  1. Sep 4, 2020 at 7:46 PM
    :hattip:
    **When you change it you need to swap the center tube. You need to put the one from the plastic cap into the metal cap so the filter isn't crushed. The one in the plastic is longer than the one in the metal one.
    booya69 likes this.
  2. Sep 4, 2020 at 7:55 PM
    Hartsy8
    Hartsy8 Resident Hockey Guy
    Max
    2020 MGM 1794
    Thank you, sir!
  3. Sep 4, 2020 at 7:56 PM
    :hattip:
  4. Sep 4, 2020 at 8:04 PM
    2020Platinum
    2020Platinum www.youtube.com/NitroZ18Fishing
    Patrick
    Northeast PA
    2022 TRD Pro (Lunar Rock)
    A lot. See my channel for all installs/mods!
    No prob man!...glad to see my videos are helping people out!
  5. Sep 4, 2020 at 8:15 PM
    sotex
    sotex Sic 'em Bears!
    Jeff
    San Antonio, TX
    2020 White Tundra SR5 Double Cab 4x2 SX
    Is like to see what the black looks like with stainless steel screws instead of the black screws.
  6. Sep 4, 2020 at 8:15 PM
    trowski
    trowski New Member
    Have a part number for that?
  7. Sep 4, 2020 at 8:18 PM
    Blue Thunder
    Washington
    Have people had that happen here? Crazy. I went with the metal simply because it's more robust.
  8. Sep 4, 2020 at 8:21 PM
    sotex
    Jeff
    San Antonio, TX
    Installed my Gator roll up tonneau. DD6AE026-B032-4297-A8E5-1ABC7AA3D771.jpg
    Ostrich, mgm16trdpro and Beesta like this.
  9. Sep 4, 2020 at 8:21 PM
    TILLY
    TILLY Gently Used Member
    Massachusetts
    2019 MGM TRD Sport D/C
    Pillslinger likes this.
  10. Sep 4, 2020 at 8:27 PM
    Yes
    Blue Thunder[QUOTED] likes this.
  11. Sep 4, 2020 at 11:17 PM
    DamirDa
    DamirDa MURICA
    I know this has been done to death but I'm finally doing it. ohh and yes it is Flat finish. I hated the stock wheels with a passion. $40 later here it is.
  12. Sep 5, 2020 at 5:31 AM
    GeoJoe
    GeoJoe 2018 Tundra SR 4x4 5.7L Looooooooong Bed
    3/1 lift on 20" OZs with KOs, LED fogs, steps and a handle
    Unloaded 3 yards of fresh compost. Can you smell it?
  13. Sep 5, 2020 at 6:12 AM
    Hongkongwongdonf
    Hongkongwongdonf New Member
    Will
    Gastonia, NC
    2017 tundra limited
    5% tint. Black rhino arsenal 20x9.5 295/55/20 KO2.
    I know it’s not the persons fault but I would be so mad.
    BoxersBrew[QUOTED] likes this.
  14. Sep 5, 2020 at 7:22 AM
    TelemarkTumalo
    TelemarkTumalo New Member
    Mark
    Bend, OR
    I took the truck in for the 2 year and final Toyota Care oil change. They did the two recalls as well. Turn signals and low pressure fuel pump. They changed the cabin air filter. All good.
    Blue Thunder, WILLINH and GODZILLA like this.
  15. Sep 5, 2020 at 8:15 AM
    surf760
    surf760 New Member
    Surf
    2020 tundra TRD sport
    Decided to go to a P rated Nitto terragrapler G2 for a better ride
  16. Sep 5, 2020 at 8:32 AM
    Saab95v6
    Saab95v6 New Member
    Just got done installing a TRD dual exhaust, was pretty easy, even tho no installation instructions were included in the box .
  17. Sep 5, 2020 at 9:27 AM
    SoileauThis
    SoileauThis New Member
    Louisiana
    2020 tundra platinum 4x4
    Lift and tires
    14726A4E-51CF-4ACD-B59E-67DFF429684C.jpg 3/1 leveling kit with 35s.
  18. Sep 5, 2020 at 9:28 AM
    Hartsy8
    Max
    2020 MGM 1794
    Looks cleannnnnn. Love how it sits! Which lift?
    PaulROahu likes this.
  19. Sep 5, 2020 at 9:42 AM
    SoileauThis
    Louisiana
    Lift and tires
    It’s a 3/1 ready lift
    Hartsy8[QUOTED] likes this.
  20. Sep 5, 2020 at 9:46 AM
    danno266
    danno266 n00b
    2016 White CM SR5/TRD OR
    You’re going to have to update us on how you like them once you get a few miles on em. Been looking at them too.
    surf760[QUOTED] likes this.
