  1. Aug 28, 2020 at 6:18 AM
    #7261
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
    Oh, forgot to post. Here are pictures of my old cruddy brake fluid.
    Once I saw how shitty it was, I went ahead and finished up. Thinking I was doing good.
    Got in the truck and discovered I'd done a boo-boo. I asked the group for help, and tried to tinker a little more. I was tired, and getting no where. Phoned pops, and asked him to bring home Dot3. Went to bed.
    Once I was ready for work we went out, and bled my brakes with new Dot 3. Pedal feel has returned to normal.
    Not sure if it was the bleed, or the new fluid. Maybe a combo.
    I did not take pics of the rear fluids, but I did get some gunkies out of the LSPV.
    Edit: Dot 3, or old Dot 3 will eat Rustoleum bed liner... at least on plastic.
  2. Aug 28, 2020 at 6:21 AM
    #7262
    On a slab of meat like that, you just want to keep it under 24-36 hours depending on how salty your brine was.
  3. Aug 28, 2020 at 6:32 AM
    #7263
    Ok thanks, I did like half a cup of salt to 8cups of liquid(cider and cider vinegar)
  4. Aug 28, 2020 at 6:37 AM
    #7264
    @Casper421 good call. Fits like a glove. Still no way the 4 of us can fit but will work if I go out with just the dogs.
  5. Aug 28, 2020 at 6:42 AM
    #7265
    Yeah, my biggest concern wouldn't be saltiness. My concern would be the acid in the vinegar making the pork mushy. Acids tend to break down meats, it's why you don't marinate meat in, like, pineapple juice and you should avoid letting pineapple coming in contact with meat on a skewer or kebab. Especially for chicken.
    I tend to go with water alone for my brines and avoid adding any acid. Then there's never a question about penetration, no concerns of time it's in there, or worries of changing the meat texture.
  6. Aug 28, 2020 at 7:04 AM
    #7266
    Casper421
    In the woods
    06 DC
    Nice work. Is there enough room in the cab for the dogs to sleep?
    NUDRAT[OP] likes this.
  7. Aug 28, 2020 at 7:10 AM
    #7267
    Pucks18
    Pucks18 Fleabit peanut monkey
    2001 Tundra 4x4 Limited trd
    Does anyone know when the" new member" goes away under my name lol? I mean jesus christ it's been 9 months!
  8. Aug 28, 2020 at 7:21 AM
    #7268
    Not comfortably. This is when I wish I bought a DC. The fridge takes up about 50% of the back seat area and the remaining area is used for storage. I'll try to tweak more but I don't see both dogs fitting in the truck. Gunner is 70lbs so he needs some space.
    Darkness and Casper421[QUOTED] like this.
  9. Aug 28, 2020 at 7:24 AM
    #7269
    Looks like you got it figured out. I'm glad you didn't do anything offensive like this:upload_2020-8-28_10-24-10.jpg
    I'm triggered by this. :mad:
    CodyP, bmf4069, GODZILLA and 4 others like this.
  10. Aug 28, 2020 at 7:36 AM
    #7270
    Pucks18
    @Tundra2 is your "post in moderation " bio a little bit sarcastic ? ;)
  11. Aug 28, 2020 at 8:19 AM
    #7271
    Darkness
    Darkness Allergic to white
    Luis
    All over SoCal
    The darkest
    It's really dark
    Wife sleeps in cab then :D
  12. Aug 28, 2020 at 8:45 AM
    #7272
    Dark Trucks Matter!
    bmf4069, TX-TRD1stGEN and Darkness like this.
  13. Aug 28, 2020 at 9:41 AM
    #7273
    BubbaW
    Bubba
    Where Eagles Nest
    04 DC LTD 4X4 4.7 V8
    T150 Lover
    @Darkness needs no help, suck up :)
    CodyP, bmf4069, GODZILLA and 2 others like this.
  14. Aug 28, 2020 at 9:44 AM
    #7274
    That's one way to make light of the situation!
    bmf4069, GODZILLA and Darkness like this.
