  1. Sep 1, 2020 at 2:56 PM
    ElNopal
    Willis TX
    19 Cavalry Blue CM
    ^^^This appeared to be faster... as yours have arrived already.
    I did a PM here @rrentrop
    jr1016[QUOTED] likes this.
  2. Sep 1, 2020 at 2:58 PM
    CorsoTundra
    CorsoTundra This is the way
    North GA
    2021 Cement Trail Edition
    Toytec Aluma 3/1.5, Pro headlights, OEM LED fog lights, AJT chrome delete, interior/exterior LEDs, front TRD sway, 18x9 Method Roosts, 285/75/18 Toyo A/T 3, RCI engine skid,
    Some key fob action
  3. Sep 1, 2020 at 3:36 PM
    jclaffee
    jclaffee New Member
    Durango, CO
    What's the brown/rust colored piece (with the blue mark on it) immediately above the top of the spring coil in this pic?
  4. Sep 1, 2020 at 4:01 PM
    RobertD
    Robert
    DFW, Texas
    Nice bottle opener!
    biebs96 likes this.
  5. Sep 1, 2020 at 4:17 PM
    abomb60
    abomb60 Maker of things
    Massachusetts
    2018 Tundra 1794 MGM
    Not sure it deserves an entire write up but the quick version is:
    1. In the bed there is a Yeti 400 that I can power from 12v (see #2), solar panels (100W on tonneau cover and 2 other panels I can deploy if needed) or from AC power (#3).
    2. 12v DC power runs from main battery to bed. Ran above frame rails to left corner of bed (from rear looking forward). This is 12v always on power (not ignition switched) for the Yeti 400 when the truck is running (their 12v battery charger for the Yeti has battery run down protection in case you leave it plugged in).
    3. AC power comes in from the shore power plug in the bumper and a 3 outlet powerstrip in the bed connects to this. The Yeti 400 AC adapter plugs into this so when I plug in an extension cord off it goes to charge.
    4. My Dometic fridge plugs directly into the Yeti 400 and is fed only off 12v power (although I could also plug the Dometic into the AC powerstrip as well and it would runoff that when I connect shore power and switch to DC when it needs to .. I might as well do this).
    PM me if you have any questions and i'll do my best to help ya out!
  6. Sep 1, 2020 at 4:47 PM
    Tigereye
    Tigereye New Member
    Eric
    2019 SSM Limited
    bed liner, diamondback se, level kit, nitto ridge grapplers,tufskinz letters, grab handle
    What's the deal with the key fob?
  7. Sep 1, 2020 at 4:50 PM
    I like how you think.:thumbsup:
    @Roman that's what you meant, right.
  8. Sep 1, 2020 at 4:51 PM
    Great idea.:thumbsup:
    ElNopal likes this.
  9. Sep 1, 2020 at 4:51 PM
    Sorry. :rofl:
  10. Sep 1, 2020 at 4:52 PM
    Send him a PM.
  11. Sep 1, 2020 at 4:55 PM
    CorsoTundra
    North GA
    Thanks. Got it in 2017 when I had my 17 Cement TRD Pro 4runner. Its from a company called yotateq. I don't think they make it anymore though.
    RobertD[QUOTED] likes this.
  12. Sep 1, 2020 at 4:57 PM
    CorsoTundra
    North GA
    It's just cooler looking then the OEM one.
    Beesta likes this.
  13. Sep 1, 2020 at 4:59 PM
    Flightmech65
    Flightmech65 New Member
    Bucks County, PA
    2015 Crew 1794 & 2016 SR5
    TRD duals and cold air
    69 Panels and almost 17kW. With 3 teen girls,my in-laws living here, and every single appliance being electric, my bill is about $17 this month.
    NewImprovedRon likes this.
  14. Sep 1, 2020 at 5:25 PM
    RobertD
    Robert
    DFW, Texas
    Yeah, I found yotateq but most their stuff was for the Raptor. I did find these though:
    https://keychainguy.com/bottle-openers
    TheBlackPearl likes this.
  15. Sep 1, 2020 at 5:28 PM
    Danimal86
    Daniel
    Sacramento, CA
    2017 White Tundra SR5
    Ho-lee-sheet
    Ever think about putting in a couple Tesla batteries or similar?
  16. Sep 1, 2020 at 5:51 PM
    Tigereye
    Tigereye New Member
    Eric
    2019 SSM Limited
    I like it. Where can it be found? Thanks
  17. Sep 1, 2020 at 6:17 PM
    16TRD
    16TRD New Member
    Norcal
    2016 White crewmax
    How come there are two washers stacked together? Is it supposed to be like that?
