Sticking in Park
Discussion in '1st Gen Tundras (2000-2006)' started by Danielkent, Aug 30, 2020.
  1. Aug 30, 2020 at 3:40 PM
    Danielkent
    Danielkent [OP] New Member
    Daniel
    2005 Tundra Double Cab Limited 4x4
    None
    Hello all,
    New member here and new(ish) Tundra 1st Gen owner. I found a 2005 double cab, limited, 4x4, pretty clean with about 160k miles on it.
    I'm having a pretty annoying issue with it and came here looking for anyone with similar problems and was surprised it didn't show up when I searched the forum. If anyone has the thread handy, please direct me.
    Consistently, I have to press my brake, and then press it again harder, release and press again (usually withing 2 or 3 tries) to get it out of park. I'm sure it has a sensing device of some kind to prevent it from being shifted into drive without the brakes pressed, anyone know what I can look for?
    Thanks.
    YardBird likes this.
  2. Aug 30, 2020 at 3:42 PM
    empty_lord
    Indiana, Chicagoland
    05 rollover special
    the shift lock for these trucks is just a cable. crawling up under the dash you should be able to see it.. later i'll get a pic
  3. Aug 30, 2020 at 3:51 PM
    Professional Hand Model
    Fred
    Hand Protectors
    Remove panel and investigate around the steering wheel/shifter area. There is a ball that slides on a track. Push the lube back into the contact area. Lube shift cable connection located close by, as well.
    Crawl under truck and lube the arm and cable where they attach to transmission side.
    TX-TRD1stGEN likes this.
  4. Aug 30, 2020 at 3:54 PM
    YardBird
    YardBird Native San Diegan
    Jonesy
    2005 RCLB
    Welcome board from SoCal.
  5. Aug 30, 2020 at 4:01 PM
    Danielkent
    Daniel
    None
    Thanks for the welcome, glad to be here. I think I'm gonna love this truck.
    empty_lord likes this.
  6. Aug 30, 2020 at 5:48 PM
    Welcome aboard! Be sure to push the brake fully, then pull the lever towards you and down. Pulling on the lever before pushing the brake fully may cause the release mechanism to bind.
