  1. Sep 3, 2020 at 6:17 AM
    #7501
    I dunno, never had Seafoam do that to any vehicle I own. I've been using it for 2+ decades now across multiple vehicles.
    I had something stupid like this happen recently. After the factory alternator burned up, then caught fire, got replaced with a Denso reman alternator, I had my local shop do it because it happened the 2nd day into a 7-day work week where I was working 12-14 hour shifts every day, but I needed my truck STAT.
    Short story long, had a friend coming into town 3 weekends later. Had just driven somewhere an hour or so prior, parked. Friend called to pick him up at the train station, so I jumped back in the truck, turn the key forward ... everything went dead, the way a vehicle goes dead when the batt cable isn't tight. Like, when I pulled the key back out, then put it in, turned to ACC position, all-clocks-reset-to-12:00-type-dead.
    I tried 4-5 more times in succession, same result. So, frustrated and in a rush so I don't keep my friend waiting, I got out of the truck, popped the hood to check the cables. Cables were tight af. "WTF!??". Close the hood. Text my friend and tell him, "Truck won't start. Need a minute".
    Tried to figure out how I would diagnose this for the next couple of minutes. Then, still in disbelief since the truck has literally never failed me, I jumped in the truck and turned it over. Started up, no problem.
    That was like a year ago now. I still have no idea what the hell caused it. It made me nervous as shit b/c it felt very electrical-gremlin-ish to me. Coming such a short time after going to the mechanic, I also suspected maybe they didn't reattach a ground cable correctly, or didn't tighten something else enough when replacing the alternator, but my mechanic has never failed me before in this way. I'd never replaced an alternator on these trucks, so I wouldn't even know what fasteners to check.
    Anyway, it hasn't happened again. I still have no idea wtf that was about. I suspect alternator because it was the most recent thing. But who knows? (I wish I did) Best I can do is clutch at straws.
    Oh, and if anyone can think of what may have caused my issue, I'm all ears.
  2. Sep 3, 2020 at 6:24 AM
    #7502
    Do you pour it in the crankcase also? I've never had an issue putting it in the gas tank but this was the first time I ever added it to the crankcase.
    See that's different than what I experienced. My truck wouldn't roll over. It was trying to start but definitely seemed like it wasn't getting any fuel. When it finally started it sounded horrible! It made noises I've never heard before.
  3. Sep 3, 2020 at 6:32 AM
    #7503
    Usually a couple hundred miles before oil changes, via the oil fill cap. Had a conversation with someone on here (Pucks?) about this some time back because of a "wtf? you put that in your oil? that sounds like a bad idea!" type comment. I linked him up with the Project Farm YouTube video since that guy does such a great job of showing off the product and how well it works applied to gas, oil and intake.
    Yeah, when I read your post, it sounded like yours was cranking at least, mine wouldn't even begin to turn over. Like, when I kicked the key from ACC all the way forward into the start position, everything went dead. It felt very much like what happens if you don't have enough juice left in a battery, you see your accessory lights come on, but the second your vehicle needs to pull those extra amps *POOF* it all goes dark. Pull the key out, re-insert, turn to ACC, everything in the dash lit up, kick it forward to start, *POOF* it all goes dark again.
    Two totally different cases, I only mention it because of the one similarity: It happened unexpectedly, out of the blue, less than 50-100 miles after a major service event (alternator replace), shortly after I'd just driven somewhere and the truck was sitting for 30-60 minutes, and it's never happened again since. I blamed the alternator install at first, but held off on accusing my mechanic until I could fathom why, and check all of the connections they would've touched. But it never happened again, so I never bothered.
    But I still have that eating at the back of my mind. And I'd still love to understand what connections they would've touched related to power, so I can double-check eventually. Don't want anything arc'ing out.
  4. Sep 3, 2020 at 6:53 AM
    #7504
    Hi06silver
    Hi06silver Fat. Thumbs.