  18. Sep 1, 2020 at 6:18 PM
    60driver
    60driver New Member
    Spring Lake, NC
    2016 Tundra CM Platinum Sunset Bronze
    2.5 Toytec Aluma front coilovers JBA UCAs Wheelers Off-road front bumpstops 2.0 Toytec Aluma rear shock OME greasable shackles and bushings OME Dakar Leaf Springs ARE CX Topper with Prinsu Toprac Northstar AGM deep cycle Renogy 100w solar panel with Renogy wanderer controller and BT1 module Yokohama Geolandar X-AT 35x12.5R17 Black Rhino Stadium 17x8.5 +10 Offset
    haven’t yet, definitely compiling. working through getting this build functional for an upcoming trip.
  19. Sep 1, 2020 at 6:20 PM
    16TRD
    16TRD New Member
    Norcal
    2016 White crewmax
    whats your suspension and tire set up? Im in sac as well. Will throw a :wave: if I see ya.
  20. Sep 1, 2020 at 6:44 PM
    jr1016
    jr1016 New Member
    Ric
    Sacramento, CA
    2020 CM TRD Sport
    He sent me an invoice same day I messaged him.
    ElNopal[QUOTED] likes this.
  21. Sep 1, 2020 at 6:55 PM
    Cfincke
    Cfincke Mall Crawler but capable
    San Antonio
    2014 Tundra 1794 CM 5.7 4x4 sunset bronze
    5.29s, Auburn LSD, 37x12.50R18, Icon coilovers and shocks, SPC UCA's, Tech 12 Volts sound system, Enve Grill
    We should get an San Antonio members run organized. I'm on the NE side but work need the rim
    Skippy[QUOTED], AggiePhil and HaveFun like this.
  22. Sep 1, 2020 at 7:01 PM
    Hartsy8
    Hartsy8 Resident Hockey Guy
    Max
    2020 MGM 1794
  23. Sep 1, 2020 at 7:18 PM
    HaveFun
    HaveFun Happy to be here
    Fair Oaks Ranch, Texas
    2019 Black Tundra CM SR5
    I’m in from the Fair Oaks area.
    Skippy and Cfincke[QUOTED] like this.
  24. Sep 1, 2020 at 7:19 PM
    sotex
    sotex Sic 'em Bears!
    Jeff
    San Antonio, TX
    2020 White Tundra SR5 Double Cab 4x2 SX
    I’m in SA too! Surely you’ll share?
  25. Sep 1, 2020 at 9:30 PM
    mcm0455
    mcm0455 New Member
    2020 Tundra Platinum
    Gave the truck a good detail today. Used Meguiar's ceramic wax. I like it a lot. It goes on easy and dries in 10 minutes. I am sure it's not the best ever, but it works well for me needs. I drive on gravel roads a lot so my truck will never be the mall crawler.
  26. Sep 1, 2020 at 9:49 PM
    PaulROahu
    PaulROahu New Member
    Paul
    Kaneohe, Hawaii
    2017 5.7 Tundra Platinum 4x4 MGM
    Rep our club member decals and my Vision TRD rims
  27. Sep 2, 2020 at 3:34 AM
    Tigereye
    Tigereye New Member
    Eric
    2019 SSM Limited
  28. Sep 2, 2020 at 5:17 AM
    BoxersBrew
    BoxersBrew New Member
    Thomas
    Northern Virginia
    2020 Black Tundra Limited Crewmax TRD
    Dealer installed TRD dual exhaust system and tonneau cover. Personally installed TRD Pro grille and surround, side mirror caps, and TRD shifter.
    Decided I liked the black door handles enough to pull the trigger on color matched. My vinyl job just isn’t going to work on a new truck. Should be here within the week.
    War Machine, GAknight, cp44 and 9 others like this.
  29. Sep 2, 2020 at 5:29 AM
    Skippy
    Skippy Standing for the Flag
    San Antonio US of A
    2016 Tundra 1794
    Sorry, I get those 2 mixed up. I've never been back in there, but one Saturday a while back saw the Tundra club (SATC) lined up going in as a group. Looks awesome back in there, and good open spaces are hard to find
    Jp-ProMamba[QUOTED] likes this.
  30. Sep 2, 2020 at 5:48 AM
    Moon Puppy
    Moon Puppy I'm not new!
    Bob
    2020 Tundra Limited
    I want that for my grocery snatcher!!
    PaulROahu and BoxersBrew like this.
