm offset rims. It is still close to mud flaps in front when at full lock and compressed but does not rub. An 18mm offset rim would rub on my truck even with this size tire when off road.Truck.jpg
    Sean492 likes this.
  3. Aug 13, 2020 at 3:44 PM
    #63
    COTundra23
    COTundra23 New Member
    Bumped up to 285/75 Falken Wildpeaks
    Y0TA PR0 likes this.
  4. Sep 3, 2020 at 7:07 AM
    #64
    COTundra23
    After spending some time on the setup for the last few weeks, I have to say, I am very impressed / happy. Given its E (vs my previous C rated) , i feel that this is the appropriate ply for this truck. The 275/70 I ran prior felt flimsy, but I never really noticed it until i bumped up to the larger / beefier tire. Definitely lost some acceleration, braking distance but not much.
    1rooster likes this.
  5. Sep 8, 2020 at 1:06 PM
    #65
    2019-1794
    2019-1794 New Member
    2019 1794 Crew Max 4x4
  6. Sep 8, 2020 at 1:20 PM
    #66
    19crewmaxTRD
    19crewmaxTRD Tundra Enthusiast
    Seth
    2019 white tundra crewmax
    Looks great. Any rubbing?
  7. Sep 8, 2020 at 1:21 PM
    #67
    2019-1794
    Nope I just had to bend the skid plate up and out of the way a bit and take off the front mud spats
  8. Sep 29, 2020 at 9:40 AM
    #68
    CorsoTundra
    CorsoTundra This is the way
    North GA
    2021 Cement Trail Edition
    Toytec Aluma 3/1.5, Pro headlights, OEM LED fog lights, AJT chrome delete, interior/exterior LEDs, front TRD sway, 18x9 Method Roosts, 285/75/18 Toyo A/T 3, RCI engine skid,
    Nice truck. How was the grille swap?
  9. Sep 29, 2020 at 10:07 AM
    #69
    Zero One Actual
    Just got Toyo MTs in 285/75R18 on 18 inch Method 315s with a +18 offset. Bilstein 6112s on top setting and Total Chaos UCAs. No rub anywhere.
    Kernal, Archive, EN2TUNDRA and 7 others like this.
  10. Sep 29, 2020 at 10:36 AM
    #70
    2019-1794
    Thanks, nothing to the swap, took about 15 minutes, just a few nuts and a couple pop rivets. You can get the garnish/sensor cover on eBay for about $50 so don’t buy the OEM one Toyota sells for $300
    #70
  11. Sep 29, 2020 at 10:37 AM
    #71
    CorsoTundra
    North GA
    Cool. Thanks. Good to know that's an option.
    #71
  12. Sep 29, 2020 at 12:14 PM
    #72
    tundra4466
    tundra4466 New Member
    2020 1794 4x4
    no cmc needed? I had the same tires on my last truck on factory wheels and they were fine after skid plate and plastic trimming. I just ordered some +18 methods and a 3/1.5 lift for the new one and was worried with the offset that they wouldn’t go without the chop.
  13. Sep 29, 2020 at 12:20 PM
    #73
    Samoan Thor
    Samoan Thor God is technically an alien
    Limited 2014 crewmax 4X4
    Kings F&R, no sway bars
    For those of you on 285/75/18, was there a noticeable difference in power loss? Did you regear? My truck needs bigger tires but the most i’d probably go is 285/75/18
  14. Sep 29, 2020 at 12:30 PM
    #74
    Zero One Actual
    I think as long as you have UCAs and get the alignment done, you should not have any issues. I have an RCI skidplate and no trimming was needed and I have no CMC. I’m sure if I’m driving above 15 mph and peg the wheel as far as it will go I can make it rub.
  15. Sep 29, 2020 at 12:33 PM
    #75
    tundra4466
    2020 1794 4x4
    great thanks, I have spc UCAs going on this one too so hopefully it’ll work. I’m not too hot on a cmc Yet with under 1k miles on the truck
    Zero One Actual likes this.