  15. Aug 28, 2020 at 11:00 AM
    #7275
    empty_lord
    Indiana, Chicagoland
    05 rollover special
    Engine harness on, engine in. [​IMG] [​IMG] [​IMG]
  16. Aug 28, 2020 at 11:27 AM
    #7276
    Dan,
    what sort of things would you replace in that scenario. I assume you had to do a new rear main seal? Fresh oil and coolant even though it's practically a new engine?
  17. Aug 28, 2020 at 4:35 PM
    #7277
    empty_lord
    05 rollover special
    I didn’t bother with the rear main because it still seemed pliable. I’ll monitor it, but typically yes, new rear main, i pull the oil pans on my own cars to check the internals and paint the oil pans (they get scratched up in the junkyard and eventually will rot out) and replace the spark plugs.
    this one being pure budget and being such low mileage all I’ve done is put it in and let it go. I have an air fuel sensor coming and a new thermostat (because it’s stuck). Other than that, this is one of the quietest corollas I’ve heard running
  18. Aug 28, 2020 at 4:36 PM
    #7278
    empty_lord
    05 rollover special
    [​IMG] Makes the inside of the engine bay look a lot better. Guess I’ll be pulling all the rust shit and painting it in My free time
    speedtre, bmf4069, Casper421 and 5 others like this.
  19. Aug 28, 2020 at 4:38 PM
    #7279
    empty_lord
    05 rollover special
    [​IMG] The before just shows how rough this thing was ran
  20. Aug 29, 2020 at 5:17 AM
    #7280
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
    Did some more rooting around when I got home with a new angle of attack.
    I'm guessing that FR is front right, and that second empty spot is where the float would go. I'm guessing I don't have the wiring for it either...
    Unless @empty_lord knows where it would be tucked up. Like my fog light wires were ziptied to the body since my truck didn't come with fogs.
    Any clues fellas?
  21. Aug 29, 2020 at 5:59 AM
    #7281
    So I've been wondering, why do we measure from the hub when measuring lift? Wouldn't it be the same from the ground? From the hub to the ground isn't gonna change.
  22. Aug 29, 2020 at 6:03 AM
    #7282
    Darkness
    Luis
    All over SoCal
    The darkest
    It's really dark
    Eliminates differences from tire size.
  23. Aug 29, 2020 at 6:07 AM
    #7283
    Ohhhhhh. Like if dude A has 33s, and dude B has 275/65/16, the hub measurement would be the same on both, but ground measurement would be different?
    Darkness[QUOTED] and Tundra2 like this.
  24. Aug 29, 2020 at 6:19 AM
    #7284
    Professional Hand Model
    Fred
    Hand Protectors
    See if @lssasami has it on his truck. Send part.
    bmf4069 likes this.
  25. Aug 29, 2020 at 6:21 AM
    #7285
    Fred
    Hand Protectors
    I have two answers for you and yours depends on if you believe in Flat Earth, or not.
    TX-TRD1stGEN and bmf4069[QUOTED] like this.
  26. Aug 29, 2020 at 6:23 AM
    #7286
    Earth is flat where I am.
  27. Aug 29, 2020 at 6:24 AM
    #7287
    empty_lord
    05 rollover special
    The r would be where the rear washer fluid motor would be on a sequoia
  28. Aug 29, 2020 at 6:26 AM
    #7288
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
    I forgot all about @lsaami's parts truck. D'oh!
  29. Aug 29, 2020 at 6:32 AM
    #7289
    Fred
    Hand Protectors
    Ok. Since you believe, then when measuring your wheels distance you would start from the ground and go up to the wheel well. Take that measurement and factor in a multiplier of 3.14 (Pi) which is an actual infinite number. Divide that by the angle of deflection due to seasonal ground angle. Once you achieve this Grasshopper, then you will have inner bliss with Ying and Yang.
    bmf4069[QUOTED] and TX-TRD1stGEN like this.
  30. Aug 29, 2020 at 6:36 AM
    #7290
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
    Forgot all about the Sequoia.
    Well, I can't see too well into the front of the reservoir. I'll just assume its up in front until I actually find it.
