VF Tuner 3UR Support - Development Tools
Discussion in 'Performance and Tuning' started by OVTune, Apr 25, 2019.
Thread Status:
Not open for further replies.
  1. Aug 29, 2020 at 6:55 AM
    #4381
    OVTune
    OVTune [OP] New Member
    Mat
    2016 FFV CM
    OVTune RD Vehicle
    The truck is not shifting at all in D?
    I don't know how that is possible..
    Gearlock is not even used / called in code when the truck is in "D"
    When you press tow / haul it switches ignition maps for higher octane. You won't feel a "transformation" into a different tune from just pressing the button.
  2. Aug 29, 2020 at 6:58 AM
    #4382
    coTony
    Tony
    Montrose, CO
    Without pressing Tow I cannot tell I have a tune with the low octane. I will use Zendesk and request GL to be removed.
    Correct, in D it does not shift. Your asking at all? I am not going to redline it to see if it shifts.
  3. Aug 29, 2020 at 6:59 AM
    #4383
    OVTune
    Mat
    2016 FFV CM
    OVTune RD Vehicle
    ok please zendesk me because this doesn't make sense, we will figure it out privately.
  4. Aug 29, 2020 at 7:00 AM
    #4384
    coTony
    Tony
    Montrose, CO
    Agreed, does not make sense to me either. Thanks Mat
  5. Aug 29, 2020 at 7:54 AM
    #4385
    Genuine Cooling Systems
    Genuine Cooling Systems New Member Vendor
    Recieved my tune for my 2019. Will report back after my drive. Thanks mat.
    PeakIT and pnw.tundra like this.
  6. Aug 29, 2020 at 7:55 AM
    #4386
    pnw.tundra
    pnw.tundra PNW Tundra
    Paul
    PDX
    2022 TRD Pro | Prev 2020 Tundra aka Blue Whale
    Can’t wait to hear feedback on the 19 tune. Hopefully that’s means 20 is next.
    Trebz likes this.
  7. Aug 29, 2020 at 7:56 AM
    #4387
    OVTune
    Mat
    2016 FFV CM
    OVTune RD Vehicle
    Please test and let us know / confirm that features are working (gearlock, directshift)
    How to:
    Gearlock
    put truck in S mode. No Tow haul button.
    put truck into S2.. about 2000 RPM.
    go full throttle.
    Does the truck downshift?
    if not, gearlock is working.
    Directshift.
    S2. Full throttle, from 2000 rpm.
    click shifter UP.
    Does truck shift before rev limit?
    direct shift confirmed
    Stroke250 likes this.
  8. Aug 29, 2020 at 8:01 AM
    #4388
    I'll let you know in about 15 min.
  9. Aug 29, 2020 at 8:06 AM
    #4389
    @OVTune please see pm.
  10. Aug 29, 2020 at 8:57 AM
    #4390
    OVTune
    Mat
    2016 FFV CM
    OVTune RD Vehicle
    018/19 ECUs use a different ram setup / bit segment for activation of "s mode"
    and, after a test is complete, we believe we got it fixed.
    So there will be an update to 18' ecus (0CN21).
    that is you AzTony.
  11. Aug 29, 2020 at 9:08 AM
    #4391
    osidepunker
    osidepunker OsidePunker
    Alex
    2013 Tundra DC 4x4
    Full LT, full armor, fully self contained Speed Glamper
    My tune is broken. I can't downshift which means it's not safe to drive on mountain roads.
    I guess I'm in time out now because I pissed you off. It's been almost a month now and you said a couple weeks ago that you had a fix. But I guess you just want to punish me.
    Worst customer service ever and I thoroughly regret giving you my hard earned money
    Saltyhero13 likes this.
  12. Aug 29, 2020 at 9:11 AM
    #4392
    Emptypockets
    Emptypockets New Member
    2012 CM Platinum
    Does anyone know when @OVTune might get to 2012 ECU’s? Do I need to purchase product in advance? If so, what needs to be purchased exactly?
  13. Aug 29, 2020 at 9:12 AM
    #4393
    OVTune
    Mat
    2016 FFV CM
    OVTune RD Vehicle
    one file is messed up.
    Flash back to one of the multiple other files you have, like the previous one.
    You are not our only customer, and we have someone else testing this ECU version to ensure it works, before sending it to you.
    Because I can only IMAGINE what would happen if we sent one to you again that didn't work.
    sometimes I wish companies could rate their customers. You have complained since day 1. Just keep complaining, I don't care, honestly.
    I'm not going to send you another file until I fully confirm that it works.
