5100 install on trd sport 4x4 cm
Discussion in 'Suspension' started by etodaceric, Sep 3, 2020.
  1. Sep 3, 2020 at 11:10 PM
    etodaceric
    etodaceric [OP] New Member
    Eric
    2020 tundra SR5 TRD Sport package CM 4x4
    about to install my bilstein 5100 s on my TRD SPORT 4x4 what setting do you recommend i hear the highest one makes it pretty stiff... just looking to level the truck and improve ride quality
  2. Sep 4, 2020 at 3:43 AM
    brobert225
    brobert225 Firm grasp of the obvious
    I went with second notch. Perfect.
    Zebruaj likes this.
  3. Sep 4, 2020 at 5:11 AM
    10TundraSR5
    10TundraSR5 Happy Tundra owner
    Tennessee
    2010 Black Tundra SR5
    Curse you Perry the Platypus!
    Same here. 2nd notch and no complaints!
  4. Sep 4, 2020 at 5:23 AM
    Second notch/ middle setting.
  5. Sep 4, 2020 at 5:39 AM
    brobert225
    Middle will leave you with a very slight rake which is ideal IMO.
  6. Sep 4, 2020 at 1:40 PM
    Longtimecoming07
    Longtimecoming07 New Member
    Rick
    2012 Toyota Tundra
    I’m running third notch kind of stiff I would do second
  7. Sep 4, 2020 at 1:43 PM
    brobert225
    Be sure to search for the Toyota FM for instructions on installing these. The YouTube wanna be videos are all over the place and will have you busting things apart that are not necessary....loosen the cams, drop the lower arm to the floor and install.
  8. Sep 4, 2020 at 2:10 PM
    ElwoodDowd
    ElwoodDowd New Member
    Rob
    N. Idaho
    2020 Calvary Blue Limited 4x4
    Middle Setting with one CB shim each side. Very nice ride.
  9. Sep 4, 2020 at 2:12 PM
    Blueknights75
    Ron
    Clayton, NC
    Top setting leveled mine perfectly which was what I was after. Ride is a little stiffer than OE setup but I did not want spacers thus top setting for me.
  10. Sep 6, 2020 at 5:31 PM
    BigArt
    BigArt New Member
    2008 Tundra Crewmax Limited
    IMG_1963.HEIC.jpg ordered mine off ebay and asked for 1" lift in front.
