Switchpro harness
Discussion in '2.5 Gen Tundras (2014-2021)' started by Genuine Cooling Systems, Aug 30, 2020.
  1. Aug 30, 2020 at 8:28 AM
    Genuine Cooling Systems [OP] New Member Vendor
    anyone know any tricks to de-pin the switch pro harness? The switchpro instructions are pretty vague and show a different connection.
  2. Aug 30, 2020 at 8:40 AM
    fisherman951
    fisherman951 MT dreams
    Tony
    2017 crewmax 4x4
    Paper Clíp in the small slots. Push the cable From the back so it’s all the way in the plug, keep the pressure and insert the paper clip in the small slot as much as u can. Then slide the wire out. Once u get the first one the rest become easy as ur more confident
    **** step one use a small flat head screw driver to unlock the white plug first just like the instructions say
    Sunnier likes this.
  3. Aug 30, 2020 at 9:28 AM
    I got thr white clip up but pushing the wires now I'm stuck. Do I push through the larger portion of the hole or the smaller slot for the terminals?
  4. Aug 30, 2020 at 9:48 AM
    fisherman951
    Tony
    2017 crewmax 4x4
    How u have the plug right now. Grab one wire at a time. Push up(towards u) and then slide the paper clip thru the small slot of that cable ur pushing. U will hear/feel the paper clip slid in to place. Then pull that wire out.
    Sunnier likes this.
  5. Aug 30, 2020 at 9:59 AM
    Do I push through the smaller slots? I attached a photo where the small slots are (red dots)
  6. Aug 30, 2020 at 11:10 AM
    fisherman951
    Tony
    2017 crewmax 4x4
    Correct. Make sure the paper clip is big enough and fits snug in there.
  7. Aug 30, 2020 at 11:13 AM
    Squatting Pigeon
    Holden
    North Texas
    4Runner | GR Corolla
    Like @fisherman951 said, hit those smaller slots (the ones you marked in red) with a paper clip, push pin, or tiny screwdriver and pull the wires (gently). My paper clips keep bending so I went and got my set of precision screwdrivers and used an Uber tiny Phillips one.
    The clips will make a pop/snap sound when they disengage. I had one that was a bear but the other three were super easy.
  8. Aug 30, 2020 at 11:54 AM
    Lol I destroyed the connector but I got the wires out. I have another connector on order. At least I know what the inside looks like now.
    fisherman951 and Sunnier like this.
  9. Aug 30, 2020 at 12:15 PM
    fisherman951
    Tony
    2017 crewmax 4x4
    Oh no, how did u manage to do that?
  10. Aug 30, 2020 at 12:19 PM
    I couldn't get the terminals to release to i snapped the white cap. Not sure why the instructions state you just need to push down. I had to pry open the clips for them to release.
    fisherman951[QUOTED] likes this.
  11. Aug 30, 2020 at 12:59 PM
    fisherman951
    Tony
    2017 crewmax 4x4
    That sucks. Did u make sure to take a picture of how the wires went in the plug color wise?
  12. Aug 30, 2020 at 2:14 PM
    I did. Thanks for your help.