    We aren't a perfect business, things get in the way. But yea we do have to take extra steps, precautions, etc with you. You know why.
  14. Aug 29, 2020 at 9:23 AM
    #4394
    OVTune
    Mat
    2016 FFV CM
    OVTune RD Vehicle
    2019 File(s) are tested, verified and have been distributed
    base NA 19' tunes
    base SC 19' tunes
    Gearlock, directshift features included.
    Stroke250, Vr0ck and DanoDavis like this.
  15. Aug 29, 2020 at 10:31 AM
    #4395
    Here is a short video of the direct shift on a 2019. Great Tune! The truck shifts way better in "d" and gets rid of the sluggishness of the stock tune.
    https://youtu.be/qDmPpMwDN1A
  16. Aug 29, 2020 at 10:34 AM
    #4396
    TruckyTruck
    TruckyTruck Dumbest Username
    Gary
    Beautiful!
  17. Aug 29, 2020 at 10:54 AM
    #4397
    Cuban11182
    Cuban11182 New Member
    Hope Mills, NC
    2018 Tundra Limited
    Kings w/ adjusters, Icon Rebound with Discover AT3 LT 285/75/R17, Airlift bags, ARB dual compressor, OV Tuning,
    Vr0ck, DanoDavis and Sbrakeville like this.
  18. Aug 29, 2020 at 10:59 AM
    #4398
    sask3m
    sask3m New Member
    Alberta
    Black 2019 SR5
    Would it be best to have the fuel pump recall done on a 19 before installing the tune or does it matter?
  19. Aug 29, 2020 at 11:20 AM
    #4399
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
    Log collected and sent to ZenDesk and alternate email (due to oversized file) and my not wanting to split/interrupt data stream/collection. Thanks.
  20. Aug 29, 2020 at 11:48 AM
    #4400
    DanoDavis
    DanoDavis New Member
    Dallas
    2018 White Tundra -5.7 -4x4 -TRD Sport - Leather
    Shell - OV Tune
    how’s that Throttle response feel? Noticeable increase in pep/pickup?
  21. Aug 29, 2020 at 11:50 AM
    #4401
    art64
    art64 New Member
    Are the 2010 Tundras on the bottom of the list?
  22. Aug 29, 2020 at 12:10 PM
    #4402
    Throttle response is improved in my opinion.
  23. Aug 29, 2020 at 12:13 PM
    #4403
    DanoDavis
    Dallas
    Shell - OV Tune
    I’ve got an 18’ and the throttle response/factory tune is damn sluggish. My dad’s got a 13’, and it *feels* so much better. Feels much more like it should.
    hell, i I’ve to put tow/haul on to make mine feel like my dad’s stock 13 lol
  24. Aug 29, 2020 at 12:26 PM
    #4404
    OVTune
    Mat
    2016 FFV CM
    OVTune RD Vehicle
    I don't have it setup by year. it's by CAL ID.
  25. Aug 29, 2020 at 12:48 PM
    #4405
    Emptypockets
    2012 CM Platinum
    How is the CAL ID found/determined?
  26. Aug 29, 2020 at 12:53 PM
    #4406
    Hit "identify" on your VFTuner software. There are instructions on his website.
  27. Aug 29, 2020 at 1:02 PM
    #4407
    Emptypockets
    2012 CM Platinum
    I don’t have the software as I didn’t know if OV would even be available for my truck.
    So again, do I need to purchase in advance and if so what exactly?
    Thanks in advance as my previous post got lost due to others problems.
    MTRock likes this.
  28. Aug 29, 2020 at 3:35 PM
    #4408
    jeffrej1
    jeffrej1 New Member
    Jaime
    2019 Tundra Limited CrewMax 4X4
    All of the buttons are grayed out. How do I resolve this?? Trying to load the tune Matt sent me this afternoon.
  29. Aug 30, 2020 at 1:49 AM
    #4409
    Cuban11182
    Hope Mills, NC
    2018 Tundra Limited
    I just dealt with this a few pages back. You need a new registry key. Copy that system ID and send it to him in the email string from Zendesk. He will reply with a registry key that you download and double click on. This will give you the ability to read and flash.
  30. Aug 30, 2020 at 7:38 AM
    #4410
    jeffrej1
    jeffrej1 New Member
    Jaime
    Thanks bud. Once I looked back at the original key he sent and realized it was different, I shot off the email.
    This is kind of a shit way to do this if it continues to change. Im locked out until they respond.
    Cuban11182 likes this.
Thread Status:
