Retrofit headlight out
Discussion in 'Lighting' started by Worriedman50, Sep 2, 2020.
  1. Sep 2, 2020 at 5:43 AM
    Worriedman50
    Worriedman50 [OP] New Member
    Richard
    West TN
    2015 Tundra Crewmax
    TRD Rear Sway Bar , 6112 front 5160 rear shocks, Retrofit Projector Headlights, Rear LED bumper lights lights, FRAC harness and front camera, TRD Pro Grill and color matched hood bulge.
    I hope this is simply a bulb burned out...
    Any way to check if it is a bulb or ballast outside of pulling the headlights and swapping bulbs to see if it is the problem?
  2. Sep 2, 2020 at 3:54 PM
    BrandonL812
    BrandonL812 New Member
    Brandon
    2021 Tundra Platinum
    Both side out or just 1?
    Swap the known good ballast for the bad side.
  3. Sep 2, 2020 at 5:21 PM
    Worriedman50
    Richard
    West TN
    2015 Tundra Crewmax
    Just one side, I swapped it and it is the bulb, got them ordered...I will not be caught without spares from now on...
    BrandonL812 likes this.
  4. Sep 2, 2020 at 5:33 PM
    BrandonL812
    Brandon
    Which brand bulb did you went with? The osram laser is on my list.
  5. Sep 2, 2020 at 7:18 PM
    Worriedman50
    Richard
    West TN
    2015 Tundra Crewmax
    Morimotos again...