  21. Sep 5, 2020 at 9:52 AM
    BoxersBrew
    BoxersBrew New Member
    Thomas
    Northern Virginia
    2020 Black Tundra Limited Crewmax TRD
    Dealer installed TRD dual exhaust system and tonneau cover. Personally installed TRD Pro grille and surround, side mirror caps, and TRD shifter.
    I would've liked to go with P rated but wanted a wider tire. It's also nice to not worry as much going off road or over curbs, but each has its pros and cons. :cool:
  22. Sep 5, 2020 at 9:53 AM
    AThomas21
    AThomas21 New Member
    Forest Grove, OR
    2015 Toyota Tundra SR5 Crew Max Magnetic Gray
    6” Rough Country Lift 18” Black Rhino Rims 35x12.5 M/T Tires A.R.E Color Matched Canopy Interior LED Canopy Lighting Side Canopy Win-Doors Yakima Rack Custom Dual Exhaust w/ Flowmaster Super 10 Muffler K&N Cold Air Intake NFab Side Step Bars Black Fender Flares Paint Matched Grill Surround / Hood Bulge Blacked Out Badges Window Tint WeatherTech Window Rain Guards Interior AJT Design Blackout Kit
    Looks great!
    What seat covers are those? (assuming they are)
  23. Sep 5, 2020 at 9:55 AM
    Razorwyre
    Razorwyre New Member
    2018 Tundra Platinum
    Unless you are hardcore off roading or towing heavy, you will have no regrets. Better ride, better mileage.
    biebs96 and surf760[QUOTED] like this.
  24. Sep 5, 2020 at 10:27 AM
    65SNAKE
    65SNAKE New Member
    RON
    2020 TRD PRO
    Today...added a TRD sway bar and a TRD cold air intake. Checked the torque on the 1 1/2" Extreme Suspensions wheel spacers....found all lugs good. Washed and waxed.
    Beesta and Long Duck Dink like this.
  25. Sep 5, 2020 at 11:21 AM
    CDC4U3TRD
    CDC4U3TRD New Member
    2016 4U3 Tundra TRD
    Leveled, front bumper, LED headlight conversion. Soon - S&B Cold Air, Bilstein 6112/5160's, 35's.
    Just recently put the TRD Pro grille on with color matched hood bulge. Upgraded to LED headlight bulbs.(that took two sets of bulbs to get good ones in there. Do not buy Auxbeam bulbs). On the plus side, I am quite efficient at taking the front of the truck apart now. Anyone else deem the headlight bulb replacement process as an engineering fail on the 3rd gens versus the 2nd generations? It was a 10 minute process on the older trucks. Now the entire front of the truck has to come apart. I am currently hovering my itchy trigger finger on the "Buy" button for an SP-9100 system since I have a bunch of Diode Dynamics lighting on it's way to my house.
    65SNAKE and AggiePhil like this.
  26. Sep 5, 2020 at 11:33 AM
    Bakershack
    Kelly
    Spanish Fort, AL
    2020 SSM 1794 4x4
    What's to be jealous of? We ALL have Tundra's!
    Wallygator and Beesta like this.
  27. Sep 5, 2020 at 11:57 AM
    Elfine
    Elfine Doing my best to break this beast
    Pensacola, FL
    2017 Quicksand Tundra TRD
    Datin Metal Fab 18" Bed Rack, ARB Diff Breather, SDHQ ABS Guards, RCI Engine/Transmission/Fuel Skid, ICON Stage 5, Rago Bed Stiffener/Ditch light brackets, ARB twin air compressor, 295/70R18 Cooper Evolution M/T, Spydertrax 1.25" spacers
    Not done today, but I forgot to post it last week.
  28. Sep 5, 2020 at 12:11 PM
    AZTundra
    Paul
    Phoenix, AZ
    Installed another round of mods. Spidertrax 1.25" spacers on the front/rear. This eliminated the tire rub I had on both the upper control arm and the front sway bar. No more rub! Before/after shot of the tire to control arm clearance below. Also a picture of where it rubbed on the sway bar before the spacers. Installed pedal commander too which I'm pleased with. Still have my black door handles to install, but it's already too hot so that will get done tomorrow.
  29. Sep 5, 2020 at 1:36 PM
    AggiePhil
    College Station, TX
  30. Sep 5, 2020 at 3:50 PM
    Jcmf52
    Jcmf52 New Member
    Rob
    2018-1794 S/C
    Shorty antenna Trifold hard top tonneau cover Center console safe Center console tray Rhino liner TRD air filter TRD rear sway bar TRD front sway bar Center console wireless charger kit Remote start Black 4x4 emblem swap
    Nebz, Ostrich, Inquiringone and 4 others like this.