    2006 DC 4x4 Waltrip
    Wow, that is scary! So what's the best solution other than driving with hi beams on? A light bar? I want a set of these retros but I don't believe I'll get flashed any less than I already do if I run hi beams more than necessary. I suppose this isn't quite as big an issue driving in the city
  5. Sep 3, 2020 at 7:00 AM
    #7505
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
    I have a light bar tied into the high beams.
    With the old light scattering leds I could see the headlights in the light bar beam. Now it all blends together for improved long distance sight.
    I need to figure out how to run my fogs with the high beams to get more "immediate" light.
  6. Sep 3, 2020 at 7:08 AM
    #7506
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
  7. Sep 3, 2020 at 7:29 AM
    #7507
    Is it just me or is your truck favoring the driver's side in a lil' gangsta lean?
  8. Sep 3, 2020 at 8:05 AM
    #7508
    Pucks18
    Pucks18 Fleabit peanut monkey
    2001 Tundra 4x4 Limited trd
    Favorite part of owning a 1st gen is when I'm pulling out of a parking lot and that big ol radiator fan gets to screaming when I'm in 1st gear. Have always loved that noise
    bmf4069 likes this.
  9. Sep 3, 2020 at 8:09 AM
    #7509
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
    It might be just a wee bit. Could be the parking lot too.
    Could be that my fat ass has already worn out the new strut :rofl:
    Darkness and bmf4069 like this.
  10. Sep 3, 2020 at 8:33 AM
    #7510
    Pucks18
    Highly doubt it tbh
    speedtre likes this.
  11. Sep 3, 2020 at 8:39 AM
    #7511
    You may be right but the timing is suspicious. It happened almost immediately after I added the Seafoam. I found all kinds of comments on reddit from mechanics saying they would use caution on older engines. Others swore it was perfectly safe. Who knows :notsure:
    Tundra2 likes this.
  12. Sep 3, 2020 at 8:48 AM
    #7512
    speedtre
    speedtre New Member
    Inland Northwest
    There is virtually no chance the seafoam caused that if you only put it in the crankcase and gas tank (at recommended levels)....now if you did the the vacuum intake procedure with it, then I'd say your suspicion would be significantly more warranted...
    bmf4069 and FirstGenVol[QUOTED] like this.
  13. Sep 3, 2020 at 9:02 AM
    #7513
    Fair enough. I'll have to form a new hypothesis. :monocle:Hopefully it was a fluke.
    speedtre[QUOTED] likes this.
  14. Sep 3, 2020 at 10:38 AM
    #7514
    Lil Steve
    Lil Steve Living the dream
    Gilbert, AZ
    Is that a bird in that Taco front grill?
  15. Sep 3, 2020 at 11:41 AM
    #7515
    empty_lord
    Indiana, Chicagoland
    05 rollover special
    2020 taco fogs with 1 mile i got for free because it got upgraded to factory LED fogs. For the corolla bumper perfectly, now to locate trim
    Lil Steve, Darkness, bmf4069 and 2 others like this.
  16. Sep 3, 2020 at 1:16 PM
    #7516
    CodyP
    CodyP Such a n00b
    Cody
    CDA, ID
    2006 Tundra 4x4 DC
    Laughed when I saw this walking out of Home Depot yesterday.
    Husband sitting in the passenger seat like a nanny and overtired child laying on the truck roof with a lollipop waiting for mommy to finish loading and securing everything. Lol.
    Oh and apparently due to her shirt she’s a winner hahaha
    Tacoma so it’s at least Toyota related lol
    NUDRAT[OP], Darkness, ktundra and 2 others like this.
  17. Sep 3, 2020 at 1:46 PM
    #7517
    Professional Hand Model
    Fred
    Hand Protectors
    Just looking for affirmation per the best Timing Belt Kit.
    Many here have recco’d the Aisin Kit on Big Gurrl. Reviews look solid, except a few saying the Water Pump Failed before 10k miles. Installer error?
    TBK has a nice kit which costs a few more dollars. The water pump is not Aisin, but is NTN which makes most Japanese Pumps.