  16. Sep 30, 2020 at 7:54 AM
    #76
    2019-1794
    no need to regear, power loss wasn’t noticeable enough to worry about
  17. Sep 30, 2020 at 10:38 AM
    #77
    Zero One Actual
    I do not have dyno research or statistical data to show you, but the 5.7 will not notice the tire change power wise. Obviously it will result in lower MPGs but power will not be an issue when you push the gas pedal at all.
  18. Sep 30, 2020 at 10:42 AM
    #78
    tundra4466
    2020 1794 4x4
    Mine still had plenty of power on them. I did notice on the highway between 70-85mph my rpm were extremely low, maybe 11-1300 or so. I’m in flat country so it wasn’t an issue for me but if your in the hills you might have some tranny gear hunting going on at those speeds.
  19. Sep 30, 2020 at 10:49 AM
    #79
    jr1016
    jr1016 New Member
    Ric
    Sacramento, CA
    2020 CM TRD Sport
    The aftermarket garnish cover didn't give you any TSS issue? I don't understand how the OEM cover cost almost as much as the grille.
    #79
  20. Sep 30, 2020 at 11:17 AM
    #80
    2019-1794
    No issues. I’m not sure why it cost that much either. It’s literally just a piece of hard plastic that holds the sensor in place.
    BravoDeltaRomeo and jr1016 like this.
  21. Sep 30, 2020 at 3:41 PM
    #81
    CorsoTundra
    North GA
    the reviews on that cheapo version sensor say it doesn't work
  22. Sep 30, 2020 at 4:08 PM
    #82
    2019-1794
    I purchased mine from this guy. Works flawlessly.
    Ares customs dot com
    had to spell it that way the link won’t post in this thread.
    jr1016 likes this.
  23. Sep 30, 2020 at 5:53 PM
    #83
    Stumpjumper
    Stumpjumper Not a new member
    Fate, Tx
    2017 Tundra TSS 4x4
    Actually closer to 1/2" larger diameter
  24. Sep 30, 2020 at 8:59 PM
    #84
    Samoan Thor
  25. Sep 30, 2020 at 9:40 PM
    #85
    19crewmaxTRD
    Seth
    Do you need uca to run these tires on stock rims with no spacers?
  26. Oct 1, 2020 at 12:46 AM
    #86
    Zero One Actual
    That will depend on what lift you have if any. Then from there, forum members can help you out with a more solid answer.
  27. Oct 1, 2020 at 1:41 AM
    #87
    toyofan87
    toyofan87 Beer thirty
    Seth
    Gettysburg, Penna
    Any daytime pajama pixs???
    NVG's are dead... Thx
    Saltyhero13 likes this.
  28. Oct 1, 2020 at 5:57 AM
    #88
    Skey44
    Skey44 GreenvilleOverland
    Scott
    Greenville SC
    2018 GX 460
    Lift, tires, wheels, roof rack
    F3A33AA0-13C0-452A-BD7A-9E45E6DA268E.jpg These are doing awesome for me, but I’m still desiring more clearance. Front and rear bumpers on the way. This should help
    with my main clearance issues, which are approach and especially departure angles. Then there’s the pesky low gas tank.
    still digging the 285/75/r18 for “stock plus” style setup. Running stock rims and UCAs no problems. I did remove the front sway bar and am happy with that, though I have heavy spring rate front and rear. 55mm Dobinsons suspension lift front and rear. All around these tires in this size perform great on and off-road. Still no snow, but soon I’m sure. 12,000 miles on them. 15264E5D-3AEF-49C9-A94B-A95E2A60B9D5.jpg
  29. Oct 26, 2020 at 8:45 AM
    #89
    19crewmaxTRD
    Seth
    Placed my order for 285/75 r18s today. Getting installed tomorrow along with 5100s on top setting with 1/4 shims, wheeler add a leaf, and r1 slotted brakes with there performance pads. Keeping stock rims and UCAs, I’ll post a picture tomorrow afternoon.
    Skey44 likes this.
  30. Oct 27, 2020 at 5:14 PM
    #90
    19crewmaxTRD
    Seth
    Just pick up my truck.
    Specs
    stock Trd rims no spacer.
    Stock uca
    Bilstein 5100 top slot with 1/4” boss shim
    Wheelers single add a leaf in the rear.
    Only things modified on the truck were I trimmed the skid and removed the mud flaps front and rear
