mounting tires on rock warrior wheels
Discussion in 'Wheels & Tires' started by chop123, Aug 8, 2017.
  1. Aug 8, 2017 at 1:32 PM
    chop123
    chop123 [OP] New Member
    clifton
    2007 dark green tundra sr5
    It is almost time to start shopping for new tires,i have a question when mounting new tires on rock warrior wheels do you all suggest the rings being removed or can they be taped up?what about the balancing?thanks
  2. Aug 8, 2017 at 1:38 PM
    TXMiamiFan
    Jose
    2016 White Crew Max TRD
    Paging @csuviper
  3. Aug 8, 2017 at 1:42 PM
    14burrito
    14burrito IG @14burrito
    2014 SR5 CM 4x4 5.7
    Discount has always removed mine,
    With that said,
    Last time they did not tighten all the screws down tight and I'm missing a few on each wheel.
    I bought my spare wheel rings from a gentlemen who discount damaged his wheel rings and forked out to buy him a new set.
  4. Aug 8, 2017 at 1:45 PM
    csuviper
    Broomfield, CO
    2019 TRD Sport CM 5.7L 4X4
    They have to be removed to get the tire on and off. Its best if you do it so they dont f them up.
    I had plastidip on mine at one point and it was all messed up after they changed a flat.
    Have mine completely off at the moment in the "need to find time to get them powedercoated" stage.
  5. Sep 3, 2020 at 4:56 AM
    Genuine Cooling Systems
    Genuine Cooling Systems New Member Vendor
    Can you put your own tire on with rock warrior rims? Since it is a bead lock i was thinking of just having pushing the tires on myself after I take off the bead lock ring.
