How screwed am I???? Please advise
Discussion in '1st Gen Tundras (2000-2006)' started by fighthedude, Sep 1, 2020.
  1. Sep 1, 2020 at 10:10 AM
    fighthedude
    fighthedude [OP] New Member
    I went under rig to attack pinch weld job and noticed grease slung on both inner CV boots. I assume from angle of new lift. Boots don't appear torn. Probably 500 miles on new lift. Coming from the inside, closest to midline of truck. Supposed to drive the truck 1200 miles sat. Any help or suggestions. ThanksA9CE8483-330F-4595-80C8-AF250A642E11.jpg68779CEA-30CC-4E6E-9ED7-9A4FFBF5248A.jpg
  2. Sep 1, 2020 at 10:14 AM
    Casper421
    In the woods
    06 DC
    Clips failed and the boot slid. Happens after you lift and the cv angles change which increase the range of movement of the joints. Easiest fix is a new hose clamp and some new grease.
  3. Sep 1, 2020 at 10:14 AM
    timsp8
    NY
    Probably have to take off the boot, regrease and reseal it. Or get new cv axles. Does anyone make a diff drop kit for 1st gen? If not the issue could/will happen again.
  4. Sep 1, 2020 at 10:18 AM
    BlackSheep
    BlackSheep ol’ Reliable
    Scott
    Kansas City, MO
    2010 Black DC 5.7L 4x4
    2.5” shocks, 3/1 level, 37s, 5.29s, air locker, on-board air, bed cap, bed stiffeners, roof rack, steps/sliders, spare carrier, under seat storage bins, window tint
    I lost a fair amount of grease from my lower ball joints after installing 3" lift coilovers. I posted a thread similar to yours and guys told me not to panic, that the joints were just getting used to their new angle. I wiped off the grease a couple times and kept an eye on the joints, and they soon quit losing it. That was about 18 months and 14k miles ago, and everything seems fine now. So, I want to say to not panic. Clean it off, drive it around a bit, keep an eye on it, and see if it continues, or starts to subside.
    Luckydog likes this.
  5. Sep 1, 2020 at 10:23 AM
    rock climber
    rock climber New Member
    2001 Sequoia 4X4, 2000 AC 4X4
    Just re-strap the boots and you'll be fine. Not enough grease loss to be worried about it.
    snivilous likes this.
  6. Sep 1, 2020 at 10:30 AM
    snivilous
    snivilous snivspeedshop.com
    SW UT
    300k+ Supercharged 2008
    That^ put a hose clamp on it and don't sweat it.
  7. Sep 1, 2020 at 10:40 AM
    fighthedude
    Im stressing boys. Seems like a lot of grease.
  8. Sep 1, 2020 at 10:55 AM
    Kimosabe
    Kimosabe Slacker
    Sun Valley, Idaho
    06 Tundra DC TRD 4WD
    It's not that much grease. As others have said, it's the lift changing the angles and the components adjusting to the new normal. Keep an eye on them and re-strap if the clamps are gone and you'll be fine.
  9. Sep 1, 2020 at 11:01 AM
    Darkness
    Darkness Allergic to white
    Luis
    All over SoCal
    The darkest
    It's really dark
    I would do what @Casper421 said. Pop off the failed clamps, pull the boot back to throw some grease in to replace what spilled, then put on new clamps. Look up CV boot mods.
    FirstGenVol, bmf4069 and Casper421 like this.
  10. Sep 1, 2020 at 11:05 AM
    Casper421
    In the woods
    06 DC
    Look for the ear type clams instead of the generic screw type. I’ve heard some say they felt the “extra weight” of the screw mechanism when driving. I’ve used the screw type in the past and didn’t feel anything. Either will work fine.
    Darkness[QUOTED] likes this.
  11. Sep 1, 2020 at 11:12 AM
    fighthedude
    Thanks men
  12. Sep 1, 2020 at 11:26 AM
    Fourknights
    Fourknights Goin Coastal
    Georgia/Florida
    2019 sr double cab 4x4 5.7
    Coverking ballistic seat covers, dipped 4x4 emblem, intermittent wiper mod, Toyota bed mat, Toyota rear under seat storage, dirty deeds budget, icon rebound 17”, bfg ko2s 285/70/17, matte black uws low profile toolbox, grill surround painted matte black
    Mine did the same thing after lift and diff drop. I got clamps from Napa, along with grease. Just need tool for clamp.
  13. Sep 1, 2020 at 11:31 AM
    Tundradrenalin
    Tundradrenalin New Member
    Virginia Beach, VA
    2016 DC Black TRD nonPRO
    Methods, Toyos, Kings, TCs, CBs
    don't need any special clamps or tools.
    just regular hose clamps work just fine. anyone that says otherwise is new here.
    edit: here are some photos of exactly what you should do. And the exact clamps I used when I did this 12 years ago.
    Darkness likes this.
  14. Sep 1, 2020 at 11:56 PM
    IEsurfer
    IEsurfer New Member
    jimbo
    Socal
    2005 tundra 4x4
    I have/had the same issue!
  15. Sep 2, 2020 at 3:35 AM
    You should be fine if you take their advice. That's an OEM axle I think. They last a long time. That pink and white sticker is what they put on the Toyota axles.
  16. Sep 2, 2020 at 4:07 AM
    brobert225
    brobert225 Firm grasp of the obvious
    How muck did you lift it?
  17. Sep 2, 2020 at 6:41 AM
    Fourknights
    Georgia/Florida
    Hose clamps will suffice. But the proper cv axle style clamp are superior for this application.
    TRDblvd likes this.
  18. Sep 2, 2020 at 6:54 AM
    Professional Hand Model
    Fred
    Hand Protectors
    I’d not worry much about this situation during your long trip. Put some new banding on when you get back.
  19. Sep 2, 2020 at 9:23 AM
    fighthedude
    Update. Drove roughly 175 freeway miles yesterday after wiping down. Very little grease on one side. No grease was slung on the other. Think I am out of grease or they are settled into new positions?649A8F09-0735-44BC-853B-E2E9EE56D77E.jpg7AD69189-6DB2-4324-9643-4AA5A8A5F768.jpg
  20. Sep 2, 2020 at 9:24 AM
    brobert225
    Use the marine hose clamps which are heavier. Not so secret secret from FJ community.
  21. Sep 2, 2020 at 10:02 AM
    fighthedude
    Need a tool to remove the old clamps i assume?
  22. Sep 2, 2020 at 11:37 AM
    Fourknights
    Georgia/Florida
    Carefully cut off or bend ears with wire cutters
  23. Sep 2, 2020 at 1:58 PM
    fighthedude
    When you guys put new clamps on did you do it with truck on ground, truck on jack or jack under lower control arm to keep it little more flat?
  24. Sep 3, 2020 at 5:23 AM
    Tundradrenalin
    Virginia Beach, VA
    on the ground. doesn't really matter. as long as you have good access. may as well inspect the boot while you're underneath. make sure it's not crimped/pinched also.
    last time I rebuilt 1gen axles they were off the truck, lots of access there :D
