Rim is hitting the brake caliper
Discussion in '2.5 Gen Tundras (2014-2021)' started by Local46er, Mar 1, 2017.
  1. Mar 1, 2017 at 9:19 AM
    Local46er
    Local46er [OP] New Member
    Neil
    Ontario Canada
    2016 Tundra SR5 TRD double cab
    The shop just called and said the rim is hitting the brake caliper. Does this mean the the rim offset is wrong. Please help.
    Nightmare
  2. Mar 1, 2017 at 9:21 AM
    joonbug
    joonbug °°°°°°°°°°
    Joon
    NorCal - Dublin
    2020 LT DC
    What brand wheel? Size and offset? Is it a 17?
  3. Mar 1, 2017 at 9:22 AM
    Maddsilence
    Maddsilence New Member
    2017 MGM SR5 Tundra
    What size rims / offset are you running?
  4. Mar 1, 2017 at 9:22 AM
    Netmonkey
    Netmonkey Don't be a Dumbass
    Georgetown, TX
    are they aftermarket wheels or factory wheels? which package do you have on your truck (pro, limited, platinum, etc..)? if your truck is under warranty, i would take it back to the dealer.
    Bob likes this.
  5. Mar 1, 2017 at 9:23 AM
    TheBeast
    TheBeast The Beach
  6. Mar 1, 2017 at 9:30 AM
    Local46er
    Neil
    Ontario Canada
  7. Mar 1, 2017 at 9:32 AM
    Netmonkey
    Georgetown, TX
  8. Mar 1, 2017 at 9:32 AM
    joonbug
    joonbug °°°°°°°°°°
    Joon
    NorCal - Dublin
    2020 LT DC
    whats the offset?
  9. Mar 1, 2017 at 1:13 PM
    Local46er
    Neil
    Ontario Canada
    Guys what a day. The issue is because of the spoke design on the chaos wheel. Any other wheel from mayhem will work. If I didn't have bad luck I wouldn't have any luck.
  10. Mar 1, 2017 at 1:25 PM
    Local46er
    Neil
    Ontario Canada
    Ended up under the gun and had to go with the mayhem Warrior black in colour.
  11. Mar 1, 2017 at 1:27 PM
    joem1cha3l
    joem1cha3l New Member
    Albany, NY
    2016 Double Cab SR5 Blazing Blue Pearl
    BOSS Suspension, DB Customz Grill, 35's, Spyder, Tint, Color matched corners
    Are you going to get a refund on the others Neil? Hope so. Sorry to hear about your bad luck.
  12. Mar 1, 2017 at 4:44 PM
    TheBeast
    TheBeast The Beach
    looks good too. now relax, pour yourself a glass and post pictures :)
  13. Mar 1, 2017 at 6:29 PM
    Local46er
    Neil
    Ontario Canada
    Yes the shop I purchased them from said bring them back for full refund. Just out the $ for the balancing of the new wheels.
    joem1cha3l[QUOTED] likes this.
  14. Mar 1, 2017 at 6:32 PM
    blue16
    blue16 New Member
    steve
    Mesa AZ
    2016 tundra
    That is good looking wheel
    GNTundra likes this.