    Coming in at twice the cost (apples to apples) over the others mentioned is the Stealer. There are a few other items outside of TB which will need purchasing from Stealer which cannot be obtained elsewhere and is not negotiable.
    What say you?
  18. Sep 3, 2020 at 2:04 PM
    #7518
    Pucks18
    Duralast by far
  19. Sep 3, 2020 at 2:23 PM
    #7519
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
    Sure is. My co-worker likes to rip, and tear down roads. I tell him his luck is going to run out one day, and it doesn't matter what kinda schmancy smensnors you've got, "luck will not be on your side."
    Lil Steve[QUOTED] likes this.
  20. Sep 3, 2020 at 2:44 PM
    #7520
    Fred
    Hand Protectors
    Yeah. I was thinking autozoned as a close second. :rolleyes:
    Lil Steve and FirstGenVol like this.
  21. Sep 3, 2020 at 3:11 PM
    #7521
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
  22. Sep 3, 2020 at 3:22 PM
    #7522
    Fred
    Hand Protectors
    Locked and loaded in all my carts. Waiting for Labor Day Sales and Promos to drop. :yes:
    The tricky AlgoreRythms raise the prices right before a long weekend. They also make it hard to find your usual preferences by moving them around. :annoyed:
    NUDRAT[OP] and Tundra2 like this.
  23. Sep 3, 2020 at 3:56 PM
    #7523
    ktundra
    ktundra rust be damned
    Lex
    NJ
    06 Tundra DC Limited 4WD
    Bilstein 5100
    This guy's tb/wp kits are supposed to be the definitive source, he sources all his kits with genuine parts and allegedly beats all the discounted $tealers.
    It has the Aisin OE water pump. He's pretty quick to answer any questions you might have. eBay username aircabinman
    https://www.ebay.com/itm/COMPLETE-T...4-7-Genuine-OE-Manufacture-Parts/120805008417
  24. Sep 3, 2020 at 5:07 PM
    #7524
    Toyotundra06
    Toyotundra06 New Member
    Donald
    2006 Silver Tundra Access Cab
    Is there any possible reason why a double cab center console wouldn't fit in an access cab?
  25. Sep 3, 2020 at 5:29 PM
    #7525
    Darkness
    Darkness Allergic to white
    Luis
    All over SoCal
    The darkest
    It's really dark
    Don't ask how he harvests and stores that Caribbean breeze :rofl:
    bmf4069[QUOTED] likes this.
  26. Sep 3, 2020 at 5:41 PM
    #7526
    NUDRAT
    NUDRAT [OP] 6 lug life
    SW CT
    Between 'Ridgelines'
    I thought double cab was wider than access cab. If I have that right, you'll need to know if the seats are wider or the consol.
  27. Sep 3, 2020 at 5:41 PM
    #7527
    Darkness
    Luis
    All over SoCal
    The darkest
    It's really dark
    Unfortunately I see this sort of thing all the time. Every other time I hit a gas station I see a woman pumping gas while the dude is sitting on his phone. I see it at Home Depot and stores in general a lot too, I just don't get it.
    Maybe I really am old.
    bmf4069 and CodyP[QUOTED] like this.
  28. Sep 3, 2020 at 5:43 PM
    #7528
    NUDRAT
    SW CT
    ERA baby!
    Women are equal & no different from men.
  29. Sep 3, 2020 at 5:44 PM
    #7529
    Fred
    Hand Protectors
    Feels good having all my homework done. Printed up all the FSM Timing Belt Pages. Been studying Faraday Cages and it gives me hope on just leaving my Crank Sensor nick alone as it was repaired the other day. Basically, as long as there is still adequate shielding in place (even when nicked) AND the shield is still grounded properly then the interference will be blocked. At least this is my hope. :D
    Truck has been running great and I’m hesitant to go splicing wires (breaking the full shield/ground) and causing a mangle event.
    bmf4069 and ktundra like this.
  30. Sep 3, 2020 at 5:48 PM
    #7530
    Bro, that last one ain't helping, that's a Nicolas Cage. It might help a little bit, but it doesn't even start with the same letter.
